Results 1 to 4 of 4
    Veteran Member Three Rings A4_PimP's Avatar
    Jan 18 2012
    Waterdown/Ontario/Canada
    Drain hole locations
    When I started looking at doing this on my car I found a ton of information about what to do and where the drainage holes are but the information was in pieces all over. I also couldn't find any good pictures of where exactly on the car the drainage holes were to give me a visual idea. I found some images and thought I'd put it all in one thread to help future B7 owners.
    This map is small but it shows the sunroof drains and where they exit out
    Body_drains by Ricky Williams, on Flickr
    Up at the Sunroof the two front drain holes are pretty easy to get to with the sunroof all the way back
    Front sunroof drain by Ricky Williams, on Flickr
    Apparently the rear ones are not so easy to get to but if you tilt the sunroof it may be possible
    Rear sunroof drain by Ricky Williams, on Flickr
    Exit of rear sunroof drain holes
    Where I got this from on the web captioned it as from a B7 S4 so I don't know if it applies to A4s as well. I will try to verify and update when I can.
    Exit of rear sunroof drain by Ricky Williams, on Flickr
    Drain holes under the battery tray. I couldn't really get a good image of the one under the Brake Servo
    Battery tray drain by Ricky Williams, on Flickr
    Mar 01 2016
    San Diego/CA
    Good Info.. Thanks!
    Jan 18 2012
    Quote Originally Posted by hemantpd1 View Post
    Good Info.. Thanks!
    I have been helped so much by these forums just trying to return the favor for others :)
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    CNY
    Items for Sale
    The rear sunroof drain image you posted isn't for a B7. The drain is higher up in the wheel well behind the liner.
    Clicky Click
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
