Results 1 to 10 of 10
    Active Member Two Rings devonsmith96's Avatar
    Mar 19 2017
    Manchester Connecticut
    Guess who blew his motor "this Guy"
    so just wondering my motor went from oil starvation it cranks but does a no start no compression or anything. just wondering is it possible to salvage the block and head and do a complete rebuild with the dnj rebuild kit
    Jun 30 2008
    Erie, Pennsylvania
    On the 1.8T, usually oil starvation kills the head RIGHT QUICK LIKE (sometimes along with turbo), but the bottom end is generally ok to reuse.
    You would determine this by inspecting the cam caps for wear. Seems to be the front ones take the worst beating, so prolly start there. If any of the caps are scored, you need an entire cylinder head. If the damage is really minor, you can polish it out with some emery cloth and soldier on.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Like Walky said, oil starvation is BAD. Tear it down and inspect, that'll be your only true indicator! I've got my fingers crossed for you!
    I also have an AEB head if you need one lol
    Mar 19 2017
    thats my plan i have shop service class so its between rebuilding my motor or swapping a junkyard motor
    Jan 12 2014
    Fargo, ND
    Good deal!
    Not sure on the price of the kit you're referring to, but I used the urotuning.com rebuild kit on my engine - http://www.urotuning.com/Engine-Rebu..._1.8t_late.htm - just so you have some more options!
    15k miles thus far on an HX35 @ 44psi, I give it a thumbs up!
    Mar 19 2017
    This is the kit that I sourced
    Sent from my Moto E (4) using Audizine mobile app
    Jan 12 2014
    Fargo, ND
    I'd tear it down and inspect your situation first, it would suck to order parts you won't need or use. Looks like a thorough kit.
    Sent from my SAMSUNG-SM-G891A using Audizine mobile app
    Mar 19 2017
    Do any of y'all know where I can find the steps to put the b5 into service position and the steps to remove the motor?
    Jun 30 2008
    Erie, Pennsylvania
    Step 1: Big Pants on.
    Step 2: Cowboy up.
    If you get the first 2 steps right, the rest just figures itself out.
    Kidding aside, you should look at timing belt DIY guides for the front end disassembly. I didn't see a 1.8T motor pull guide, but there's like 1,000 of them for the B5 S4 (LOL), so that may help a little.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What's the quality on those DNJ parts?. In my situation, I pieced together the kit with higher quality parts for probably less.
