Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 369
  1. #201
    Established Member Three Rings canduchita's Avatar
    Jan 11 2017
    ypsilanti
  2. #202
    Nov 12 2015
    Oregon
    Im curious as to why you switched focuses to make it a drag car now?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    My build log
  3. #203
    Jan 11 2017
    ypsilanti
    I don't know I just thinking I have a chance of being the 1st one in the U.S to hit 8 in the quarter mile with a B5 2.7T some gonna give it a shot
  4. #204
    Nov 12 2015
    Oregon
    Quote Originally Posted by canduchita View Post
    Well good luck! I just hope the integrity of the cage holds up if it needs to from speeds generated by doing an 8 second pass.
    Give em hell
    Vinny
    My build log
  5. #205
    Veteran Member Three Rings RickyCastro's Avatar
    Mar 14 2011
    2015 Misano Red 8V S3
    Anchorage, AK
    I have Recaro Profi SPG's. Love them. Light and they look great
    2002 Pearl White S4 Avant Tip (Sold)
    2015 S3 Misano Red Prestige | Performance
    2000 Nogaro S4 6speed 3.0L k24 AKA Money Pit (Sold) Bought back 3L WDR 6466
    1998 A4 2.8 Tip (Sold)
  6. #206
    Established Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    I used to run my CRX on that battery :)
  7. #207
    Established Member Two Rings Isaac313's Avatar
    Aug 15 2017
    2008 Ford F350 Diesel - 2000 Audi S4 - 1994 Ford F150 Lightning
    Michigan
    Just got a wrecked 01 if you need anything from a partout...
    I can't wait to see an 8 Second car. I'm curious how the aerodynamics will be for this?
  8. #208
    Established Member Two Rings ofspecialk's Avatar
    Nov 06 2016
    Attachment 52438Attachment 52439 A couple more pictures at different angles these will be the last pictures before I doing a video update of it when I go over to KROWX next month
    How much does the vehicle weigh without the body??
  9. #209
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by ofspecialk View Post
    I'm not sure yet because I haven't waited the car but I'm gonna guess somewhere on 2000 ish But I should have a weight soon for it since I'm gonna do coil overs so I need it for Spring rate
  10. #210
    Jan 11 2017
    ypsilanti
    Here's another shot of the blue carbon mirrors
  11. #211
    Senior Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego Ca
    This is what we had before but this aint gonna cut it anymore
    FIA Approved fixed back SPARCO or Recaro.
    Suprised your "cage builder" didnt design the main hoop around the driver and his seat.
    Are they ever going to install supports/ harness mounts for the main hoop?
    Also surprised they haven't fixed the cage reinforcement issue on the rear of the cage that i pointed out to you, good luck passing tech with that....
    b5 s4. k24, 2.8 heads, rods, meth, corn, gutted, custom standalone, rear radiator
    c5 a6 4.2
    4.2 touareg. Locking diffs, air suspension.
    350$ 2.7t c5 a6, runs perfect
    Cls 63 sAMG 4Matic
    LP700-4 Aventador, ithaca verde
    52' Studebaker Pickup, Fully blueprinted original motor, hardened valve seats, 85 Horsepower!
  12. #212
    Jan 11 2017
    ypsilanti
    Deck cooling
    Screenshot_20180313-222936.jpg Has anybody done this or anybody have any feedback on it
  13. #213
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    '07 Volvo S60R EFR 7163 Turbo, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    The principle behind it is valid. You can further push the limits of the combustion mixture with optimized cooling.... closed deck blocks are strong but not the best for cooling. Curious to know where you found this?
    2001 Silver/Black S4, Built engine (RPM rods, ARP hardware, Mahle pistons, Supertech valvetrain, etc), Tial 605's @25psi on 93 oct, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
  14. #214
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by ElementR View Post
    Thanks for the info euro spec offers it on their motors
    http://www.eurospecsport.com/products/engines/v6-5v.htm
  15. #215
    Veteran Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    Quote Originally Posted by rguil View Post
    Is the main hoop even one piece? And 180 deg or less on bend?
    98 Passat Var,2L,IE/JE,ARP,034,SPA,50tr,3tbe,FX400,BigREDs,Uni440,Fuel ab,Sterns,Mocal,Bils,JHM
    LINKS:2L Build,Further PerformanceHausOfHarnessD2 S8 40vQM
  16. #216
    Jan 11 2017
    ypsilanti
    Well not sure on the deck cooling yet but for sure I just went into a group buy and bought the bass girdle
    If there anybody else's interest they're still taking more orders for the group by
  17. #217
    Jan 11 2017
    ypsilanti
    I didn't know how to answer any of those questions so I asked JD from KROWRX
    Yes the main hoop is 42Ē tall and standard fixed back seats are 32Ē tall, regulations require 0 sliders but I took that in a count adding more head room as well. Also the harness bar is tied in and you wrap the harnesses for maximum strength! The rear will have multiple bracing but mounting rear rad and fuel cell and mock up rear firewall is done before bracing to ensure proper clearance.
  18. #218
    Dec 17 2014
    San Diego Ca
    That deck cooling looks interesting, id be interested to see your results.
    c5 a6 4.2
    Cls 63 sAMG 4Matic
  19. #219
    Jan 11 2017
    ypsilanti
    Meth tank
  20. #220
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    whats the group buy price ? could probably talk with marshall (rock candy customs)
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
  21. #221
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by AudiTechS4 View Post
    $1179.00 Shipped
  22. #222
    Jan 11 2017
    ypsilanti
    Here is a picture of the alphaloc clamps that we're going to use on the intercooler the Craig from white dog is going to be making for me
  23. #223
    Jan 11 2017
    ypsilanti
  24. #224
    Jan 11 2017
    ypsilanti
  25. #225
    Senior Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    The amount of hacking and custom work going into this car is unreal... I love it!
  26. #226
    Jan 11 2017
    ypsilanti
    Should I go 3.0L stroker And I guess of yes I need help what crank do I need, what will be the best rod to use what pistons and compression
    And I guess if no why no
  27. #227
    Aug 04 2013
    Pennsylvania
    Avk crank. Rods have been discussed in countless threads. As far as pistons, I went with Mahle 142 pistons for Issam. 82.5mm for a little extra cylinder wall thickness and also room to bore over in the future if it is ever needed.
    I'll leave the pros and cons to someone else. It's also been discussed in a lot of other threads.
  28. #228
    Senior Member Three Rings Gtmauto's Avatar
    May 29 2016
    Ann arbor michogan
    3.0 🤗🤗🤗🤗
    Sent from my SM-G930P using Audizine mobile app
  29. #229
    Jan 11 2017
    ypsilanti
  30. #230
    Jan 11 2017
    ypsilanti
    Just waiting on the intercooler to be finished at white dog racing so I can personally deliver it to JD at krowrx so they can finish the front.
    Really excited it's looking good
  31. #231
    Jan 11 2017
    ypsilanti
  32. #232
    Jul 04 2012
    Woodbridge, VA
    Just curious, are you going to put body panels on it or what's the plan? Good stuff man.
  33. #233
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by vavJETTAw36 View Post
    At the moment there is no plans of body panels but maybe in the future who knows at least maybe at front
  34. #234
    Jan 11 2017
    ypsilanti
  35. #235
    Dec 17 2014
    San Diego Ca
    You should consider the stroke to bore ratio in your build.
    Increasing the stroke will increase piston speed at the same RPM.
    Id say keep it simple and not put the life of your engine in the hands of a machinist that might not know what hes doing with a 2.7
    If i were you id do rods with stock pistons and either 2.7 heads with 2.8 cams or 2.8 heads and cams depending upon your turbo choice.
    c5 a6 4.2
    Cls 63 sAMG 4Matic
  36. #236
    Oct 11 2016
    Connecticut
    I think some custom fiberglass or carbon fiber body panels could be a great touch... after the exo is up and running! like a continuation of this madness!!!!
  37. #237
    Jan 11 2017
    ypsilanti
  38. #238
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by JustManson View Post
    Yeah definitely I think once we have it complete maybe we can do some mah carbon fiber body panels it's already getting a carbon fiber diffuser carbon fiber wing and a couple other nice bits and pieces of blue reflection carbon fiber
  39. #239
    Jan 11 2017
    ypsilanti
    Driving to Alabama tomorrow to take a look up the EXO S4 in person hopefully will have some more pictures and video of the update
  40. #240
    Jan 11 2017
    ypsilanti
