Results 1 to 7 of 7
    Active Member Two Rings GlacierS5's Avatar
    Jul 27 2017
    2015 Infiniti QX60, 2008 Infiniti G35 S 6MT
    San Jose, CA.
    034 Motorsports Rear subframe kit noises
    Anyone who installed 034 Motorsports Billet Aluminum rear subframe mount insert kit noticed excessive noise when going over speed bumps? The noise started about a month ago and now its more noticeable. Sounds like the OEM rubber is rubbing/squishing against the inserts. I made sure everything was installed correctly using the specs and grease recommend by 034. I may need to pay a visit to 034 to diagnosed.
    Sent from my Pixel XL using Audizine mobile app
    2018 Glacier White | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    May 20 2010
    Wrecked B7 A4
    Items for Sale
    Is there any kind of lubrication required?
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    CNY
    Items for Sale
    Quote Originally Posted by GlacierS5 View Post
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    May 20 2010
    Wrecked B7 A4
    Items for Sale
    Quote Originally Posted by fR3ZNO View Post
    Reading comprehension fail on my part
    Active Member Two Rings GreyLens's Avatar
    May 24 2017
    San Antonio, TX
    This is concerning. I'm planning to install these in a couple of months and certainly don't want squeaks happening. I go over a lot of speed bumps at the apartment...that would be bothersome. Post your findings.
    2018 S5 SB| D-Grey | P+ | Sport Diff | Carbon | B&O | Tech | Napa | Ceramic Pro |
    Jul 27 2017
    San Jose, CA.
    Will do! Dropping her off on Tuesday for 034 to diagnosed
    Senior Member Four Rings Jimmy ny's Avatar
    Sep 13 2014
    New York
    I had same problem on my RS5. It can cause minor noise and toughness depending on the weather and type of road imperfections you may encounter. Not a worth while mod and you will see zero gain on the street. A track only mod when you looking for every last piece of performance.
    2016 TTS. Mythos Black w/ Nappa Red interior. APR 1, AFE Intake
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
