Results 1 to 11 of 11
    Feb 19 2015
    Las Vegas, Nevada
    What is this trim piece called? And where can I buy it?
    So this little piece of window trim is broke on 2 of my doors. I've looked at pictures of replacement trim and it doesn't look like it is included with the trim I've saw. What is this little bit and where can I get it?
    Established Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Perth, WA
    Thats rubber behind the door trim. You need to purchase the whole trim and take the door completely apart to remove it. Not worth it.
    A4 B7 2.0T | HPFP upgrade + FMIC | BSR Stage II + exhaust + HFC | RS4 fuel contr., PRV + S3 inj. + DW300c | GFB DV+| 034 RSB + all arms and mounts | S4 brakes | B12 Bilstein suspension + H&R springs | Polk Audio PA D5000.5 - 4 x DB6502 + db840DVC sub + Pioneer 10" sub | LEDs throughout | 19" Audi 2015 RS4 rims
    Feb 19 2015
    Las Vegas, Nevada
    Ahh......Piss. Well thanks for the bad news anyway haha.
    Oct 24 2015
    Perth, WA
    Just get some sikaflex or similar and stick it down. If youíre careful youíll not notice
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    How did that happen?
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Senior Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    ^^seriously lol.
    Also Iím pretty sure that piece on my car is black. Yours looks silver?
    2005.5 A4 2.0T Brilliant Red | 6MT | Quattro | S-Line
    Go: K04 | ST Coilovers | Carbonio | Maestro | S3 Injectors | IE Rods | JHM FMIC | Autotech HPFP | ECS Short Shifter | JHM Clutch | USP HFC | Quad-tip Exhaust | S4 Brakes
    Show: DTM Rear + Skirts | Recaro | Black Miro 111 19" | RS4 Grille | Votex Spoiler | OEM CF Trim | S4 Mirrors | Black Ext. Trim | CC + Joey Mod Bixenons | LED Tails | A8 Rings | RNSe | 20% Tint | 034 Adj. UCAs
    Jan 26 2010
    SC
    Its called a window slot seal. Does your car have the chrome trim for all the windows or are they all rubber? If its the chrome trim you are going to have to remove everything from the door. If not you should be able to remove it without having to take anything apart. I just replaced that thing today as mine kinda disintegrated got sticky and left black streaks on the outside of my window and trim pieces.
    Feb 19 2015
    Las Vegas, Nevada
    Its black, that wonky lighting kinda makes it look silver. No idea how it happened tho. Front passenger door has a big ass piece already broke off. Drivers rear is in the pic. I'm sure it'll be coming off soon. Can't stand to look at it lol.
    I have the chrome trim. Its wrapped in vinyl to make it black. Which come to think of it could be how it got damaged to begin with.
    So with it being chrome it all has to come apart to replace that? Ugh.
    Feb 19 2015
    Las Vegas, Nevada
    So when I google window slot seal it doesn't look like this. Its the trim piece with the wiper(seal), but not this rubber piece. This is over the window wipe. I think its more for aesthetics than anything maybe?
    Jan 26 2010
    SC
    Ya you are going to have to pull apart the doors to replace them. The part numbers for the front passenger side is 8E0853284G and the rear driver is 8E0853767A. Thats if you are correct in having the chrome trim. If you go on youtube you can find a video to replace the window regulator and thats how you have to take apart the door to remove it. It took about 2 hours to fix it for the driver side door only. To confirm you have those part numbers you can roll the window down and look down in there and you should be able to see the part number.
    Feb 19 2015
    Las Vegas, Nevada
    Oh ok. Well I know exactly how to do it then bc I have a regulator I have to replace, so I've been watching the videos on that. What figures tho is that its a different door then the trim problems. Oh well. Has to be done......eventually.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
