Results 1 to 6 of 6
Thread: k04-015x
    Established Member Two Rings goa's Avatar
    Nov 18 2016
    Tokyo japan
    k04-015x
    In this turbine boost will leak. Overshoot occurs. Cause?
    https://www.amazon.com/XS-Power-KO4-015-PASSAT-UPGRADE-K04-015X/dp/B017KQJH0K
    Nov 18 2016
    Tokyo japan
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Items for Sale
    Like every other one of your threads you need more info, also that turbo is crap so probably your issue.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Apr 01 2007
    2017 Mustang GT Performance Package, 1983 Chevy Silverado
    houston texas
    Over boost occurs because its an over-sized compressor wheel stuck into too small of a compressor housing - along with an undersized turbine.
    X2 on it being a low quality turbo, I would pass.
    2003 A4 1.8TQ
    APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
    Jul 14 2009
    Pasadena
    Items for Sale
    from now on you should post your questions here: http://www.audizine.com/forum/showth...oo-dumb-to-ask instead of making a new thread for every topic that has already been covered.
    build page here
    GTX2867r Audi a4 b6 TQM RECARO|HRE|ER|IE|APR|AWE|034
    IG: @matthewee
    Veteran Member Three Rings 3 bar's Avatar
    91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Items for Sale
    The chra is crap and as they said the compressor housing isn't correctly matched to the turbine side. I've got one on my b5. After 10k the turbo seals blew out and I sent it to Tims turbos in Annandale VA for a rebuild. He put in a genuine borg Warner CHRA and clipped the turbine impeller to balance it out. $450 dollars later after initially spending $450 for it. Have had no problems since.
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
