Results 1 to 25 of 25
    Sep 19 2016
    Roseville, CA
    Difference between $500 Coilovers vs $1500 Coilvers?
    Hey guys,
    Just wanted to get your take on something. Is there a real big difference between a coilover set like this one that's around $550 like this one....
    https://www.ecstuning.com/b-solo_wer...xoCBi0QAvD_BwE
    and one's that are $1500 like this one...
    http://www.modbargains.com/KW-Coilov...i-B8-A4-S4.htm
    This is all for my 2010 A5 2.0 Quattro S-Line. Is the major difference between the two ride quality since they both have the ability to lower the car at about the same height?
    Thanks Guys!
    May 20 2010
    Lots of things. Materials, construction, damping characteristics, quality, and brand recognition, to start with. KW is renowned the world over for making fantastic suspensions. Also includes R&D cost and certifications.
    On my B7, I had 4 different suspensions: Stock, H&R, JOM, and Voltland. H&R (new $1100+) rode well but the rear was always lower than I wanted (rake was wrong) and from side-to-side, it would never line up. JOM Bluelines ($400) were easily setup and level, but they were cheap and did not dampen as much as I wanted (would rub on bumps). The Voltland GT1s were fantastic--easy to get setup, settled in at the perfect height, and drove so much more comfortably than any other than stock.
    Feb 27 2014
    Dubai
    Go with the bigger names and you’re getting a product that’s had R&D for a specific vehicle, it will have a damper that contains quality parts and it will improve the vehicle both dynamically and asthetically.
    Go with to the cheaper brand and it won’t have had the same R&D if any, it will improve the vehicles aesthetics but you will soon feel the cost savings when it comes to dynamics.
    Been there with FK coilovers, look nice and shiney but terrible rebound damping had the car bouncing almost out of control, I pulled the damper apart to look at the insert, when I compared the damper insert on their spare parts list, the same part number was used in just about all their dampers, no matter what the weight of the car or spring used.
    FK’s solution to the bouncing ride was to send out a stiffer spring. Considering it was already underdamped this was only going o make a bad situation worse. They went in the bin and Bilstein went on, the difference was $1000 but also a fantastic handling car.
    I accept a Stage II tuned S5 is quicker than an RS5
    Doug convinced me
    He's also the reason I don't come here much
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Jersey City, NJ
    @jamesrs5 you nailed it. Great insights.
    Sent from the Amazon.
    PAST| B8 S5| B6 S4| B6 A4
    NEXT| Another Audi of Course
    Active Member Two Rings keinmitleid's Avatar
    Aug 08 2017
    nevergonnaletyoudown
    I don't mind paying $1500+ for coilovers, I just would hate to get them and not go as low as I want them to go. Not talking stretch tires and stupid camber, just as low as possible without rubbing and ridiculous camber. Not worried about stiffness, I actually prefer it.
    997.2s Cab
    B8.5 S5
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Shelby Twp, MI
    The main thing that no one has pointed out yet is stainless vs non. If you live in the northeast/midwest and drive your car year round then you're better off getting a stainless set. These stainless sets (Bilstein, K&W) also are the more expensive ones. I live in Michigan and I use H&R Street Sports (+/- $1000) which are higher end coilovers, but a step below K&W and Bilstein, and he H&R are also non stainless steel. But I garage my S5 in the winter. The ST brand coilovers are made by K&W and are nearly identical besides the ST are non-stainless steel. And as you go up, the more configuration options you have, such as damper adjustment, greater height control, etc. I've enjoyed my middle of the road coils for a few years now with no complaints.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Feb 27 2014
    Dubai
    Amount of lowering available on the higher end dampers is usually less than the cheaper options for the R&D reason mentioned above - go too low and you will destroy the geometry and handling of the car. Bilstein and KW would rather a cars handing improved with their product than just allow it to drag its exhaust along the road.
    Damper material is a very valid point but don’t get too wrapped up in stainless, it all depends on the grade of stainless used and it’s chromium content, cheap Chinese low chromium content stainless will suffer from pitting corrosion on the threads unless you keep them greased. The suspension I junked was stainless, it’s the damper inside that stainless shell that makes the difference.
    Doug convinced me
    Established Member Two Rings ChaserBBS's Avatar
    Oct 25 2016
    2010 Corvette ZR1
    Rio Rancho
    i went with ST Coils, ive had them for about a year now and absolutely love them , they ride like a dream. Hard to believe the more expensive brands ride better.
    2014 Ice Silver S5 Black Optics Premium Plus.
    2010 ZR1
    Senior Member Four Rings SuperMex's Avatar
    Aug 09 2014
    Ferrari LaFerrari Aperta
    Florida
    It’s like asking what the difference is between a Kia and an Audi. Sure they’re both cars but one is better quality
    ND | W205 | 997.2
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2013 S5 6MT
    Atlanta, GA
    This is the main issue. The fly by night Chinese companies will put the same damper on any chassis that has a following and demand. They don't specify performance based on motion ratios, spring rates, vehicle/chassis weight distribution, intended use, etc. It's one size fits all, and they make them bolt up. Then they go on to add "36 way adjustable" capability, which just opens up a whole can of worms. Increasing compression stiffness affects rebound stiffness, and vice versa. There's an inherent amount of cross talk between the two, and without knowing what the baseline is, you're just guessing what clicks of a knob will do. Sure you might get relative changes, but as far as actually being able to dial in the package to the vehicle, forget it. Lastly, just look at who will provide you spring rates. If they don't know them, why would you buy their product? Throw in shock/strut shaft size and seal materials, and the real deals quickly separate from the junk. Bilstein inverted monotubes have BIG shafts (~45-50mm diameter on my TT), and can handle full droop, airborne jumps with ease. Cheap, tiny shafts, not so much. This is also an unpublished number most of the time. At the end of the day, you get what you pay for.
    Oct 25 2016
    2010 Corvette ZR1
    Rio Rancho
    every one just needs to go air.
    2010 ZR1
    Aug 17 2017
    Atlanta, GA
    Quote Originally Posted by ChaserBBS View Post
    No thanks.
    May 20 2010
    I like where you're at
    Sep 19 2016
    Roseville, CA
    Definitely gonna be saving up for higher end coilovers now, I was just trying to see if I could get away with saving a little bit of money and using the money I saved on other mods Always great help and info on this forum, as always, thanks a lot guys.
    Oct 25 2016
    2010 Corvette ZR1
    Rio Rancho
    What coils are you considering>?
    2010 ZR1
    Oct 09 2008
    On the street you can probably get away with cheaper coils for awhile. On the track, people blow them out pretty quickly.
    The Awesome™
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    Quote Originally Posted by JoshDub View Post
    what brand(s)/style(s) are considered good for improved handling on the street & acceptable for mild track use maybe 2 - 3 times a year?
    Bill
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    Love my Bilstein B16s (PSS10s)- Ran them hard on a track a few weeks ago and they performed flawlessly. Being able to switch to 'comfort' mode while cruising with the SO is an added bonus.
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2008 Toyota Tundra SR5, bone stock
    Feb 27 2014
    Dubai
    I would personally only go for the two top brands, Bilstein and KW and if you can stretch your budget to the electronically adjustable kit then you really will see a vast improvement in both comfort and handling.
    Doug convinced me
    Oct 09 2008
    Quote Originally Posted by wkhanna View Post
    Bilstein, KW, H&R, and Koni (do they make a kit for the B8?)
    The Awesome™
    Feb 27 2014
    Dubai
    I know this will not be a popular statement so I’m wearing my flame proof jacket- H&R make great springs but I’m not sure their dampers are as good as the leading brands.
    Koni are only rebound adjustable so a compromise although they are good quality.
    Doug convinced me
    May 12 2017
    needs cleaned
    thanks for the input, guys!
    been awhile since i have been modding cars, so was not sure if things have changed much.
    back when i was heavy into performance mods, koni, bilstein & kyb were the popular choices for serious folk....
    Bill
    Avatar Chart
    Feb 27 2014
    Dubai
    I believe KYB own the design for the Audi DRC suspension or at least made the equipment so they know what they are doing for sure. They used to be more for the Japanese car scene but still good stuff non the less.
    Bilstein invented the McPhearson strut (suspension as we know it) so you really can’t go wrong with any of their kits, obviously the more you spend the better and more functions your setup will have.
    Doug convinced me
    Oct 09 2008
    Have you had any negative experiences their H&Rs dampers? I've never heard anything bad, and I felt like their coil over was built well as well as drove great.
    But I also have a set of BC's on our E53 (because the only other option was something like $3k KW's) which I have also been impressed with thus far.
    The Awesome™
    Feb 27 2014
    Dubai
    Only the usual reports on leaks Josh but I’m sure all damper manufactures will have those. H&R usually have a Bilstein B6 insert inside but then they allow you to run them really low, lower than Bilstein themselves would, maybe this causes earlier failure if guys wind them all the way down?
    BC are a nice damper, I know we went through a few months of development on another car forum to get a good spring/damper combo to give good comfort and nice handling. In the end they made a damper with the option for a predominantly road driving or more track orientated driving springs. I believe BC dampers are the same as Apex or at least come from the same factory?
    Doug convinced me
