Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 198
  1. #41
    Sep 25 2017
    Oslo, Norway
    UPDATE:
    Got the EGT-delete set today & put it on the car! Deleted fault codes, took it for a spin
    Straight away the car feels much better! No "sluggish" drive. Great
    BUT! Still hitting boost like crazy (30-50psi according to my app "TORQUE" ) for a fracture of a second when doing "kick down" and WOT. Stabilizes at around 10psi after that all the way until gearshift. (isn`t stock boost between 7-9psi)
    Has anyone logged realtime boost like this before??? Is the app-readings wrong? Where do i go from here? Any suggestions?
    Also the throttle only opens about 85-90% according to the app. Is this normal? Shouldn`t it be 100% ?
    Thanks for all your help guy`s!
    Thomas
  2. #42
    Senior Member Three Rings olethalb's Avatar
    Feb 22 2013
    london ish
    would personally bung a cheapo ebay boost gauge on to compare app accuracy
    Glad the egt sorted the slug problem :)
  3. #43
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by olethalb View Post
    Something like this?
    https://www.bsr-tuning.no/produkt/multicolor_544601
    Is it easy to install/uninstall. Not very keen on having this mounted in my car.
  4. #44
    Nov 24 2015
    Milford, CT
    Your EGT is going to be your problem. I had mine coded out, along with SAI, and a Stage 1 tune. It cost less then replacing the EGTs myself.
    When I got the ECU back the car easily felt like it had an extra 150 horse, because EGTs weren't interfering, and I was getting full boost.
  5. #45
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by kid View Post
    I did change this EGT (delete set) but having some issues with the boost readings being very high at WOT, but only for a fracture of a second.
    Considering stage 2 ( they say that`s 300hp) and that this is no problem for the 2.7 on stock parts. Do you concur to this or is the car too old? Would it be best to leave it be?
    Have you guys tested 0-60? Supposed to be 7-8 seconds I`m more in the top 8`s but do not race the if you know what i mean! Just the occasionally passing some BMW
  6. #46
    Nov 24 2015
    Milford, CT
    I have the 034 stage 1, which they claim is about 315 HP / 345 Ft lbs. I would say I'm in the high 6 second range, but have not tested it yet.
    I do throw a code from time to time for over boost. Never really caused any issues for me.
    I would not trust the torque app for accurate boost. Get yourself a mechanical gauge. As for the throttle, you will never see a car read from 0-100%.
  7. #47
    Sep 25 2017
    Oslo, Norway
    Thank you for the quick response! Is this something you buy as a kit (the 034 stage 1), or do you map the ECU? i`m doing the last one i guess. cost`s about 300$
  8. #48
    Nov 24 2015
    Milford, CT
    You mail them your ECU, and they send it back tuned. It's a "canned" tune, so you are better off if you go to a shop with a dyno.
    https://store.034motorsport.com/perf...olkswagen.html
  9. #49
    Sep 25 2017
    Oslo, Norway
    I think it's the same thing. They "download" ecu software and get an upgraded file in return wich they upload the car... takes about 15-20 minutes.
  10. #50
    Sep 25 2017
    Oslo, Norway
    So.... To update my situation.
    After countless search on google and this forum i've done this so far:
    1. Changed TBB(cracked underneath)
    2. Changed MAF (mass air flow housing with sensor), although my Ohm was right. Noticed no difference.
    3. I've changed the N75-valve, although my Ohm was ok(between 25-35). Noticed no difference
    4. Got an EGT "delete set". After new code: 17861 P-1453-35-10 EGT sensor 1 open/short to b+. This changed the car immideately! No more slug!
    Have not registered any codes after this, but i do not trust the "tourqe" app, so i will do an full vcds scan again anytime soon.
    I'm also gonna check the DV's to see if they work properly and the N249.
    Want to thank you all for help! Much appreciated!
  11. #51
    Oct 02 2013
    05 allroad FBP 6mt, 06 VW Passat Komfort, 08 VW Touareg V8 FSI
    pennsylvania
    Great work Herr! Looks like your persistence is paying off. I would take the opportunity to replace the torn TBB with an upgraded silicone version (Samco, 034, Mishimoto etc...) Fixing that leak should def. yield a noticeable difference as well as eliminate a likely weak spot in the event you add more boost in the future.
    I personally would focus on ironing out all of its current issues as well as bringing maintenance up to date before doing any mods. Your car is already rather bad ass, so making it even better should prove to be a fun task. It depends on what your looking to achieve with the car as TONS of mods are available for the platform ranging from mild to wild. On the mild side, a stg1-2 flash with all of the accompanying mods (upgraded TBB, DV's open downpipes and a free-er breathing exhaust) would prolly put a big smile on your face (for a bit anyways). This can prove a bit of a slippery slope as many can attest because the need/want for MORE is always in the back of your mind. It really just boils down to personal preference and of course $$$$.
    getting her closer to the ground on a sick set of wheels is never a bad idea either, although your wheels your runnin currently are classics. Lookin good man!
  12. #52
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by n8henn View Post
    Thanks again, quite happy with the look, condition and performance as is. BUT, as you say, there is always that feeling of wanting a bit extra. Even though this is a family car packed with children`s seats in the rear
    It`s that once or twice a week when your alone in the car and just want to feel the power unleashed!
    So next up would be the upgraded DV`s i guess: https://www.ecstuning.com/b-assemble.../06a145710nkt/
    On that note, do you know what kind of Ohm the N249 should have or any other way to test it? https://www.ecstuning.com/b-genuine-...49/078906283a/
    What about fuel filter? How often if so do you guy`s replace this? https://www.ecstuning.com/b-genuine-...er/441201511c/
    As for maintenance, i`ve changed oil, oilfilter, spark plugs, air filter, cabin filter, polished and clean inside out. It`s about 99% rust free and has been well taken care of with every service documented! It only has 100K km (62K Miles) on it.
    So i`m not going crazy with tune or apperance, but some adjustments are to be made
    Wheels are classic, 225/40-18" on Conti`s but would be nicer to have them a bit wider, winter rims however is a different chapter Stock 16`s just barely clearing the disc, that`s just wroooong, i know...
    I also have another thread on the P-sensor not working but hasn`t got any response/tip yet. Just goes with a loooong beep every time. Help on that would be great as well, Bentley`s manual is on the christmas list
  13. #53
    Sep 25 2017
    Oslo, Norway
    Tuned (300hp) problem back😠
    Problably got a bit too carried away and went straight for an flash with +50hp. Now the feel of sluggish drive has returned but also the ESP light turns on. Staggering drive and loss of power...
    Also forgot to tell you this, because i didn't think it would matter but: early this year i've had a bit of an accident. Was late for an red light and put my foot down (but not faster than 60-70mph). Road work ahead and going to fast for the circumstances the car "jumped" going over an bump and the bumper actually touched ground... Most on passenger side.
    Now: could this be an speed sensor issue or allignment problem that occured after the impact?? But didn't cause an problem straight away?
  14. #54
    Nov 24 2015
    Milford, CT
    Quote Originally Posted by Herr G View Post
    So...you forgot to mention you did a Dukes of Hazard, and grounded your front bumper? lol
    I would have gotten my alignment checked the next day. However, if the light didn't come on until after the tune, I would check with the tuner.
  15. #55
    Established Member Two Rings Grainreaper's Avatar
    Nov 19 2016
    Lake in the Hills, Illinois
    I've a little tip on those park sensors, they are little sonar sensors that you can actually hear (or feel) operating... I used a screwdriver to check, simply crouch down and place the tip of the screwdriver to the sensor (key on, engine off) and in reverse, wheels chocked/ebrake on put the handle of the screwdriver to your ear to listen to it, you will hear a clicking noise from the sensor if it's good, or nothing if it's dead, my car has two dead sensors, I just need to figure out which version of sensor I have and I will swap them out. I think there are two types of sensor depending on year, I have a 2000 A6 2.7t, ifound the sensor info online at one point but did nothing wth it, now that I'd like to replace the sensors I cannot find the info on which sensors to get
  16. #56
    Sep 25 2017
    Oslo, Norway
    Oooooops... yeah, kinda forgot about it sence the car didn't act any different before/after. And it wasn't really that bad. But yes the car had an impact that was really unnecessary! And because i read another thread on the allignment and speed sensor as well as crank positioner sensor.
    Allignment will be booked tomorrow! Should i ask them to check speed sensor as well?
  17. #57
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by Grainreaper View Post
    I did that, and replaced two. But now i don't hear any working. Could wrong/bad quality sensors make the whole system "crash"?
  18. #58
    Sep 25 2017
    Oslo, Norway
    The esp/traction light has come on 2 times before and 1 time now after the tune. Turning the ignition off/on reset's the light. Also think i've exaggerated limp mode after reading other threads. I can easily drive my car up to 130-40km/h but when WOT the staggering starts... 1 and 2 gear runs very often good, but 3-5 the staggering gets worse! When driven gently i almost don't feel anything... Hope this will tell you something more😉 . Thomas
  19. #59
    Sep 25 2017
    Oslo, Norway
    Can any one tell me where to find allignment specs for my 2004 A6 C5 2.7T?
    And tell me if the speed sensor/ camshaft sensor (same thing?) should be changed at the same time? is it 2 of these? Don`t want to pour money out the window, but if it`s a good decision of course i will do it!
    Workshop could do it this week, and i want to leave a note with the correct settings so they don`t get this wrong
  20. #60
    Nov 19 2016
    I can get you specs today while at work (my bays are next to the alignment rack)
  21. #61
    Sep 25 2017
    Oslo, Norway
    Thank you Mr!
  22. #62
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    Well just guessing won't help, scan the module for codes.
  23. #63
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by blitz2190 View Post
    Scanning vcds will be done tomorrow!, along with the wheel alignment. I`ve only have an OBD Torque app , and no codes are visible! The other codes are listed earlier in this thread.
  24. #64
    Sep 25 2017
    Oslo, Norway
    Back from the workshop
    Workshop called, the car was 99% alligned and no adjustment was necessary. No other fault codes than boost pressure to high again. He recommends to change the MAP sensor. Hopings he`s right.
    200$ for wheel alignment and diagnostic "out the window" But at least i know it`s straight as an arrow
    Should i go for an stock MAP-sensor or one that has higher tolerance for boost pressure? Mine has part.nr: 078 906 051. Can you guide me in the right direction here? Is this the one:
    https://www.ebay.com/itm/Genuine-Pre...lZHY1S&vxp=mtr
    Thomas
  25. #65
    Sep 25 2017
    Oslo, Norway
    Boost gauge
    Hi
    Wich boost gauge do you guys run in your C5 Vent`s? I`m not so sure i want to mount it but i have to do a test so what are my option here?
    Is it like everything else that, quality and price goes hand in hand? Or can i purchase China products for 1/10 of the ECS tuning ones?
    Something like this: https://www.ebay.com/itm/Universal-5....c100005.m2219
    Audidealer wanted 2.900,- NOK (362 $) for the MAP sensor
  26. #66
    Sep 25 2017
    Oslo, Norway
    Have i screwed up???
    CEL came on today. Obd shows P0103
    https://www.obd-codes.com/p0103
    MAF is brand new but i hope i change to the correct one! Is AIP compatible as i have believed or not?? Or does it has to be Hitachi or Bosch. AIP # is 401352563104. NEW MASS AIR FLOW METER SENSOR MAF *FOR S4 A4 A6 3.0L 2.7L
    Looking forward to response. Cheers.
    Thomas
  27. #67
    Jul 31 2014
    NH
    for it to work with the me7 it needs to be a hitachi or bosch (which ever your ecu is programmed for as they are different, being an 04 its almost certainly a hitachi), aftermarket mafs are notorious for not working within the tight specs of the oem units.
  28. #68
    Sep 25 2017
    Oslo, Norway
    Thank you very much for that! Old one is Hitachi. Thought i was doing it right. Ok. Back to start. Is it possible that you can get me an link to the correct one?
  29. #69
    Jul 31 2014
    NH
    I believe this should be the right one
    https://www.ecstuning.com/b-hitachi-...SABEgIKCvD_BwE
  30. #70
    Sep 25 2017
    Oslo, Norway
    Thank you so much! Ordered it now👍 Feel pretty darn stupid too. Note to self. Ask you guys before and not after i try stuff on my own🤣🤣🤣 Thank's again!
  31. #71
    Feb 21 2016
    Colorado
    FWIW, I had a similar issue with my ESP flashing and the TCM cutting throttle on hard pulls in 2nd gear. I recently changed out one of the ABS sensors (right front I think) and the ESP hasn't had any issues since, I don't know if it was related, but seeing your post made me remember and think about it. Mine is bone stock, except for a 6mt swap and I think the shop may have given me like a stage 0+ tune when they programmed my TCM for me. Anywho, the bad ABS sensor ended up throwing a code a few months ago so I finally broke down and fixed it. I also have at least one bad wheel bearing, just a couple things you might want to check out.
    Cheers!
  32. #72
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by brokenwrench View Post
    Cheers!
    Thank you for sharing! Hope changing my poor choice of the wrong MAF from AIP, now will get the problem sorted out as i`m getting the one from Hitachi instead.
  33. #73
    Sep 25 2017
    Oslo, Norway
    New MAF sensor from Hitachi installed.
    So, finally got the correct MAF sensor from Hitachi today and put it straight in. Improved both drive and boost, but from 3-5 gear there is still something wrong. No codes and in 1-2 gear the car goes really fast! So could it be a small boost or vacuume leak that's causing this problem? Even though pressure test allegedly is ok?!
    *Pressure test ok
    *New maf
    *New plugs
    *New N75
    *wheel alignment check
    * EGT plug & play delete set.
    What's next in line?
    Thomas
  34. #74
    Sep 25 2017
    Oslo, Norway
    Hi
    Boost gauge showed up yesterday, will try to get it mounted this weekend. I`m not looking for a permanent fitting so where should i go about placing this and hooking it up?
    Found some different ways via this forum so i think maybe it could just lay in the hatch underneath the steering wheel during testing. Uploading pics later
    Do you have any other suggestions about do`s & dont`s???
    Also now that it`s getting cold ( -10-20 C ) i`ve noticed when i start up in the morning after car has been sitting all night, it sometimes struggles a bit before i touch the gas pedal. (then everything is fine again)
    Still showing no codes after changing to MAF-sensor from Hitachi so that`s good, but in 3-5 gear it wont pull as hard as in 1-2 gear. Feels like it holding back power.
    Have a nice weekend!
    Thomas
  35. #75
    Senior Member Three Rings m_haiser's Avatar
    Apr 24 2011
    Highland Green Allroad
    Oregon Coast
    you have a boost leak somewhere, I promise you. the boost deviation codes prove it. check your waste gate lines
  36. #76
    Sep 25 2017
    Oslo, Norway
    Quote Originally Posted by m_haiser View Post
    Do you recommend a smoke test? I did a pressure test with air earlier but they said it was fine, also In/Hg holds -20-22 at idle. can i assume that vacuumelines are in good shape but that the pressure side of turbo`s are leaking?
    Was supposed to fit the boost guage this weekend but didn`t get the time.
    Sorry for a lot of back and forth on the subject. Thought i had i fix the last time
    Thanks for all your guidance!
  37. #77
    Apr 24 2011
    Oregon Coast
    yeah smoke probably wont tell you anything since smaller leaks only present themselves under pressure. pressure test up to like 25psi.
  38. #78
    Sep 25 2017
    Oslo, Norway
    Thank`s! Will order another pressure test today, maybe they can do it before christmas
    How fast should the pressure drop? Guessing it won`t hold 25psi for a long time when u stop pushing air in?!
    Thomas
  39. #79
    Apr 24 2011
    Oregon Coast
    it should hold pretty well though, I think its like 1 psi drop per minute or something. the main thing you want to do is listen to where the air is escaping from so that you can fix that and your boost leak
  40. #80
    Sep 25 2017
    Oslo, Norway
    Ok. Checked DV's today. They worked fine. Haven't heard from the mechanic yet, hoping they will answer soon...
