Results 1 to 11 of 11
    Established Member Two Rings CronicPAIN's Avatar
    Jun 16 2016
    none
    pennsylvania
    Best Manual Transmission and motor Oil for Winter ?
    hi guys what oil you recommend for this cold winter here in PA so far i found this
    https://www.ecstuning.com/b-assemble.../n10037106kt2/
    https://www.ecstuning.com/b-assemble...g/n10037106kt/
    and for my motor found this
    https://www.ecstuning.com/b-assemble...20tprmoil1kt1/
    my car is Audi a4 2006 2.0t quattro Sline
    Let me know what you guys are using or recommend thanks
    Sep 09 2009
    Minneapolis
    I use redline for the trans and it's stiff in winter.
    I'd go oem, I think fcp euro has it at a good price.
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Sep 30 2009
    08 A4, 87 Jag XJ6, Lex RX300, HD Street Rod, Grumman Yankee AA1A
    Indiana
    I don't think much of RedLine MTL product. I'm sure it's a great lubricant for summer use but takes 20 minutes to warm up to the point where it starts to shift normally in cold weather, longer if it is really cold. I and my buddies have tried any number of MT fluids and have all settled on OEM (expensive) or Pentosin MTF2. If you research it you will find that Pentosin MTF2 is approved for use in many BMW and MB manual trannys. It's far better in the cold than anything else we've tried.
    Regarding the motor oil link you posted, Liqui Moly is an OK motor oil. Many here on the forum use it. But I think it's important for you to know that its HTHS (high temperature high shear) strength, the best test for wear performance, is not that great. I suggest you check out this site and then select a motor oil. https://540ratblog.wordpress.com/201...-test-ranking/
    Nov 15 2011
    A4 B6 Avant | A4 B7 Sedan
    Montreal | I sell in USD
    Items for Sale
    I put Redline in my transmission and regret it. Probably going to try Ravenol soon.
    *****I sell in USD*****
    B6 Avant GTX2863R Motoza Tuned Aka the part hauler
    B7 Sedan Stage II HPFP Aka the retrofitted queen
    Mar 24 2013
    '01 Chevy 2500HD Duramax
    Griswold, CT
    Swapping to AC Delco synchromesh soon. I've heard good things.
    -Adam
    May 09 2012
    08 A4 Avant, 05 Silver S4 2.7t swap
    Virginia
    Items for Sale
    I used Fuchs Titan Sinto in my B5 and continue to use it in both B7's. Good stuff
    Sep 30 2009
    Indiana
    Quote Originally Posted by jbain2 View Post
    Yeah, but you are in Virginia. The OP is asking about cold weather performance, and it can get really cold depending upon where you are in PA. How is the Fuchs at 5 degree F?
    Jun 16 2016
    none
    pennsylvania
    awesome guys thanks for the help i think i will go with oem oil for transmission for motor not sure yet
    Sent from my SM-N920T using Audizine mobile app
    May 09 2012
    Virginia
    Items for Sale
    Quote Originally Posted by Brillo View Post
    True. I lived in Maine and MA for 8 years so I think that qualifies. I don't see 5 in VA, but do see single digits intermittently. There are plenty of folks who run this in cold weather.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2008 Volvo XC90
    Otterburn Park, QC
    Items for Sale
    If it's cold, stay with OEM. I put Motul gear 300 after a lot of search, and i regret it. To hard until tranny reach good temp.
    2006 A4 Avant 2.0t FSI 6spd silver. Owning an Audi is like having a hot girlfriend that's mentally unstable
    Unitronic stage 1+, black/white alcantara Recaro, S4 front brakes, RS4 swaybar, 18" Ruffino Boss, Koni Yellow + eibach, JHM SS, 034 HFC, OBX DP/S4 exhaust, K&N, APR snub mount, S4 door blades, Forge spacer, CIM vent boost gauge, B8 style led headlights with xenarc HID. Retrofit: sirius, menu wiper stalk, RNS-E, oem BT, Recaro to Avant, ski bag
    Senior Member Three Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by CronicPAIN View Post
    Buy it from FCP euro. Cheapest I could find it was there. It was like $15 or so per liter, can't beat that.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
