Results 1 to 3 of 3
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    West Linn, OR
    212 - Snow Performance Stage 2 MAF/MAP Boost Cooler
    Selling this kit that I just haven't had a chance to install. It's still brand new/in the box and ready to ship. $375 shipped and paid as a Paypal Friends and Family.
    Product Description
    The Snow Performance Stage 2 MAF/MAP water-methanol injection kit is designed for all naturally aspirated/forced induction vehicles utilizing a Mass Air Flow (MAF) sensor or Manifold Absolute Pressure (MAP) sensor. The Stage 2 uses a progressive controller that proportionally injects more or less water-methanol according to MAF/MAP input. Start and full points are adjustable for engagement and delivery curve to match what the engine requires. Proportionally injecting according to MAF/MAP sensor input gives an accurate delivery of water-methanol for small fast spooling turbos and positive displacement superchargers that hit boost almost instantly and allows the most accurate injection curve which translates into the highest cooling and performance gains.
    Proven to deliver 20-35 HP and 45 FTLB of torque on all naturally aspirated applications and 50-80 HP increases and up to 150 degree drop in air temps for all positive displacement superchargers and small fast spooling turbos! The Stage 2 comes with a MAFU controller that can be mounted any where in the engine bay or cab for a clean install and comes with the industry leading Snow Performance 300 PSI UHO pump and Hypersonic Nozzles™ for the absolute best atomization and power available for your MAF/MAP equipped vehicle.
    Kit Includes:
    300 PSI UHO (Ultra High Output) Pump
    3 Quart Reservoir
    MAFU Progressive Controller for Use With All MAF/MAP Sensors
    Pig Tail Harness
    All Tubing Necessary for Installation
    10’ ¼ Inch High Temp Nylon Tubing
    3’ (Black) Wire Loom
    Level Switch Upgrade
    1 Nozzle Holder/Check Valve Combo
    3 Hyper-Sonic™ Nozzles (175, 375, 625 ml/min) For Applications up to 1,000 HP (for custom nozzle selection give us a call at 719-633-3811)
    Required Hardware for Install
    Snow Performance Running S Decal
    Comprehensive Instructions to Install on Any Vehicle Utilizing a MAF/MAP Sensor
    Snow Performance 1-Year Warranty
    NOTE: For All Naturally Aspirated/Boosted Vehicles Using a MAF/MAP Sensor
    Jason - 2012 Glacier A4 Avant - Prestige - S-Line - Titanium
    | APR K04 w/APR V3.1 Files | APR Carbonio | BB HFC | AWE 3" DP | EC FMIC & Crank Pulley | CTS CC | GFB DV+ | H&R SS Coilovers & F&R Sways | SPC Adj. UCA's | 034 Rear Diff& Trans Inserts | ECS Skid Plate | S4 Mirrors | B8.5 Euro RS4 FBSW | B8.5 S-Line Shift Knob | B8.5 3G + MMI | B8.5 Clim Cont | Piano MMI Trim | S5 Peelers |
    Mar 27 2006
    Lots of bikes!
    West Linn, OR
    BUMP!
    Mar 27 2006
    Lots of bikes!
    West Linn, OR
