Results 1 to 19 of 19
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    SOLD
    Selling this kit that I just haven't had a chance to install. It's still brand new/in the box and ready to ship. $375 shipped and paid as a Paypal Friends and Family.
    Product Description
    The Snow Performance Stage 2 MAF/MAP water-methanol injection kit is designed for all naturally aspirated/forced induction vehicles utilizing a Mass Air Flow (MAF) sensor or Manifold Absolute Pressure (MAP) sensor. The Stage 2 uses a progressive controller that proportionally injects more or less water-methanol according to MAF/MAP input. Start and full points are adjustable for engagement and delivery curve to match what the engine requires. Proportionally injecting according to MAF/MAP sensor input gives an accurate delivery of water-methanol for small fast spooling turbos and positive displacement superchargers that hit boost almost instantly and allows the most accurate injection curve which translates into the highest cooling and performance gains.
    Proven to deliver 20-35 HP and 45 FTLB of torque on all naturally aspirated applications and 50-80 HP increases and up to 150 degree drop in air temps for all positive displacement superchargers and small fast spooling turbos! The Stage 2 comes with a MAFU controller that can be mounted any where in the engine bay or cab for a clean install and comes with the industry leading Snow Performance 300 PSI UHO pump and Hypersonic Nozzles™ for the absolute best atomization and power available for your MAF/MAP equipped vehicle.
    Kit Includes:
    300 PSI UHO (Ultra High Output) Pump
    3 Quart Reservoir
    MAFU Progressive Controller for Use With All MAF/MAP Sensors
    Pig Tail Harness
    All Tubing Necessary for Installation
    10’ ¼ Inch High Temp Nylon Tubing
    3’ (Black) Wire Loom
    Level Switch Upgrade
    1 Nozzle Holder/Check Valve Combo
    3 Hyper-Sonic™ Nozzles (175, 375, 625 ml/min) For Applications up to 1,000 HP (for custom nozzle selection give us a call at 719-633-3811)
    Required Hardware for Install
    Snow Performance Running S Decal
    Comprehensive Instructions to Install on Any Vehicle Utilizing a MAF/MAP Sensor
    Snow Performance 1-Year Warranty
    NOTE: For All Naturally Aspirated/Boosted Vehicles Using a MAF/MAP Sensor
    Jason - 2012 Glacier A4 Avant - Prestige - S-Line - Titanium
    | APR K04 w/APR V3.1 Files | APR Carbonio | BB HFC | AWE 3" DP | EC FMIC & Crank Pulley | GFB DV+ | H&R SS Coilovers & F&R Sways | SPC Adj. UCA's | 034 Rear Diff& Trans Inserts | ECS Skid Plate | Euro RS4 FBSW w/Extended Paddles | FL S-Line Shift Knob Retro | 3G + MMI Retro | FL Clim Cont Retro |
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    BUMP!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Who wants this? Box was opened to verify contents only; Everything is brand new and all included, as new!
    Make me an offer!
    Established Member Two Rings LionKing's Avatar
    Mar 09 2017
    MD
    Dangit. I just bought an intercooler otherwise I'd be all over this.
    Sent from my Nexus 6P using Audizine mobile app
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    - Modded B8 A4 / RS4 Grille / Carbonio Intake / Silicone Hoses / ECS Intercooler / TM Delete / 034 MS HFC / Forge Wastegate / Forge DV Spacer / S4 Exhaust / APR STG II / Sitting Low On 19 in. Rotors -
    Established Member Two Rings slow_poke25mph's Avatar
    Aug 02 2015
    2011 F150 6.2L, 2016 VW Touareg
    El Paso, Texas
    PM Sent
    Sent from GLaDOS, because there was no cake.
    The Grocery Getter Stage 2 Allroad on bags.... cause milk & diapers. (Soon to be K04ed)
    Instagram: grocery_getter_81
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Quote Originally Posted by LionKing View Post
    This is best used in conjunction with an intercooler, both to cool IAT's further (approx. 20c) and to boost octane (if you want to run a 93 or 100 octane file)!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Open to reasonable offers but come on people... $150 is far from reasonable!
    I paid $380, which was the cheapest I've seen it online.
    Who's got $350?!
    Mar 09 2017
    MD
    Quote Originally Posted by jaycurn View Post
    +1... Wish I had more monayyy!!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Bump!!
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    PM sent.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Still available people... $350 shipped is a smoking deal for a brand new, complete kit!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Bump...
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Weekend bump!!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Monday bump!
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    TTT
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    Anyone??
    Jul 14 2012
    Eastern Shore,MD
    My offer is still on the table
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Items for Sale
    SOLD
