Results 1 to 40 of 41
    Veteran Member Four Rings derek2079's Avatar
    Aug 02 2004
    Missouri
    2001 S4 6 speed stage 3 needs a new clutch
    i hate your car. mine is better. forum\
    May 09 2012
    Virginia
    Location?
    Aug 02 2004
    Missouri
    Hannibal Missouri
    Mar 17 2017
    chicago il
    Did you do the rods too?
    Aug 02 2004
    Missouri
    Block is stock.
    Jul 31 2014
    NH
    Quote Originally Posted by derek2079 View Post
    top to bottom complete rebuild of suspension/ timing belt anything and everything on the car has been done newish oem rs4 clutch kit was not able to handle the power so right now the car shifts when its off but turned on it does not shift from gear to gear.
    thats likely a pressure plate or arm issue. A bad clutch won't prevent going into to gear unless its fused. You probably had the pressure plate bolts back out. its happened quite a bit to others.
    Aug 02 2004
    Missouri
    Well I no longer have the money to fix it.
    Jun 01 2016
    columiba/mo
    Are those horsepower number crank or to the wheel
    Established Member Two Rings dwbunks's Avatar
    Jun 23 2014
    Ottawa
    Quote Originally Posted by blitz2190 View Post
    It most certainly will prevent you from going going into gear with the car on... twice on two different cars for me this past year, neither fused as I had expected as well
    Registered Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    A coupla things:
    1. Intercoolers? Stock ones won't give you 500 horsies with K24 turbos. They probably won't do 400 without blowing off the end caps.
    2. Who did the tunes? You're sayin' lots of them. Generally we only need one but if one's good more should be better.
    3. I'm not sure I would say the compression test you're showing good but buyers can make up their own mind about it.
    4. More pitchers would be good.
    Aug 02 2004
    Missouri
    Quote Originally Posted by rdcyclist View Post
    A coupla things:
    1.So despite what you've heard stock Smic's are pretty darn good.
    2. Not going to mention names but you know who are and if you care to chime in feel free. One I use daily the other would be more or less a track file.
    3.im including the compression test. It's important.
    4. It's sitting inside of my garage with not light. Pictures aren't the easiest thing to take.
    Aug 04 2013
    Pennsylvania
    Stock intercoolers lol
    Maybe good for 250bhp...
    I'm like a tree. I'm all root
    May 09 2012
    Virginia
    Blitz knows the compression test is important. His point was that a cylinder compression of 115 is concerning.
    There is a world of difference between stock and quality aftermarket SMIC's in both cooling and pressure loss.
    Your answer regarding tuning is not helpful. Yes, we know there are many tuning options. I don't know of a tuner who would advocate tuning a car with RS6 framed turbos and stock SMIC's. If you don't know who tuned the car or the specifics of that, it's far more informative for a potential buyer to know that.
    If you expect someone to hand you over $6K, you need better and more pictures as well as refining your listing to be as complete as you can make it.
    Nov 12 2013
    SanHo, CA
    Quote Originally Posted by Mille Bornes View Post
    Nah, they're good for at least 300 as most Stage 2 tunes will get you there with the stock pieces of sh*t. But I'm sure a pair of aftermarket IC's are required for anything more. A friend blew an endcap off when he was fiddling around with an amateur toon. He was pushing 24 pounds into the OEM IC's at the time; mostly just to see what would happen. It was entertaining...
    Nov 12 2013
    SanHo, CA
    Exactly.
    Actually, this might not be a terrible deal but the car is not driveable and getting it from Hannibal to where the buyer lives is going to be either challenging or expensive. To get someone to invest the effort to make it happen is going to require some work on Derek's part.
    Feb 23 2010
    Lehigh Valley
    The little bit of credibility you may had is now gone
    B5 S4- K24s, built bottom end, E85
    B8 S4- GIAC Stage 2
    150cc Chinese Scooter of Doom
    Aug 04 2013
    Pennsylvania
    lol I bet
    I did give them less credit than deserved. I ran them with NVR 2++ for awhile and only upgraded once stage 3 but it's mind boggling to me that someone would do so much work to this car and then leave the stockers in place.
    Aug 02 2004
    Missouri
    Look at the numbers.
    Jun 14 2017
    Mankato, MN
    Miles? "timing belt service" when?
    Aug 02 2004
    Missouri
    173xxx timing belt 168000 have receipt
    Aug 02 2004
    Missouri
    Iím repairing the clutch as we speak.
    Aug 02 2004
    Missouri
    eff u
    Nov 12 2013
    SanHo, CA
    eff u
    That is certainly an effective sales tool.
    Jun 14 2017
    Mankato, MN
    eff u
    no eff u
    Aug 02 2004
    Missouri
    Ok ace
    Established Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    That didnít last long!
    Shame really... you were so stocked to get your Dream Car and now a simple clutch job has you selling.
    You CAN do that job and keep this car.
    Best of luck!
    Established Member Three Rings tate182's Avatar
    Nov 06 2016
    Minnesota
    Quote Originally Posted by JustManson View Post
    Best of luck!
    I can't tell if this guy is a huge troll or really clueless?
    Sent from my SM-G920V using Audizine mobile app
    2001 b5 s4 stock
    Oct 11 2016
    Connecticut
    Heís a Troll... and clueless.
    Itís like hitting the web lotto. Highly entertaining.
    I also mean that in the nicest way possible.. 5000+ posts and been here for 13 years.
    Aug 02 2004
    Missouri
    Youíre correct. Except Iíve grown up now and Iím being stereotyped.
    Oct 11 2016
    Connecticut
    Hahahha!
    Aug 02 2004
    Missouri
    So Iím the old school days of az I as well as others posted clown ass shit to get our post count up. I was only active on the forum from 2004-2007ish
    So yep
    Aug 02 2004
    Missouri
    In a broader sense as Anthony as The Godfather the old school built az from nothing. I actually messaged him about starting a calendar. One of which I own. Along with other Audizine gear. Support Anthony. Support Audizine and intelligent conversation. I did go pretty crazy with my posts but this was over 10-13 years ago when I was 22-24 years old with an 01 A4 stage 3. The amount of pun tang was ludicrous. Think the car was retailing for $27,000 to 32,000 when I bought it at dealerships.
    In other words MySpace days Facebook was new.
    Nov 20 2014
    New York
    So would you take $3500 cash moneys?
    Aug 02 2004
    Missouri
    Quote Originally Posted by sonic32 View Post
    Quit being a stupid ass hat.
    Nov 14 2013
    earth
    ^^^Im pretty sure this guy is Anthony that has been trolling the b5 section with this Derek account for the past year.
    Ive never seen posts as strange as these before and trust me that says a lot.
    Nov 20 2014
    New York
    You quit being stupid asking that much for a non driving car douche 🤷🏼*♂️
    Nov 06 2016
    Minnesota
    Dude are you stupid this thing is a beast
    2001 b5 s4 stock
    Nov 20 2014
    New York
    Quote Originally Posted by tate182 View Post
    A beast that doesnít drive... I think only stupid people here are you an him. It could have Jesus turbos on it and make 799 all wheel godly unicorns if I canít test drive it, itís worth parts.
    Aug 02 2004
    Missouri
    Not my fault you canít afford it. Sonic32
    Oct 11 2016
    Connecticut
    Cut the shit Derek.
    Fix your dam axle!
