Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
  1. #41
    Sep 08 2017
    Riverside, Ca
    Quote Originally Posted by B8_Dude97 View Post
    Don't put anything under 2013 in your car it's just gonna be problems. Get a 2013 and up motor and follow the guides and use the metal manifold
    If you can't wait here's a low mile motor. Try to stay under 45k and look for keywords lkq uses like with turbo
    Here's the motor I found a while ago and it was a steal
    Hey man,
    Will this motor fit my 2009 QUATTRO?
    http://www.ebay.com/itm/2013-Audi-A4...item2cc4a2357b
  2. #42
    Established Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Quote Originally Posted by TheSubGuy View Post
    Hey man,
    Yes plug n play. Doesn't look like turbo is included so youll need to use your original turbo
  3. #43
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    Paid 10 for mine with 89k, engine rebuilt from audi and new turbo right before I bought it. You mad bro. lol
    bruh...Cold blooded
  4. #44
    Established Member Two Rings rolandoa1324's Avatar
    Jan 28 2016
    Orange CA
    True. Although you'd definitely need to remove the stock transmission and use a supra one and remove quattro just to move it farther back and not make it not plow like a cow with that extra 200 sitting even further up front.
    Cool driftcar project though and first b8 rwd
    Personally id go 4.0 v8 TT if your doing something crazy
    The best v8 to get would be LS or Coyote that would be really crazy
  5. #45
    Senior Member Two Rings DoItAllGarage's Avatar
    Oct 29 2013
    Pacific NorthWest
    I put a 2013 engine almost 3 years ago in my b8 a4. Took a ton of research and Elsa was a big help! I still have my b8 a4 and drive it daily. Here is a link to get you started http://lovetodiyandmore.com/page8.php?category=19
    Almost forgot, if you buy a used engine always do a compression check and a leak down test for extra insurance before you install it, you would hate pay someone to install the engine and have to pull it back out Bec the used engine had problems, plus lkq and most salvage yards will replace them, if you call them within the first day or two of receiving it.
  6. #46
    Sep 08 2017
    Riverside, Ca
    Okay. I'm trying to decide which mechanic to go with. 1 mechanic is charging $3200 for the motor and $1500 for labor plus cost of other small items. See attachment.
    This mechanic is saying that he knows about LKQ but they are just pulled from cars at junkyard while his motors are pulled and then work is done to them before he gets them. He says this is what is done - Timing chain fixed.
    Rebuild cylinder head
    Carbon clean , ports brand new
    Replaced stem seals
    Replaced timing chain tensioner
    On the other hand, this other mechanic will just plug & play the motor that I buy from LKQ. The labor costing $1000 and motor costing $2500. He will add the small items listed in first mechanics invoice if they need to be replaced.
    What do you guys think? Will the motor from LKQ be fine as is, or should I pay more and get one from this mechanic and pay extra for him to work on it? I want to do this proper.
  7. #47
    Established Member Three Rings Spawne32's Avatar
    Nov 20 2016
    waste of money IMO
  8. #48
    Sep 08 2017
    Riverside, Ca
    waste of money IMO
    Why do you say that
  9. #49
    Sep 05 2016
    Antioch, California
    waste of money IMO
    Replaced stem seals
    4seasons is a great vw/Audi tuning shop but here's the thing. You don't need a vw/Audi specialist to do this swap. If your not mechanically inclined enough yourself your local mechanic can do this swap(so the second mechanic sounds imo better. Lkq is just pulling motors but I don't see the need to replace water pump on a 35k-45k motor unless it's leaking or not working
    Same goes for rebuilding the head? Why unless there's something wrong with it but on a 35k-45k motor?
    Seems like stuff you do if you got money to blow.
    Timing chain fixed? All 2013 and up motors have the fixed versions of tensioners and I doubt the chain is stretched at that mileage. Have mechanic replace with latest revision though since motor is out
    However I would recommend the carbon cleaning and replacing any seals that look bad since the motor is right there also I'd reccomend a rear main seal upgrade to future proof that. Don't get oem get the beefier aftermarket tsi one.
    Go with cheaper mechanic or do it yourself
  10. #50
    Sep 08 2017
    Riverside, Ca
    Got it.
    Thanks!!!!
  11. #51
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    The guy who sold it to me owns a private car dealership in Las Vegas called RUSH HOUR MOTORS and NO EXCUSES LIFESTYLE. ]
    Is the owner a 9 year old boy? Who would trust a business with such a ridiculous name?
    CEO and General Manager of the AZ Pedal Responce Team
  12. #52
    Active Member Two Rings Zingrox's Avatar
    Sep 03 2016
    Pennsylvania
    How much would a 2010 a4 with 100k miles and a blown engine be worth? Automatic transmission, Quattro, black leather interior, everything in good condition. As an estimate, of course
  13. #53
    Apr 01 2011
    B5 on jack stands
    charlotte
    Replaced stem seals
    This is all pointless BS unless he can provide some kind of warranty in writing for so called improvements.
    MODS
    Things'n stuff
  14. #54
    Sep 05 2016
    Antioch, California
    Idk about worth but considering blue book on one not blown at that mileage is 9-10. I would pay no more than 4.5-5.5k realistically do I could do a swap and still maintain value to resell
    Quote Originally Posted by demonmk2 View Post
    Not really bs. 4seasons is a great shop but they are offering a motor swap plus work that will prevent anything failing right after a swap. Not bullshit just unneeded extras
  15. #55
    Aug 16 2017
    Las Vegas
    Sent from my SAMSUNG-SM-G530AZ using Audizine mobile app
  16. #56
    Nov 20 2016
    Why do you say that
    because you can buy an 09 that runs for around the same price they quoted for the repair, car isnt worth that much to warrant dumping that much into it. You can never make that money back.
  17. #57
    May 27 2017
    San Francisco
    Quote Originally Posted by Dethmachine View Post
    I don't think you can tell a guy who just blew up an automatic A4 to buy a 2JZ, convert it to single turbo, and call it a day. I think his very long days and nights would just be starting. Via just a quick search, I couldn't even find any 2JZ swapped B8's.
    Keep it simple, if you are going to rebuild this unfortunate loss. Value/worth/etc are all up to the owner and are all offset by how deep his pockets run.
    Not only that, OP is in CA, can't legally swap a 2JZ into a B8.
  18. #58
    Sep 05 2016
    Antioch, California
    Quote Originally Posted by tommyz2kool View Post
    Anyone swapping a 2jz isn't worried about legality more then power. Hence many 2jz swaps rolling In ca in a lexus
  19. #59
    Aug 07 2015
    Pittsburgh
    Nobody guna touch on that American V8 nonsense? Coyotes and LS's in a B8? I can't tell of they're just trolling anymore or what...
