Results 1 to 10 of 10
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    :: EuropaParts.com :: 034Motorsport NEW PRODUCTS!
    Our 034Motorsport catalog is updated and live!
    P34 COLD AIR INTAKE, B9 AUDI A4/ALLROAD & A5 2.0 TFSI
    034Motorsport P34 Cold Air Intake System. Delivers improved power, sound, and acceleration to B9 Audi A4 / allroad & A5 owners in a clean OEM+ package.
    Through extensive evaluation of the factory airbox design, 034Motorsport's engineers were able to create a performance replacement that allows for increased airflow to the turbocharger and engine. The P34 Air Intake System offers measurable performance improvements, simple bolt-on installation, and unsurpassed fit and finish.
    Throughout the development process, multiple designs were modeled, prototyped, and tested - all to ensure that the P34 Cold Air Intake System delivers measurable performance benefits and superb fitment. The result is a partially-enclosed airbox which uses the factory fresh air inlet duct and heat shield, while housing a massive 5" inlet conical air filter, and a CNC-machined billet aluminum velocity stack feeding a reinforced silicone turbo inlet pipe.
    FEATURES:
    • Developed In-House by 034Motorsport's Engineering Team
    • Dyno-Proven Horsepower & Torque Gains
    • Increased Airflow to Turbocharger Inlet
    • Enhanced Engine & Induction Sounds
    • Improved Throttle Response
    • Superb Fit & Finish to Match Factory Engine Bay
    • Stealthy OEM+ Design Utilizes Factory Inlet & Heat Shield
    • Massive 5" Inlet Conical Air Filter
    • CNC-Machined Billet Aluminum Velocity Stack
    • Large-Diameter CFD-Optimized Turbo Inlet Hose
    • Securely Installs Using Factory Mounting Grommets
    • Simple, Straightforward Installation Instructions
    DYNO-PROVED PERFORMANCE GAINS:
    The P34 Cold Air Intake System for B9 Audi A4 / alroad & A5 was engineered with performance in mind, and is a free-flowing replacement for the factory airbox and turbocharger inlet hose. As the fruition of this design approach, the P34 Cold Air Intake System yields a measurable reduction in pressure drop at the turbo inlet compared to the factory airbox, with a corresponding increase in horsepower and torque throughout the powerband.
    Stock Intake: 253 Horsepower / 270 Foot-Pounds of Torque
    P34 Intake: 262 Horsepower / 274 Foot-Pounds of Torque
    Peak Horsepower Gain: 10 HP @ 6,100 RPM
    Peak Torque Gain: 8 FT-LBS @ 6,100 RPM
    Stock Intake: Peak Pressure Drop of 0.58 PSI at 6,300 RPM
    P34 Intake: Peak Pressure Drop of 0.10 PSI at 6,300 RPM
    COMPATIBLE VEHICLES:
    • 2017+ Audi A4 B9 2.0T
    • 2017+ Audi allroad B9 2.0T
    • 2018+ Audi A5 B9 2.0T
    Please Note: Not for use on emissions-controlled vehicles in California.
    BUY 034MOTORSPORT P34 COLD AIR INTAKE ONLINE NOW
    034MOTORSPORT DYNAMIC+ ADJUSTABLE REAR SWAY BAR, B9 AUDI A4/S4, A5/S5, ALLROAD
    The 034Motorsport Dynamic+ Adjustable Rear Sway Bar is made from a single piece of high-quality, 22.2mm thick spring steel for maximum rigidity, and is designed to combat understeer while reducing body roll under hard cornering.
    This product was tested thoroughly on the street and track on 034Motorsport's in-house B9 Audi A4 Development Vehicle before release. The 034Motorsport Dynamic+ Adjustable Rear Sway Bar substantially reduces understeer and body roll on B9 Audi A4/S4, A5/S5, and Allroad vehicles without compromising comfort on the street.
    In addition, the 034Motorsport Dynamic+ Rear Sway Bar is engineered to be used effectively with the stock front sway bar, and maintains factory levels of comfort and driveability. No upgrade in the front is required with this rear sway bar. The addition of a stiffer front bar can positively affect turn-in feel, but ultimately worsens the platform's tendency to understeer. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is substantially reduced, while turn in and off throttle oversteer are greatly improved.
    FEATURES:
    • Improved Vehicle Dynamics & Handling Feel
    • Reduced Body Roll
    • Decreased Understeer
    • 2-Way Adjustable - 173% to 210% Increased Sway Bar Rate (Over Factory "Sport" 18.5mm Hollow Rear Sway Bar)
    • One-Piece 22.2mm Diameter Solid Spring Steel Construction
    • Direct Bolt-On Upgrade
    • Designed for Use with Factory Front Sway Bar
    WHAT'S INCLUDED:
    • 034Motorsport Dynamic+ Adjustable Rear Sway Bar
    • Billet Aluminum Sway Bar Brackets with Integrated Zerk Fittings (Pair)
    • Polyurethane Sway Bar Bushings (Pair)
    • Sway Bar Bushing Backing Plates (Pair)
    • M8x30mm Allen Bolts (Set of 4)
    • Zinc Coated M8 Washers (Set of 4)
    • Super Lube Sway Bar Bushing Lubricant
    • Installation Instructions
    FITMENT:
    • 2017-Present Audi A4 B9
    • 2018-Present Audi S4 B9
    • 2018-Present Audi A5 B9
    • 2018-Present Audi S5 B9
    • 2017-Present Audi allroad B9
    BUY 034MOTORSPORT DYNAMIC+ ADJUSTABLE REAR SWAY BAR ONLINE NOW
    DYNAMIC+ LOWERING SPRINGS FOR B9 AUDI A4/ALLROAD
    034Motorsport Dynamic+ Lowering Springs for 2017+ Audi A4 & allroad B9. Dynamic+ Lowering Springs were engineered and tested in-house at 034Motorsport to deliver superb ride quality and optimal handling performance. Designed to as a true no-compromise solution, Dynamic+ Lowering Springs provide an aggressive yet functional stance, and reward drivers with precise vehicle control and OEM+ comfort levels.
    Dynamic+ Lowering Springs were thoroughly evaluated on the street and track on 034Motorsport's B9 Audi A4 Development Vehicle, and by independent Audi enthusiasts before release. The selected spring rates, unique dual-rate spring design, and ride height are the culmination of months testing - thousands of miles of commuting and countless track days - resulting in a lowering kit that is perfectly matched to the factory dampers.
    Each set of Dynamic+ Lowering Springs is manufactured in the USA at an ISO 9001 certified facility, and tested to 034Motorsport's exacting specifications to ensure they deliver unmatched levels of handling performance. These springs are the ideal suspension solution for the discerning Audi A4 and allroad owner who desires to lower their vehicle and enhance their driving experience.
    FEATURES:
    • Improved Handling Performance & Chassis Dynamics
    • Reduced Body Roll & Understeer
    • Superb Comfort & Ride Quality
    • Compatible with Audi Adaptive Suspension
    • Lightweight, High-Strength Construction
    • Shot Peened & Powdercoated
    • Made in USA at ISO 9001 Certified Facility
    RIDE HEIGHT:
    B9 Audi A4 Base Suspension
    • Front - 2.0" Lower
    • Rear - 2.0" Lower
    B9 Audi A4 Sport Suspension
    • Front - 1.1" Lower
    • Rear - 1.1" Lower
    B9 Audi allroad Suspension
    • Front - 2.2" Lower
    • Rear - 2.0" Lower
    EFFECTIVE SPRING RATES:
    • Front - 380 Pounds/Inch (Linear)
    • Rear - 490 Pounds/Inch (Linear)
    FITMENT:
    • 2017-2018 Audi A4 B9
    • 2017-2018 Audi allroad B9
    Please Note: Compatible with Base, Sport Package-equipped, and Audi Adaptive Suspension-equipped models. We strongly recommend trimming the front bump stops by 10mm on Base Suspension A4s and allroads.
    BUY 034MOTORSPORT DYNAMIC+ LOWERING SPRINGS ONLINE NOW
    RES-X RESONATOR DELETE, B9 AUDI A4/A5 & ALLROAD
    The 034Motorsport Res-X Resonator Delete unleashes a throaty growl that exudes the sound of performance and warns bystanders that this isn't your average 4-cylinder. The new aggressive exhaust note is accomplished by removing the heavy factory resonator and replacing it with a ready-to-install 034Motorsport Res-X Resonator Delete.
    No welding required! This is a true bolt-in exhaust upgrade that eliminates the quiet factory resonator for a deeper exhaust growl.
    Enjoy a more aggressive exhaust note with no noticeable drone inside the cabin at a fraction of the cost of more expensive cat-back systems.
    FEATURES:
    • 304 Stainless Steel Construction
    • Deeper, Aggressive Exhaust Note
    • No Added Drone Inside Cabin
    • Lighter Than Factory Resonator
    WHAT'S INCLUDED:
    • 034Motorsport Res-X Resonator Delete
    • Two (2) Exhaust Clamps for Bolt-In Installation
    FITMENT:
    • 2017-Present Audi A4 2.0T B9
    • 2017-Present Audi allroad 2.0T B9
    • 2018-Present Audi A5 2.0T B9 (Coupe and Sportback)
    BUY 034MOTORSPORT RES-X RESONATOR DELETE ONLINE NOW
    034MOTORSPORT FRONT STRUT BRACE, B9 AUDI A4/S4, A5/S5, ALLROAD, BILLET ALUMINUM
    034Motorsport billet aluminum front strut brace. The factory Audi strut brace is made of thin stamped aluminum, allowing for lateral deflection of the strut towers and chassis flex under hard cornering. This deflection can be observed as imprecise steering input and a vague, disconnected feeling from the front end.
    The 034Motorsport Strut Brace replaces the flimsy individual factory braces to improve the B9 A4's steering feel and handling performance. This robust chassis reinforcement is machined from T6-6061 billet aluminum, and engineered to be a comprehensive upgrade by limiting lateral strut tower deflection and maintaining proper suspension geometry under heavy cornering. The incorporated center brace ties together both left and right strut tower to provide precise, consistent feedback from the front end and ensures that you enjoy a more connected driving experience.
    This strut brace was thoroughly tested by 034Motorsport on an in-house B9 Audi A4 Development Vehicle before release. Installation is very simple, can be performed in minutes, and is completely reversible.
    FEATURES:
    • Engineered to Enhance Handling Dynamics and Performance
    • Improves Steering Feel, Consistency, and Precision
    • Bolt-On Upgrade for Factory Front Strut Braces - Easy, Straightforward Installation!
    • T6-6061 Billet Aluminum Construction with Clear Anodized Finish
    WHAT'S INCLUDED:
    • 034Motorsport Billet Aluminum Front Strut Brace Chassis Reinforcement
    • M8 Mounting Screws (Set of 4)
    FITMENT:
    BUY 034MOTORSPORT FRONT STRUT BRACE ONLINE NOW
    034MOTORSPORT TRANSMISSION MOUNT INSERT, B9 AUDI A4/S4, A5/S5, ALLROAD, BILLET ALUMINUM
    034Motorsport billet aluminum transmission mount insert. The factory Audi transmission mount has a large void in the rubber damping medium, which results in excessive transmission movement under load. This movement results in drivetrain slop than can be observed when accelerating, decelerating, and shifting.
    This billet aluminum insert is designed to fill the large void in the factory transmission mount, and limit transmission movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the void in the factory mount, this insert eliminates the associated slop and ensures that you're experiencing crisper shifts and a smoother driving experience.
    This mount was thoroughly tested on 034Motorsport's in-house B9 Audi A4 Development Vehicle, and independent Audi enthusiasts before release. Installation is very simple, can be performed in minutes, and is completely reversible.
    FEATURES:
    • CNC-Machined In-House
    • Clear Anodized Finish for Durability
    • Engineered to Fill Void In Factory Transmission Mount
    • Drastically Reduces Transmission Movement During Shifting & Deceleration
    • Improves Shifting Feel, Resulting in Crisper Shifts
    • Will Not Cause Additional NVH Transfer Inside Cabin
    • Fits All Transmissions
    • Easy, Straightforward Installation Takes Minutes!
    FITMENT:
    BUY 034MOTORSPORT TRANSMISSION MOUNT INSERT ONLINE NOW
    BILLET ALUMINUM REAR SUBFRAME MOUNT INSERT KIT, B9 AUDI A4/S4/A5 & ALLROAD
    034Motorsport billet aluminum rear subframe mount insert kit. The B9 chassis models use rubber rear subframe mounts which deflect under load, causing the rear end to feel vague and loose, as well as leading to less-than-optimal suspension geometry and increased understeer. These precision-machined billet aluminum inserts are designed to fill voids in the factory rear subframe mounts, and limit subframe movement without sacrificing ride quality or introducing any perceivable additional noise, vibration, or harshness into the cabin. The result is a more refined, connected driving experience, as well as improved effectiveness of aftermarket rear sway bar upgrades and suspension components.
    Designed to work in conjunction with the factory rubber mounts, this insert package was engineered using CAD software and thoroughly tested and refined to provide a significant improvement in handling performance and feel.
    These inserts were tested extensively on 034Motorsport's in-house B9 Audi A4 Development Vehicle before release. Installation is very simple and is completely reversible.
    FEATURES:
    • Engineered to Fill Voids In Factory Rear Subframe Mounts
    • Helps Maintain Proper Suspension Geometry When Cornering
    • Reduces Rear Subframe Movement During Launches & Acceleration
    • Virtually No Additional NVH Transfer Inside Cabin
    What's Included:
    • 034Motorsport Billet Aluminum B9 Audi A4 Rear Subframe Insert - Front (Pair)
    • 034Motorsport Billet Aluminum B9 Audi A4 Rear Subframe Insert - Rear (Pair)
    Fitment:
    Please Note: The four factory rear subframe bolts can be reused at the torque specified in the Installation Guide. If you wish to purchase new stretch factory hardware, you will need QTY: 2 of N91228001 and QTY: 2 WHT004756A.
    BUY 034MOTORSPORT REAR SUBFRAME MOUNT INSERT KIT ONLINE NOW
    Hubert
    EuropaParts.com, Your Trusted Audi Parts Source
    Phone: 800.877.7033 x 101
    Email: hubert@europaparts.com
    Facebook: Like Us on Facebook
    Aug 22 2010
    Piscataway, NJ
    In stock and ready to ship... check out the maps below to see how long it would take to receive your parts from EuropaParts!
    FedEx
    UPS
    Hubert
    Aug 22 2010
    Piscataway, NJ
    Hubert
    Senior Member Three Rings Nikoman's Avatar
    Feb 04 2008
    2015 Jeep Grand Cherokee
    Chicago, IL
    Bump. Great mods!
    2017 A4 Premium Plus Mythos Black + Sport + Cold Weather
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Nikoman View Post
    Bump. Great mods!
    Thank you!
    Hubert
    Sep 21 2017
    Lil Rhody
    Any chance you have 034 intake in stock for b9? Also any deals on intake?
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Ap12Scooby2A4 View Post
    Both intakes are currently in stock and ship same day!
    Hubert
    Sep 21 2017
    Lil Rhody
    Is the filter for the 034 intake a dry filter or oiled filter?
    Aug 22 2010
    Piscataway, NJ
    I believe it's a dry filter...
    Hubert
    Aug 22 2010
    Piscataway, NJ
    FedEx
    UPS
    Hubert
