Results 1 to 40 of 47
    Senior Member Three Rings V70R's Avatar
    Feb 14 2015
    PDX, OR
    B5 01X and 02X Conversion Thread
    Been working on this over my Summer break with a lot of help from Blake (A1 and A2 German) and we have made quite a bit of progress.
    Brief introduction for those who may not be familiar with these transmissions, the 01X is the transmission found in 2005-08 Fronttrak A4's, while the 02X is found in 2004-08 Quattro A4's. One of the primary advantages to 01X and 02X transmissions are the gear ratios; seen below, gear ratios generously favor smaller displacement engines regardless of modifications or turbocharger size, and feature a 6th gear that is great for cruising down the highway while keeping engine RPMs low. For example, 80mph in my '05 Ultrasport Avant is approximately 3200 RPMs.
    I will be converting my 2001.5 Avant with a GJW 02X transmission removed from a 2004 A4. Since the GJW has the 4.11:1 final drive, I sourced a tiptronic rear differential to match the transmission.
    Driveshaft: for quattro vehicles, a tiptronic driveshaft appears to be a drop-in solution. The 02X and 01V transmissions have an identical length (35.5'') and the same flange dimensions. I will be installing mine this week to confirm.
    Axles: After installing the 02X, I did a test fit with the stock '04 axles and both fit without modifications.
    Clutch and flywheel: 012/01A share the same spline dimensions as 01X/02X. I will be running a Valeo single mass conversion for right now.
    VSS single will be acquired from a digital GPS unit (cannot remember brand, model etc.) with minimal modifications to the engine harness. Since there are no provisions on 01X and 02X cases for side mounting brackets, an AWE Tuning Drivetrain Stabilizer will be adapted and incorporate the transmission mount.
    Gear chart:
    Shift box install...
    Comparison; 02X transmission shown on top, 01A below:
    Shift linkage assemblies; 02X linkage on left, 01A linkage right:
    Comparison of B6 shift box (bottom) to B5 shift box (top). 02X shift linkage and shifter (bottom) can be directly transferred to a B5 selector box by removing the two 6mm allen fasteners attaching linkage to the shifter and 4-T25 torx screws:
    Ready to install, B5 selector box with B6 shifter and 02X linkage:
    Box installed and bolted to trans without any modifications, shown in first gear:
    More to come! Tomorrow I will load the gifs that compare shift throw between the old 5spd 01A and 6spd 02X.
    Xlite w/ 11spd Campy Record- 2005 Dolphin Grey Ultrasport Avant 6MT-- 2001.5 Light Silver Metallic Avant 5MT w/ Sludge Package --1979 Scout II
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    This looks very promising, in for updates!
    Sent from my ZTE A2017G using Audizine mobile app
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Jun 30 2008
    Erie, Pennsylvania
    10/10. A+. Would thread again.
    I considered the 02X when I was doing my 5-speed swap. But they were pretty expensive then and I had no idea that a tiptronic driveshaft would work. For a swap, that means you don't need to anything with the rear diff OR driveshaft. The mounting and VSS would be the largest hurdles, then.
    I'm interested in details on the front axles. I've heard the B6 axles are longer due to wider front track. Persons that, for instance, used a B5 donor to 5MT swap a B6 ran into problems with axles that were too short. I'm curious to see if you have any issues in that area.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Apr 01 2011
    B5 on jack stands
    charlotte
    Are the newer transmissions stronger than the 01A's?
    MODS
    Things'n stuff
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Reserved: Will re-fill with info later
    This is for B5 Fronttraks who are interested in swapping from the weak oem 5 speed, to a ~modern stronger 6 speed, being an A4 B7 2.0T 6 Speed Transmission Code : GVT
    Using B6 and/or B7 front axles, regaurdless of being from a B6/B7 Fronttrack or Quattro donar car, will fit a B7 GVT transmission and should slide right into B5 hubs perfectly (this will be confirmed shortly).
    Parts Needed:
    #1) A4 B7 GVT transmission
    #2) A4 B7 front axles (or B6 axles)
    #3) A4 B7 shift linkage (using your exsisting B5 shift box)
    #4) Aftermarket Speed Sensor Unit
    #5) AWE lower billet brace
    Things to consider, about:
    #4) Aftermarket Speed Sensor Unit: The B7 GVT trans has no VSS like the B5. There are a couple ways to tie into the B5 female VSS Bosch plug to send a single to the dash to get a working speedo:
    - Dakota Digital system which ties into your abs speed sensor
    - Dakota Digital system which you mount magnets on to an axle and use a ~hall type sensor to read the spin.
    - Dakota Digital system using simply gps.
    #5) AWE lower billet brace: The GVT trans has no side trans mounting brackets like a B5, a B7 uses a factory lower brace with a transmission mount. We are working on mocking a B5 AWE billet lower brace to the oem B7 trans bracket to secure it.
    Having a bucket that runs 10's is like saying you have a 200lb girlfriend but she's good in bed.
    Feb 12 2004
    DG 2004.5 A4 1.8T USP
    Austin, Texas
    Subscribing, as a 1.8T B6 owner with an 02X transmission. Good luck!
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Apr 01 2011
    B5 on jack stands
    charlotte
    Quote Originally Posted by demonmk2 View Post
    More specific the 3rd gear
    MODS
    Things'n stuff
    Mar 05 2013
    Earth
    Quote Originally Posted by K-1
    Diff to 4:1 why not
    Feb 14 2015
    PDX, OR
    Exactly, an auto to manual conversion candidate would be perfect for an 02X. I spent a few days recording dimensions of various Audi products at local wrecking yards and was really surprised when I measured the overall length of an 01V, as I feel the biggest hurdle for an 02X setup in a B5 was the driveshaft. I pulled the 02X back out today with the motor to install new parts; I will compare axle lengths and transmission dimensions to see how much wider things are. B5 shafts with B6 inner CVs may be an option if we have an issue.
    Edit- 4:1 differential mod I think would be awesome for this setup
    Established Member Two Rings thrilos5's Avatar
    Feb 03 2009
    Greece
    Subsribed
    Established Member Two Rings Gbomer's Avatar
    Mar 04 2010
    Sydney, Australia
    any updates from the weekend ?
    99 A4 1.8TQ
    Handling
    KW V3's | Hotchkies Front and Rear Sways | Brembo BBK |
    Power
    Comp Turbo CT3-5356 0.63 A/R, Billet - ETT | Haltech PS1000 | Piper Ultimate Road Cams | Scat Rods | JE Pistons | Supertech Valve Set | IE Springs Set | Full Race Ex Mani | Custom Enlarged Intake Mani | 1000cc Inj | Zietronix Flex Fuel Sensor | Treadstone TR18 FMIC
    Feb 14 2015
    PDX, OR
    Yep! I'll post everything in the next 24hrs and get all the numbers crunched.
    Minor update- B5 slave does work with the 01X/02X.
    Mar 04 2010
    Sydney, Australia
    so she's all buttoned up and running ?
    99 A4 1.8TQ
    Handling
    Power
    Senior Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant
    San Diego, CA
    If I have a 99 pre-facelift 1.8T B5 will the axles still fit the hubs or would I need the steering knuckles from a V6 or 01.5 model?
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/Kmac/17" Enkei/Bridgestone Potenza
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    S4-RS4 look bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    Jun 30 2008
    Erie, Pennsylvania
    You could probably just swap your smaller joints onto the 02X axles.
    Feb 28 2005
    Tempe
    Quote Originally Posted by b5v6 View Post
    This will be confirmed shortly in person :
    A) Pre-Face '97 A4 B5 1.8T (Note it's Fronttrak: However it's only the bearing/hub/spline size that matters, aka, as long as my bearing/hub/spline size is the same as your quattro). As far as we see on paper, B7/B6 axles slide right in.
    B) As stated before regaurding axles, B6 vs B7, Frontrack vs Quattro, are all the same axles. Please note, however they are all the same, there is a difference between the right and left length, by ~2" or so (which is dumb IMO, as they could of extended the trans case or axle cup out that much more to make them identical). So you'll have to source a drivers and passenger side for the front from a B6/B7.
    Feb 14 2015
    PDX, OR
    Alright, sorry for my delay getting this all the data compiled as school has been out of control already.
    After measuring all of the axles compressed that I had (6 in total), I found my measurements to be fairly accurate to OE specs regarding axle length. An 02X with stock B6/B7 axles is approximately 2.38mm wider overall when compared to the stock 01A with B5 axles; a difference of 1.19mm per axle. We'll give this a shot and see how things work.
    Apologies for my small-ass handwriting.
    Nov 02 2008
    01 Passat 4Mo Wagon 1.8T 6sp swap,. 05 Golf
    Grapevine,TX.
    It would be easier to use the V6 or later 1.8T steering knuckles. I don't know if the axle shafts are the same diameter. The bearings/hubs/splines are not the same.
    2001 B5 Passat Wagon, 4Motion, 6sp manual and 1.8T swap. H+R Race from an A6Q, Konis, Custom 6pt strut bar, A8 front brakes. Coming soon: TT exhaust, Hotchkis 35mm S4 front and RS6 rear sway bars, FMIC, 240mm stage 2 clutch.
    2005 Golf 2.Slow.
    2001 B5 Passat V6 Wagon, FWD Tiptronic.
    2001.5 B5.5 Passat V6 5sp sedan.
    Former: 91 SHO, 83 5000S Turbo, 78 Supra, 86 Golf, 69 Chevelle SS, 2 Taurus wagons.
    Nov 03 2011
    B6 Avant 420-R
    Kampala, Uganda
    Unfortunately, this doesn't work, Walky. The spline count of the shafts are different.
    His:
    Hers:
    Jun 30 2008
    Erie, Pennsylvania
    Good to know. Thank you for the correction.
    Quote Originally Posted by V70R View Post
    Are you measurements with the axles fully compressed, fully extended, or just "at rest"?
    Feb 14 2015
    PDX, OR
    Axles were measured fully compressed. I removed the axle bolts and compressed the outer CV and stood each axle vertically to record their overall length. If I remember correctly I took three measurements of each axle on two different days, one of my old B5 axles had a bad boot and was prohibiting an accurate reading.
    Also- I took into consideration regarding The mating surface for each transmission's flanges. 01A CV joints are recessed approximately 3mm for each flange. Trying to keep things consistent and yield accurate measurements for width comparison of each transmission and their axles.
    Mar 04 2010
    Sydney, Australia
    Any updates?
    Sent from my SM-G900I using Tapatalk
    99 A4 1.8TQ
    Handling
    Power
    Feb 28 2005
    Tempe
    Update
    I'm in a position to install my clutch to the block, bolt the B7 trans to the block and crane it in basically now (I could do it Wed or Thursday)
    I have not done so as involvded in another build and primarly, hesitent on craning in the entire assembly by myself. Considering I just did a full engine bay shave along with a minty fresh newly sprayed tubular subframe, and the B7 trans was sandblasted and coated too (aka, need to prevent paint scuffs and scratches).
    Update on fitting in axles:
    Axles do not fit (axle splines) do not fit my prefacelift hubs. I will be recieving facelift hubs (full uprights) uprights from V70R and should be good to go.
    Please note in preface: There might be the possibilty of swaping out the bearing and hub from a facelift into your preface so the B7 axles can slide in.
    Feb 14 2015
    PDX, OR
    Hot damn I am slacking. Alright,so I tossed in the drivetrain today for mockup to test things out and see if this will work, and things look pretty good. I have no clue where I put the new CV joint, so I could not completely bolt it up the driveshaft; as a positive, it allowed for myself to compare the overall length and it's perfect. Sorry for the poor images. I'll snag some better images this Friday after midterms.
    Feb 28 2005
    Tempe
    Update
    - B7 A4 2.0 6 Speed transmission has been successfully mounted to a 1.8T 06A block and installed into the car .
    - Facelift Uprights have been installed on my pre-face B5 to except the large B7 axle splines .
    - B7 A4 2.0 axles slipped right in and bolted 100% up and spin freely, no binding, and see no issues .
    - B7 shift rods are utilized, and bolt directly to the B5 shift box .
    - B5 transmission tunnel excepts the much larger B7 trans with no issues, see no issues with shifting, excepts B5 slave cylinder.
    - Thee only finilzation and modifcation required to complete the swap are transmission mount brackets, which will bolt to the B7 tran bungs and use the stock B5 pick up points on the subframe which need to be fabricated and will look something like this: http://www.motorgeek.com/viewtopic.php?p=401700
    Senior Member Four Rings Mattr567's Avatar
    Mar 20 2016
    Excited for this!!!
    Nice seeing more fronttrack content on this forum.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    The most base A4 in the world
    99.0 B5 A4 1.8TMS
    APR 91 | Forge | APR Catback | Valeo SMF | Bilstein Sports | Eibach | Neuspeed RSB | B5 S4 TRE's | 034 Snub | OEM Strut Bar | Ebay SS w/ Pushdown Delete | 2.0T Coils
    BBS | Podi | DDM HID | OEM RS4 Grille | Euro Mirrors | Facelift stuff | Sport Cloths | Euro Trunk | Valeo E Code
    Jun 30 2008
    Erie, Pennsylvania
    Cool. This is cool stuff. Thanks for posting.
    How are the 2nd gear synchros in these 01X/02X jobbers? 01A 2nd gear synchro leaves much to be desired.
    Oct 24 2013
    girls MK4 1.8t
    United States
    How are the 2nd gear synchros in these 01X/02X jobbers? 01A leaves much to be desired.
    FTFU
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
    Feb 28 2005
    Tempe
    "All high horsepower modified Fronttrak B7's report here"
    I had that thread running for a ~year in the B7 forums, not one single tuner or build reported in, nor could I find one FT build. I did this to gauge the trans and whether I should cryo-dip the guts and see what the breaking point was on 01X GVT's. With all the revisions Audi does, I would bank that they resolved these issues...also see the "wider gear" set upgrade they did which prevents sheared teeth.
    And I go from a 5 speed to a 6 speed
    Feb 14 2015
    PDX, OR
    Ben- It's been a long time since I can remember a 2nd gear synchronizer issue with an 01X/02X trans and I have probably driven at least 40+ examples over the years. I've driven my B6 in winter with cold starts around 30* F and it can be slightly notchy for your first few 1-2 shifts, but it quickly goes away. For comparison I am fairly used to double-clutching 01A transaxles in anything below 40* F for the first few miles, and I think this can be attributed to the synchronizer design in 01X/02X trans. I pulled my motor and trans today and subframe, should have mounts made for Blake and I by the end of the weekend.
    Jun 30 2008
    Erie, Pennsylvania
    ^Indeed. I've got ~350k miles on a 1991 01A box (installed in my B5). That darn cold shifting into 2nd takes some skill. #DoubleClutch4Life
    Feb 14 2015
    PDX, OR
    Haha, that's exactly how my B5 was with less than 115k miles; quickly nicknamed it the Deautsch four-on-the-floor aka syncrokiller.
    Alright, mount brackets to yield the factory puck mounts to an 01X/02X will be delivered this week. I will probably revise this and design a loop to brace everything in together. Might make trans mount changes down the road a pain, but it will be very secured to the subframe and chassis.
    Teaser for fun- B6 crossmember was notched and installed, but only the two main subframe bolts fit on each side. Makes a good template, though!
    Oct 29 2005
    10speed
    San Francisco, CA
    Can you run a DTS style bar like the B5s normally do? Also, what are you doing for speedo?
    - Clint
    Current: 05 B5.5 Passat 4motion 1.8T
    Totaled: 04 DG B6 Cabby 1.8T - stock forever
    Gone: White '04 S4 2.7T - Stage 2+
    Gone : 05 DG B7 2.0TQ - Stage 1
    Feb 28 2005
    Tempe
    Yes, I'm running an AWE DTS bar, Tyler is running a notched B6 oem DTS.
    AWE looks far more trick and far smaller in volume
    cutting down on clutter however, only has B5 provisions/hardware for a B5 trans and a mount system will have to be fabricated to union the 01X B7 oem trans mount to the B5 AWE DTS bar. If you clearance an oem B6/B7 oem dts to fit, it'll also fit the 01X B6/B7 mount (complete bolt on). However the notch will have to be boxed in (welded) as takes too much material out of the B6 dts to run with out welding.
    AWE DTS: More money and trans mount needs to be made, a bracket could be made with most likely no welding.
    vs
    B6/B7 DTS: Cheap if not free, needs to notched, and boxed in via welding, however no dts mount system will need to be fabricated.
    We will most likely use Dakota GPS speed modules. They do offer an ~abs tap in unit/speed sensor tap in unit....however figured why cut/hack/and create more wiring when you can get a free standing gps unit and most likely be far cleaner.
    Mar 20 2016
    Quote Originally Posted by A1 A2 German View Post
    I continued this thread onto Tyler's conversion thread. I've already done the swap, now onto doing all the coolant lines, harness, etc so I can start it.
    Thought i'd move this over to the right thread.
    As I said theres the perfect donor car in my local yard. They charge about $130-160 for a trans, and $25 per axle shaft. I feel like its the wrong time for me right now but im pretty sure thats a good deal?
    I would also need facelift uprights as im PFL.
    Other question: What clutch setups are you guys using? I have a Valeo SMF right now, but idk if that would work with the B7 trans...
    99.0 B5 A4 1.8TMS
    Feb 14 2015
    PDX, OR
    holy crap I am slacking on this. Once deadweek and all the labs conclude and my last final on Tuesday this project will be my #1 priority.
    Matt- buy it. Buy it all. That's a rediculously cheap price and would be well worth it. My B5 S4 is going to be parted out, so if you want the uprights for cheap you could have them.
    As for clutch, your existing Valeo setup will work with the 01X, along with your slave cylinder too. I'll be running a TTV flywheel and B7 RS4 clutch.
    Mar 20 2016
    Pretty sure im gonna go for it!
    One other question: So I would use my B5 shift box AND shifter right? I would simply bolt up the B7 linkage to the B5 box and be done. I have a short shifter right now that I would like to keep. No push down reverse (facelift).
    I just dont have quite all the tools and expertise to pull everything I'll try to get some help.
    99.0 B5 A4 1.8TMS
    Feb 14 2015
    PDX, OR
    So you will use the B5 shift skeleton(black assembly that is secured to the car via 4 fasteners; see first post) and the shifter and linkage from the B7. The reverse on the 6spd is down and over, so your shifter wouldn't swap over. I'll say this, though- you'll find that the shift throws are much shorter as there's about a 37% reduction in throw compared to the 01A, and is much more precise too.
    Edit- perfect! Learning on a car that isn't yours, and if something goes wrong...oops
    You could probably support the engine with the mobile cranes they have at the yards, disconnect the linkage and then remove the trans crossmember (would lower the subframe to get the bottom trans bolts). I think you could probably have it out in a few hours.
    Mar 20 2016
    Ah I see. Idk what SS options are with B7's but JHM probably makes one. The eBay one I have is also very good.
    My friend said I should just drop the whole front subframe and unbolt everything on the ground. No one cares about junkyard hoses and random harnesses
    99.0 B5 A4 1.8TMS
    Mar 20 2016
    So some bad news. I went to the junkyard today to get some stuff and scope out the B7, the damage is a lot worse than I thought. The accident didn't seem to penetrate much from the outside, but the force did. The whole DTS is cracked and the car won't shift into 1, 3, 5 or R. Bent shift fork perhaps from the force of the wreck?
    One of the shift linkages looks to be disconnected/missing however?
    Axle shafts ok but a little beat up.
    Also, the car is in the more expensive part of the yard with newer model cars, about 22% more expensive compared to the normal yard. This isn't looking good, I think I'll just throw some JHM linkage in my B5 box and it'll be alright
    99.0 B5 A4 1.8TMS
