Results 1 to 26 of 26
    Dec 19 2014
    Salt Lake City
    Engine stand: How have you done it (4.2 V8)?
    Hey all!
    I have a 4.2 I'm working on for a replacement swap in my B7 S4. I'm finding that mounting that motor on a stand to work on the back side (and hopefully rotate it to work on the pan) is a bit tricky. I'm used to "standard" engine that seem designed to be on a Harbor Freight stand in someone's garage some day : )
    I have this one loosely set up on the stand using the cast holes in the cyl. heads (and supported from the ceiling with straps until I have it dialed in), but I'm thinking there must be a better way.
    What have you all done or seen done that works well? Ideally I'd like to be able to get to the bottom end as well, using the same setup.
    Veteran Member Three Rings badger.'s Avatar
    Mar 31 2014
    '05 S4 Sedan | '05 S4 Avant | '01 Lexus IS300
    KY
    Here is what I did. I added cross bracing immediately after this pic to connect each stand:
    '05 S4 Sedan Arctic White: JHM Intake Spacers | JHM ATF Cooler | JHM Auto-tensioner | 034 Motor Mounts | Apikol Snub | Slotted & Dimpled Rotors | AQ1200D w/Dual 10" CVRs | 35% Tint | Piggies | Fast Intentions Catback
    '05 S4 Avant Brilliant Red: JHM Tune | JHM v1 Headers | JHM LWCP | JHM Ported IM| JHM ATF Cooler | Koni Yellows | Apikol Rear Diff & Snub | Thor Skid Plate | JHM LW Rotors | Fast Intentions Catback
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    In my build thread in my signature
    Dec 19 2014
    Salt Lake City
    Thanks all!
    Keep 'em coming! I like Badger's setup, especially with the trans attached. I'm doing motor first (donor), then pulling the motor/trans that are in the car now. I like the metal/square tube stand too, but alas I have no welder on site.... and I have to keep things relatively mobile in the "bunker". Various bikes, furniture and other largish items seem always be going in and out.
    Going to check q_dubz setup now, and I'll post whatever I come up with too.
    Cheers! [beer]
    May 18 2012
    2005 S4
    Portland, OR
    The engine block has 4 M12 holes on the front designed for an engine stand. Not the greatest photo, but this is what mine is on right now.
    Senior Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    anyone know if a harbor freight engine hoist will hold the V8 and trans or is that too much for a harbor freight hoist? Not trying to thread jack, just figured this would be a good place to ask that question before I attempt and possibly break stuff.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by lyates1987 View Post
    I wouldn't attempt it with both the engine and trans, that is a lot of weight cantilevered off the end and, while Harbor Freight does have some good products, their engine stands that I have seen (not to say that they are all like this, but just the ones I've seen) are not rugged enough for that. It would really suck to have that drop off and crack your trans housing/break the oil sump and whatever else.
    I actually had just my engine without trans on a flimsier stand than the one in my photo above and it was sagging really alarmingly so I used that beefier one instead (has 4 wheels instead of 3)
    Senior Member Three Rings roboto_1337's Avatar
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    I found this very effective... the smaller pallets help when getting your cherry picker in place.
    Note the various sized 4x4s used to stabilize the weight.
    Hehhehe....
    Piggy Pipes, Milltek non-res cat-back exhaust, JHM 93 Tune, JHM Short Throw Shifter, Updated RS4 upper and lower timing guides, Brembo 18Z w/RS4 SS lines, Hotchkiss RS4 Front Anti-sway bars, BC racing BR coilovers, EB-Works adjustable rear end links, 034 Motorsports spherical end links. 034 Motorsport Engine mounts, 034 Motorsports Silicon MAF hose, Hartmann 19" RS4 Reps +5mm 42DD front +10mm ECS rear.
    Sep 17 2014
    Lakeway
    Quote Originally Posted by 924Carrera View Post
    I was asking about a harbor freight HOIST, not a stand, i'd never attempt to put an engine with a trans connected on a stand, doesn't seem like it'd be able to stand it lol
    May 18 2012
    2005 S4
    Portland, OR
    Oh, I totally misread that, my mistake. What is the Harbor Freight hoist rated at for weight? I would think that it shouldn't be a huge problem.
    Mar 31 2014
    KY
    Quote Originally Posted by roboto_1337 View Post
    Hehhehe....
    I always thought just setting it down like that would crush the oil pan??? Or is that a non-issue? Seems risky but I haven't pulled very many engines myself..
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Quote Originally Posted by badger. View Post
    I used the 4x4 to support on either side of the oil pan. I never put it down on the pan itself
    Nov 20 2016
    michigan
    I used an old tire to set the engine on to work on it. Worked great for me. Used some blocks of wood underneath to get it on different angles to make it easier to work on
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    If you look closely at my pic you can see the two oil soaked 4x4s that run parallel with the crank
    May 18 2012
    2005 S4
    Portland, OR
    Blocks of wood do work well if you don't have access to an engine stand. However, if you need to do upper oil pan removal, the stand really comes in handy because you can just flip the engine over.
    Dec 19 2014
    Salt Lake City
    I know a local that has used the Harbor Freight hoist (one of the less expensive ones) to pull the engine/trans combo. It seemed to work fine. He rigged some kind of furniture dolly-based roller to put under the trans to move the whole thing around.
    Thanks for the pic of the motor on the stand! Definitely beefier than the one I have, but in looking at how you mounted it up, I have the arms on mine configured a bit different. I'll re-set them and see if it helps. I'll post a pic, if I don't end up trapped under the motor in my garage : )
    Sep 17 2014
    Lakeway
    I believe it's rated at 1 ton, I'm pretty sure it would work but it's harbor freight so you never know if it will only work once.
    Nov 12 2015
    Oregon
    I've used a harbor freight cherry picker many times with no issues
    Sent from my SM-G550T1 using Audizine mobile app
    My build log
    Sep 17 2014
    Lakeway
    That's what I'm talkin bout!
    Established Member Two Rings MG15's Avatar
    May 05 2015
    east coast
    I've been meaning to make a thread on my build, but I've been crazy busy ever since completion. This is what I did for mine. I Mcguyver'd the crap out of this. I found random planks from an unused shed and built them to fit the tire skates I had. I wanted the portability since I was working in a tight spot. Held strong and did the job lol.
    May 05 2015
    east coast
    May 05 2015
    east coast
    May 05 2015
    east coast
    May 05 2015
    east coast
    I built the stand in about 1 hr. I wasn't going for looks, but more so for strength and sturdiness (although it doesn't look it). I also had access to a hoist which was quite useful since I pulled and re installed the motor myself. Definitely would ask for assistance next time around.
    Established Member Two Rings Mike50design's Avatar
    Feb 17 2017
    Mission/BC/Canada
    I used some scrap steel brackets that were being thrown out at work to build two stands that picked up either motor mount at the M8 bolt:
    When the tranny was mounted, I used my jack to keep it level. I would have built another stand had it not only been for a few hours to redress the motor before putting it back in the car.
