Results 1 to 19 of 19
    Senior Member Three Rings Dondbg's Avatar
    Mar 12 2016
    MB w203
    New Zealand
    Transmission mount replacement approach
    Hey Guys.
    Next weekend my new transmission mounts for my B7 will arrive, it's 2.0T with tip trans.
    I had a look today and been reading around here in AZ and I didn't find a diy but it looks like a straight forward job, I want someone have done this to correct me if the steps below are wrong.
    I see there is a mention to use epoxy on the top bolt to hold it in place, not sure why? Why not to remove be bracket all together while supporting the transmission?
    Here are the steps and I will be taking
    Before staring the below I will support the transmission with a floor jack, piece of wood will be used.
    Step 1 : undo those four
    Step 2:
    Step3:
    Then replace the mount and put everything back.
    Will that work ?
    Comment please.
    I want to get it done fast and right with no surprises.
    Thanks in advance.
    Don.
    B7 2.0TQ Avant '08
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Ive never remove the bracket. Just unbolt the mount, jack underneath and slide the old out and new in.
    Sent from my SM-N920P using Tapatalk
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by bigblue View Post
    Do you know the torque specs by any chance ?
    B7 2.0TQ Avant '08
    Mar 12 2016
    MB w203
    New Zealand
    So it's easier than I thought ... :)
    Thanks.
    B7 2.0TQ Avant '08
    Aug 14 2017
    Queens NY
    The driver side looks easy but the passenger side looks like its more involved. Is dropping the frame necessary to get the passenger side mount out ?
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I always just snuck them out
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Step 3 is the only step plus a jack
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by Luis_Heineken View Post
    Edit....
    You mean 1&3plus a jack.
    Do you know the torque specs ?
    B7 2.0TQ Avant '08
    May 28 2012
    [QUOTE=Dondbg;12612721]Edit....
    no, sorry
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by Dondbg View Post
    Edit....
    B7 2.0TQ Avant '08
    I think he meant just step 3 the top bolt and remove the mount should slide right out.
    Sent from my SM-G925T using Audizine mobile app
    Ivan
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by dalmation53 View Post
    By looking at the mount ,1&3 needs to be undone
    B7 2.0TQ Avant '08
    Nov 01 2016
    2013 S4, 2008 A4 Avant, 1997 PSD F350
    San Diego CA
    Did you have a chance to complete the installation? I have to do this project as well....curious about the process....
    Also, where did you get your transmission mounts? If you don't mind me asking....
    Thank you
    Feb 10 2012
    parts
    Napanee, ON
    For torque specs you can search the bolt size. I have the Info you need but I'm away from home for a few day as.
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by canadianA4B7 View Post
    I got it and the mounts are replaced. Thanks!
