Results 1 to 7 of 7
    May 24 2017
    los angeles
    Q5 burning oil post piston ring replacement
    Ill try and keep this brief. I own a 2012 Q5 2.0 PP with approx 115000 miles The month I paid it off (last dec) the car began burning oil at a very fast rate. My car was just over the extended warranty I purchased also. When I took in the car for a small recall they informed me there was another recall. Some valve don't remember what its called but I knew through research of the oil burning it was part of the oil consumption test. I hoped it would fix the problem to no avail. Was informed they couldn't do anything. Spoke with everyone until I reached the GM. I explained and had to be THAT costumer you don't want to talk too. The GM spoke with Audi corp and agreed to do and pay for the oil consumption test. It failed. They agreed to replace the pistons and rings at no cost to me which I was very grateful BUT it did not fix the problem. My wife has since driven 5000 miles and is on her third top off. She is burning approx 1100 miles per qt. I just emailed the corp rep helping me and informed them the problem was not fixed. Their work has 12000 or 1 yr warranty. Standing by to hear what the next step is. Sounds like this problem extends into the 2012 2.0s and not just the 2011 and older.
    Does anyone have this issue? Also wondering what the next step will be.
    Active Member Two Rings BierJager's Avatar
    Apr 28 2017
    Three Rivers Michigan
    I don't have your year or engine but I would say they possibly misdiagnosed the rings as being the problem and the next step will be whatever Audi service diagnostic procedure recommends. They will determine next step. A leak down / compression test sounds wise.
    The valve you speak of sounds potentially like something related to the PCV system - a PCV valve. I plugged or defective one can allow crankcase pressure to build and force oil places you don't want it. This becomes particularly problematic in power adder cars with worn rings.
    Assuming the ring and cylinder hone job was done correctly, cylinder head and things like valve stem seals seems like the next place to look.
    I am however far from an Audi motor guru so take that with a grain of salt.
    Maybe somebody else with more 2.0 motor rebuild experience can chime in here.
    May 24 2017
    los angeles
    Thnx for the reply. You are correct it was the PCV they replaced. Today my wife went to top off for the third time. It burned 1 qt in 1400 miles. The audi corp rep told us to make a diagnostic appt and from what it sounded like to my wife possibly another oil consumption test. The manager at the dealership was very helpful with my wife and under his breath said that they might have to change the engine block or possibly the engine. Of course depending on what they find. thnx again
    Mar 18 2013
    States
    if I were you I would trade in if the problem not fixed. basially the piston ring replacement/engine block replacement will reduce the resale value dramatically.
    Apr 28 2017
    Quote Originally Posted by lucio_liu View Post
    If it's not fixed, definitely the resale is shot because anybody running a carfax will see all this work and ask WTF is going on with it.
    I bet they can figure it out.
    May 24 2017
    los angeles
    So audi is doing another oil consumption test at no cost to me. So far it doesn't look like it'll pass. It's been 600 miles and the mmi is showing a drop. Have to wait until the light goes off to return it for part 2. Really hope they fix this and not leave me with a car thats resale value is shot.
    Sep 23 2016
    California
    Quote Originally Posted by coolwat3r79 View Post
    Curious which dealer you are working with. Sounds like you are dealing with a pretty good service department. I'm also in SoCal and trying which dealership I want to start using for all my service work.
    TIA
