Results 1 to 19 of 19
    Established Member Two Rings a4ced's Avatar
    Mar 07 2016
    Lehigh Valley PA
    Fault code help P1068
    Hey guys just bought a 2009 S5 V8 and having some trouble figuring out some codes. I know some are just from LED lighting in the car, but the following are of concern:
    P1068
    P1571
    P0196
    P1373
    After some research I've determined I need a ignition service kit from ECS and 034 Density Mounts.
    However the air intake N335 issue and oil temp sensor issue don't seem to have many answers.
    Anyone have some insight on what needs replacing/checking?
    Here's the car by the way:
    Mar 07 2016
    Lehigh Valley PA
    Anyone ever deal with these before?
    Senior Member Three Rings Jeff V.'s Avatar
    Dec 30 2014
    2008 S5 6MT
    Kansas City, MO
    Quote Originally Posted by a4ced
    Do you have a stock airbox? The N335 valve is on the bottom. If it's gone, or just not plugged in all the way, that'll throw the code.
    I can't even find the G8 oil temp sensor on the factory schematics. Does your app have a way to show the VW code for that rather than the OBD code? I'm wondering if the description is wrong or something. The schematics show the "oil level thermal sensor" as G266. It's on the bottom of the oil pan. Maybe the sensor or the harness got damaged?
    Most of the rest of the stuff looks like conseqences of mods like the LEDs and facelift. The fuel cap error means the locking solenoid is busted. My car has the same codes. I need to go order a replacement.
    Mar 07 2016
    Lehigh Valley PA
    Quote Originally Posted by Jeff V. View Post
    I do have the stock air box, I'll check that in a little bit thats good to know. Unfortunately no, there is no way to see the VW specific code. I'm going to buy a VCDS soon though because I think its really worth having for this car. The fuel cap code comes and goes but it works fine so I'm just kind of ignoring that.
    Mar 07 2016
    Lehigh Valley PA
    Where does the plug for the n335 originate? I can't seem to find it at all
    Dec 30 2014
    2008 S5 6MT
    Kansas City, MO
    I think the harness runs along the passenger side frame rail, and then that specific plug branches across to the bottom of the airbox.
    If you reach underneath the front corner of the airbox, you should feel a corrugated tube, and right near that is the electrical connector.
    If you peel back the wheel well liner, you should be able to see it all. Popping out the fog light grille might work too.
    Mar 07 2016
    Lehigh Valley PA
    I did mange to find it but when I connected it and started the car it looks like several things blew on a relay or fuse
    ESP, Parking break and mass air flow errors all occured
    Where would I find the relay? And how much of a difference would it make If I just removed the intake box completely and went short ram? This seems like a silly set up.
    Dec 30 2014
    2008 S5 6MT
    Kansas City, MO
    Your car is cursed. That's weird as hell. The The ESP, parking brake and MAF aren't even on the same circuit.
    That valve opens a 2nd flap in the airbox when the engine is over 5000rpm or your speed is over 155mph. I can't imagine it'd cause that much of a power loss to just leave it disconnected. I think you'll suffer more by having an open element sucking in hot engine bay air.
    Veteran Member Three Rings Porschephd's Avatar
    Jul 11 2012
    2009 S5, 1994 911 Turbo,
    Lenexa, KS
    Did you unplug the MAF and if so are you sure you got the plug seated? An unplugged MAF will send those errors out as the software is interconnected with those functions. So it shuts them all down.
    2009 S5
    1994 911 3.6 Turbo AWD
    Mar 07 2016
    Lehigh Valley PA
    Quote Originally Posted by Porschephd View Post
    I am positive, once I disconnected the n335 again and cleared codes evertyhing went back to normal. The second flap looks like it should have a vaccum line going to it or something but does not. Just got my VCDS from europaparts, going to investigate further
    Mar 07 2016
    Lehigh Valley PA
    I really want everything to work on this car so I guess I'm going on an electrical hunt lol
    Mar 07 2016
    Lehigh Valley PA
    Finally took the next step in being able to do some diagnostics myself, here is a full auto scan. All of this seems pretty individual or at least I cant find the connection.
    Friday,11,August,2017,20:50:21:17709
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    VIN: WAURV78T69A014151 License Plate: KLL-1615
    Mileage: 133240km-82791mi Repair Order:
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42
    46 47 52 53 55 56 65 67 6C 77
    VIN: WAURV78T69A014151 Mileage: 133240km-82791miles
    01-Engine -- Status: Malfunction 1010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    65-Tire Pressure -- Status: Malfunction 0010
    67-Voice Control -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
    Part No SW: 8T0 907 560 N HW: 8T0 907 560
    Component: 4.2l V8/4V H10 0002
    Revision: 76H10---
    Coding: 01140009190F0120
    Shop #: WSC 40832 444 52613
    VCID: 45D4594565A5B4FF28C-8010
    6 Faults Found:
    004200 - Intake Air Switch-Over Valve (N335)
    P1068 - 004 - Open Circuit
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:29:56
    Freeze Frame:
    RPM: 187 /min
    Load: 100.0 %
    Speed: 0.0 km/h
    Temperature: 46.0C
    Temperature: 30.0C
    Absolute Pres.: 960.0 mbar
    Voltage: 10.541 V
    005489 - Left Engine Mount Solenoid Valve (N144)
    P1571 - 001 - Short to Plus
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:29:56
    Freeze Frame:
    RPM: 187 /min
    Load: 100.0 %
    Speed: 0.0 km/h
    Temperature: 46.0C
    Temperature: 30.0C
    Voltage: 10.541 V
    000406 - Engine Oil Temp. Sensor (G8)
    P0196 - 004 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 132506 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:53:14
    Freeze Frame:
    RPM: 2031 /min
    Load: 83.9 %
    Speed: 45.0 km/h
    Temperature: 75.0C
    Temperature: 28.0C
    Voltage: 14.224 V
    008217 - Intake Manifold Flap Position Sensor (Bank 2)
    P2019 - 002 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 132818 km
    Time Indication: 0
    Date: 2017.08.08
    Time: 16:20:27
    Freeze Frame:
    RPM: 775 /min
    Load: 32.1 %
    Speed: 4.0 km/h
    Temperature: 103.0C
    Temperature: 50.0C
    Absolute Pres.: 970.0 mbar
    Voltage: 13.843 V
    006481 - Radiator Fan 2 (V177)
    P1951 - 002 - Movement Restricted / Jammed - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 133009 km
    Time Indication: 0
    Date: 2017.08.11
    Time: 13:20:15
    Freeze Frame:
    RPM: 2296 /min
    Load: 43.5 %
    Speed: 114.0 km/h
    Temperature: 90.0C
    Temperature: 32.0C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.589 V
    006480 - Radiator Fan (V7)
    P1950 - 002 - Movement Restricted / Jammed - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 133204 km
    Time Indication: 0
    Date: 2017.08.11
    Time: 15:26:21
    Freeze Frame:
    RPM: 1008 /min
    Load: 23.5 %
    Speed: 8.0 km/h
    Temperature: 105.0C
    Temperature: 50.0C
    Voltage: 14.351 V
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
    Part No SW: 8K0 927 158 B HW: 0B6 927 156
    Component: 0B6 42 FSIUSA H04 0040
    Revision: --H04---
    Coding: 001002
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMAL651 A01004
    ROD: EV_TCMAL651.rod
    VCID: 3534298535C5247FB8C-8060
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 120500
    VCID: 79ACE5B559DD001F1C4-802C
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
    Component: BCM2 1.1 H71 0134
    Revision: 00002001
    Coding: 0D0000
    VCID: 75B4E98575C5647F78C-8020
    Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
    Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
    Component: MEM-BFS H09 0043
    Revision: AA000000 Serial number: 00001001122120
    Coding: 00017025002C00000000
    VCID: 42DE4259748B83C70DE-8016
    Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
    Part No SW: 8T0 035 729 M HW: 4E0 035 729 A
    Component: Interfacebox H43 4610
    Revision: 00000000 Serial number: 340HS087509660
    Coding: 0025003
    Shop #: WSC 06342 000 00000
    VCID: 43D0475D67918ACF068-8016
    Subsystem 1 - Part No: 8T0 919 609 D
    Component: E0380 BedienteilH08 0100
    Subsystem 2 - Serial number: 00000000124149
    Subsystem 3 - Serial number: 0129.07.080000000100010480
    Subsystem 4 - Serial number: 010480
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
    Component: KLIMA 3 ZONEN H06 0140
    Revision: C1000000 Serial number: 0131.07.081470
    Coding: 48022000
    VCID: 72BED29904AB73475DE-8026
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H22 0253
    Revision: 05022001 Serial number: 00000000199102
    Coding: 260090350638AF010000000300003D3D4F1C53880001016100 0000
    Shop #: WSC 40832 444 59566
    VCID: 303A1891CA270157EBA-8064
    Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 080808 H13 0040
    Serial number: SWFBIE 0000014
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10216247
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
    Component: E1 - LDS H07 0070
    Serial number: 00000000002907080883
    Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
    Component: UGDO HL US H04 0060
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
    Component: MP3-Changer H43 0390
    Revision: 00043003 Serial number: AUZ5ZBH8533987
    Shop #: WSC 00000 000 00000
    VCID: 2A0E0AF9E0FB7B8725E-807E
    Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
    Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
    Component: SDAR SIRIUS H07 0160
    Revision: 00000000 Serial number: AUZ4Z7H0382731
    Coding: 0000100
    VCID: 313C1D95CD2D085FE44-8064
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:29:23
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 D HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0020
    Revision: 11001001 Serial number: 52930821910079
    Coding: 200102
    VCID: 3A2E3AB91C5BCB0755E-806E
    Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
    Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0039GD12D74P
    Coding: 303333333730303030304A55304C38543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_A02.rod
    VCID: 3D2431A50DF5FC3F70C-8068
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
    Component: BF-Gewichtss. H01 0050
    Serial number: 5810000R0800000Z8B
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME6B3061033
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME3E13323DG
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME620518267
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME0806330EC
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME35032B04R
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME3853040AX
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H13 0013
    Revision: -------- Serial number: 90315HH7000F7
    Coding: 000036
    VCID: 3D2431A50D75FC3F70C-8068
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 981 E HW: 8T0 920 981 E
    Component: KOMBIINSTR. H30 0224
    Revision: 00000000 Serial number: 9D9775488
    Coding: 831F01000B00D705020000
    VCID: 3E2636A90073E727696-806A
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0092
    Revision: FB402044 Serial number: 4400F0872681DE
    Coding: 000303
    VCID: 4ACE6A794CBB5B87C5E-801E
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    Serial number: 180359D9280708
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 132881 km
    Time Indication: 0
    Date: 2017.08.08
    Time: 21:19:36
    Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
    Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
    Component: SG ext.Player H15 0850
    Revision: 00000000
    Coding: 020000
    VCID: 2B000FFDE301628FDE8-807E
    Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
    Component: MEM-FS H09 0043
    Revision: AA000000 Serial number: 00001001121955
    Coding: 00197B25002C00000000
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
    Component: MNS US H51 1100
    Revision: 00000000 Serial number: 341GI087511504
    Shop #: WSC 40832 444 58812
    VCID: 382A20B12E57D917A3A-806C
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0050
    Revision: 00H01000 Serial number: --------------
    Coding: 0000004
    VCID: 36362E8924432F67B16-8062
    Subsystem 1 - Part No: 8K0 907 568 B
    Component: J0770_SWA_Slave_H01 0050
    Subsystem 2 - Serial number: 6PZ 009 014-33
    Subsystem 3 - Serial number: 5F08.08.0800H010003CD10523
    Subsystem 4 - Serial number: D10523
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 HW: 8K0 959 793
    Component: TSG FA H09 0149
    Revision: Serial number: U
    Coding: 011C13224E002201
    VCID: 7DA4F1A54DF53C3F30C-8028
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0113486813
    Coding: 0106069A007A4405003000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0040
    Serial number: 00000000000000055477
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
    Component: J245EE16SKB10 H01 0180
    Serial number: 0123456789ABCDEFGHIJ
    4 Faults Found:
    02616 - Fuel Tank Cap; Unlock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:34:36
    01519 - Bulb for Back-Up Lights; Right (M17)
    012 - Electrical Fault in Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:51:25
    01518 - Bulb for Back-Up Lights; Left (M16)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:51:25
    02615 - Fuel Tank Cap; Lock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 132522 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 17:08:49
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
    Component: DSP Prem H14 0400
    Revision: 00H14003 Serial number: 34814002533601
    Coding: 030101
    Shop #: WSC 12336 024 394758
    VCID: 3FD84BAD0779EE2F620-806A
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 HW: 8K0 959 792
    Component: TSG BF H09 0149
    Revision: Serial number: GU
    VCID: 7CA2FCA156EF3537072-8028
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
    Component: EPB Audi B8 H05 0060
    Revision: 00000003 Serial number: 00000000191550
    VCID: 313C1D95C12D085FE44-8064
    1 Fault Found:
    02442 - Function Lamp in Control Head
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:29:20
    Freeze Frame:
    Voltage: 11.80 V
    Count: 72
    Speed: 0.0 km/h
    Hex Value: 0x02E0
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8H0 907 357 A HW: 8H0 907 357
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000017
    Shop #: WSC 06324 000 00000
    VCID: 303A1891C6270157EBA-8064
    Subsystem 1 - Part No: -----------
    Component: AFS-Modul links
    Subsystem 2 - Part No: -----------
    Component: AFS-Modul rechts
    1 Fault Found:
    02071 - Local Databus
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:28:58
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 357GZ087507455
    Coding: 0000002
    Address 65: Tire Pressure (J502) Labels:. 8K0-907-273.clb
    Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
    Component: J502-RDK H03 0250
    Revision: 00001001 Serial number: 13140785998619
    Coding: 0CD154
    1 Fault Found:
    01521 - Sensor for Tire Pressure
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 182
    Mileage: 132505 km
    Time Indication: 0
    Date: 2017.08.07
    Time: 16:50:59
    Freeze Frame:
    0.00
    Bin. Bits: 00000000 01001001
    Voltage: 12.50 V
    Text: 22,0C;n.erkannt;3441735563;--h;---C
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
    Component: SDS 3501 US H46 0630
    Revision: 00000000 Serial number: 00000807210498
    VCID: 34321481323F3D778F2-8060
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
    Component: J772__Rearview 0070
    Revision: --H12--- Serial number: 525PA8-J8791LT
    Coding: 1000008
    Shop #: WSC 06435 000 00000
    VCID: 3728238D2349D66FAA0-8062
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4F0 910 336 H HW: 4E0 862 335
    Component: Handyvorb2 H20 1130
    Revision: 00000000 Serial number: 00000005053891
    Coding: 0010900
    VCID: 280AF0F1FEF7499733A-807C
    End----------(Elapsed Time: 03:44, VBatt start/end: 12.2V/12.2V)-----------
    Mar 07 2016
    Lehigh Valley PA
    Only noticeable symptoms of engine problems are occassionaly it will shift poorly, idle crappy when cold and the car does not accelerate properly and feels restricted. Oil sensor tells me car is too full, dip stick disagrees. No over heating, I can hear my radiator fans running, kicking on and off when they are supposed to. I'm confused.
    Dec 30 2014
    2008 S5 6MT
    Kansas City, MO
    I don't think 08-09 had a working virtual oil level sensor. You can enable it in the MMI, but it doesn't read correctly.
    The engine hesitation could be the intake manifold flap. The P2019 code. Look around in the diagnostics for the engine computer. There might be tests in there for the intake flaps. It could also be an electrical short related to the failed engine mount. My car acted really weird when one of my mounts failed. It was almost undrivable. I think the hydraulic goo in the mount is electrically conductive.
    Mar 07 2016
    Lehigh Valley PA
    Makes sense, once I cleared all modules only the N335 valve issue, Motor mount issue, and Oil sensor issue returned after a spirited drive. I am going to take it to get the motor mounts done, and check my MMI to see if that oil setting is enabled for some reason and shouldnt be.
    Oct 11 2014
    2002 TT, 2012 X5d
    Connecticut
    I got this code (2010 S5 6spd, 70,000miles) and it turned out that the manifold flap was stuck due to a vacuum leak. That was much cheaper than some of the other possibilities - like replacing the manifold...
    Check for a leak - maybe it's simple
    Mar 07 2016
    Lehigh Valley PA
    Quote Originally Posted by cts5 View Post
    I will dig through VCDS to see if I can test it. I wouldnt be super surprised, I've already fixed a couple leaks on this car, theyre just getting harder to find lol
    And theres small deposits of oil In my plug wells, and I'm concerned about that as well. Should I be?
    Dec 30 2014
    2008 S5 6MT
    Kansas City, MO
    Given the mileage, I wouldn't worry too much. The gasket is probably just getting old.
    The valve cover gaskets for these cars are actually really reasonable. $19 left, $23 right.
    Left https://www.ecstuning.com/b-genuine-...ft/079103483t/
    Right https://www.ecstuning.com/b-genuine-...ht/079103484c/
    Mar 07 2016
    Lehigh Valley PA
    Thats not bad at all and the job looks like it will be fairly reasonable as well
