Results 1 to 7 of 7
    May 16 2017
    Anchorage Alaska
    Question P3 Vent Gauge Not Reading Boost
    I recently installed a p3 vent gauge with the track pack software and it reads everything except the boost. Currently running apr stage 2 software with dual pulley setup.
    Does anyone have any ideas?
    Active Member One Ring rgferrell56's Avatar
    Mar 22 2017
    Newark California USA
    P3 not reading boost
    Sent from my SM-G955U using Audizine mobile app
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Items for Sale
    Is it configured for your car / setup / etc? Good instructions on the website. I bought my gauge with the analog boost setup, but didn't install that option right away, so I had to change the setting to digital in the setup / config menu.
    2005 A4 USP (Gone)
    2012 S4
    Mar 14 2016
    doesn't matter
    Remember to set it up based on the instructions on the website. It's has a few specific settings for our ride.
    Sent From S8 via Audizine app.
    Senior Member Three Rings Joker S4's Avatar
    Jun 21 2014
    Virginia Beach, VA
    I have the same thing going on right now, and it doesn't read IAT either. I just have to set it up. The website has everything you need. I'll get it configured properly once I'm finished with my current work road trip.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF |
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    IA/IL
    Push and hold both buttons to enter configuration, then scroll through (tap the right button) and make sure you have bSt.A selected if you ran a boost tap and have the analog sensor or bSt.d if you are using the OBDII port. Also ensure that car.3 is selected for the 3.0T. Save your changes (long hold on the right button) and that should do it.
    http://www.p3gauges.com/install/
    Jun 21 2014
    Virginia Beach, VA
    Quote Originally Posted by jl87 View Post
    Awesome, thanks for that quick rundown.
