Results 1 to 16 of 16
    Jul 15 2015
    2000 Z51 Corvette 427, 1987 AM General M998
    Boston MA
    A/C blowing warm
    Ac is blowing warm. I thought it just needed a recharge but when I plug the bottle in it's reading zero psi when I squeeze the bottle.
    I also couldn't tell if the compressor was cycling on or not.
    Just wanted to double check if I'm missing anything stupid before I take it to Audi and I get completely screwed on parts and larbor.
    Sent from my XT1650 using Tapatalk
    Aug 04 2016
    Athens,GA
    You are going to need vcds cable to cycle the ac compressor.
    Jul 15 2015
    Boston MA
    Ok, Is that the only way to tell?
    Veteran Member Three Rings Dr Chill's Avatar
    Oct 04 2011
    South FL
    Items for Sale
    This has happened to our cars twice in the past 2 years. Ran the codes and the problem both times was a bad AC pressure sensor switch which screws on in front of the condenser. Bought one at the local VW dealership which was $65 rather than $82 for the same part at Audi. Took 1 minute to switch out.
    Current- 2017 S6 , 2015 Z/28, 2015 A8L TDI, 2013 S4 DSG
    Jul 15 2015
    Boston MA
    Thanks! I'll run the codes in the morning.
    Jul 15 2015
    Boston MA
    Dr chill. You were right. Ran the codes. Ac pressure temperature sensor no signal. Thanks for the great advice
    Senior Member Three Rings shoe3k's Avatar
    May 18 2015
    I'm literally at the dealer with my new car because my car's AC started to blow hot air. I have 1180 miles on the clock.
    2017 S6 Prestige | Moonlight Blue Metallic | Sport Pkg | Cold Weather Pkg | Driver Assistance Pkg |
    Previous: 2015 S4 | 2015 STI | 2012 GLI Autobahn | 2008 Passat | 2004 R32 | 2005 GTI 1.8t |
    Jul 15 2015
    Boston MA
    Blowing ice cold now. Took 2 mins to change. Thanks again
    Mar 21 2016
    Columbia South Carolina
    Quote Originally Posted by Havok View Post
    I had a sensor fail that an indy replaced for $40.
    Dec 13 2015
    '17 Audi S7
    CA
    Replacing this seems simple enough, but would anyone mind taking pictures and briefly explaining the process for a DIY?
    2017 S7 | Glacier White Metallic
    Jul 15 2015
    Boston MA
    If you Google image the sensor you'll see a b8 image.
    All you have to do is remove the plastic cover above the radiator and it's right there.
    I just bent mine up instead on unclipping to save time.
    Unclip the wire and use an adjustable wrench to remove and replace. Reattach wire
    Clip the plastic cover back into place. Don't force it! It has clips that slide right in.
    Dec 13 2015
    '17 Audi S7
    CA
    Hey thanks!
    Veteran Member Three Rings car's Avatar
    Feb 03 2009
    00 S4 06 A4 Avant 93 SLC 91 GTI
    Millersville, PA
    Mine did this this morning. Message stating that auto start stop is not available and warm air from the AC. Two pending codes, no light. P0116 and P017B. Hoping they come back on so I can take it in to get it checked out.
    16 S6 Prestige - Daytona Gray Pearl - Sport Package - Drivers Assistance - B&O - Black Optic - Comfort Seats - Cold Weather Package - Alcantara Headliner - Cargo Net
    Dec 13 2015
    '17 Audi S7
    CA
    Wow seems like a common failure, assuming car's problem is the same.
    Maybe I'll just go buy the part ahead of time. I know this stuff is warranty covered, but for something like this, assuming the fix is that easy, I would just do it myself.
    Oct 04 2011
    South FL
    Items for Sale
    Quote Originally Posted by jpru2001 View Post
    Aftermarket switches have the reputation of not lasting very long. I'd recommend a genuine VAG part.
    Active Member Two Rings cjryan33's Avatar
    May 23 2013
    2010 Chevy Tahoe Z71
    Fulshear, TX
    I just had my pressure temperature sensor swapped out about a month ago. Thank god the Texas heat has not been that bad so far!!!!
    2013 A6 3.0T Quattro, Premium Plus, Dakota Grey, 20" Sport
