Results 1 to 7 of 7
    Jul 17 2017
    Crack in oil cooler
    So I recently had a crack in my oil cooler and it started mixing oil with the coolant. A friend of mine told me that since it's a manual this should not happen. If it was an automatic this would happen.
    Can anyone shed light on the latter part of my statement?
    2001 S4
    Apr 26 2015
    Phoenix, AZ
    Absolutely false. The oil cooler will leak coolant into the oil, and oil into the coolant, regardless of what transmission is bolted to the other side of the engine. Your friend was probably thinking about a transmission cooler, which on an automatic transmission vehicle would be plumbed into the radiator.
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    '07 Volvo S60R Cavalli Turbo, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    All S4's (regardless of transmission) have an engine oil cooler which is cooled by the engine coolant so if that cracks internally, coolant and oil can mix. The trans cooler (automatic only) appears to also be an oil to coolant based heat exchanger housed within the radiator end tank so there's also possibility of cross contamination there.
    2001 Silver/Black S4, Built engine (RPM rods, ARP hardware, Mahle pistons, Supertech valvetrain, etc), Tial 605's @25psi on 93 oct, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    I was waiting fro some white rocks to fall out of the cooler..
    anyway.. as the fellas above me said absolutely false, They both have and they can mix if there is an issue
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I recommend ditching the factory cooler and installing an external oil cooler it will eliminate the chance the the same failure in the future plus it will cool your oil better that the stock cooler will ever be able to.
    Established Member Two Rings ReggieNoble's Avatar
    Dec 17 2016
    Fl
    Not to thread jack but I'm thinking of going that route, do you recommend any kits? Or is it easier to build a kit?
    Nov 23 2013
    Grosse Pointe, MI
    For anyone considering switching from a water cooled to air cooled oil cooler and living in climate where winter means sub zero temps, you absolutely must install a thermostatic bypass valve or else you will blow oil lines due to the pressure of the oil pumping against extremely viscous oil (think sludge) in the cooler. Once it comes up to temp, the valve switches from bypass mode to allow flow through the cooler. The water cooled oil coolers don't suffer this issue since the coolant helps maintain oil viscosity in an acceptable range. And if you wonder how I know, I do this stuff for a living.
