Results 1 to 6 of 6
    Active Member Two Rings dwilliamsj's Avatar
    Mar 24 2017
    HuskerNation - Nebraska
    Passenger Speaker Rattles, B&O Sound System,
    My passenger side speaker has been rattling randomly and it gets really annoying, I figured I would post on the forums, I do not believe it is blown because it still is putting a good output of sound, idk if the door frame is loose or what, any ideas?
    Mar 24 2017
    Bump
    Veteran Member Three Rings Rocs's Avatar
    May 25 2009
    2004 Audi A4 USP
    Conshohocken, PA
    Items for Sale
    mine occasionally rattles also. maybe 10% of the time. May be common on our cars. Adust the speaker settings and it should go away. NO real reason to have your bass anywhere past the middle setting in my opinion.
    Come to think of it, look at the bottom of your door. Is your weather stripping sagging? Mine is and this could be a result....
    2012 A4 6mt
    -Prestige
    -S Line
    -Black Optic
    -B&O
    Senior Member Two Rings ranchos's Avatar
    May 05 2014
    United States
    It's 99% probably the plastic clips that hold the door card to the metal. You can pop it loose and put some rubber wedges around the clips, and pop it back. The rubber will sorta put outward pressure on the clips and keep them from rattling.
    May 02 2017
    phoenix
    get an app you can control the tones with. I noticed around 65-75 hz or so it can cause some buzzing. I pinpointed it to the light under the door.
    Shoved some insulation type stuff in the door and it seems to be gone now.
    Mar 24 2017
    Quote Originally Posted by ranchos View Post
    How do you get to this if you could give me something to look for that would be appreciated!
