Results 1 to 8 of 8
    Senior Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Best diagnostic tool for our cars?
    I was thinking of getting the OBDII And EOBD Code Reader from ECS. What are your thoughts?
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Buy vag-com.
    Dolphin S4 Cabriolet
    Misano RS4
    IG @dinuzzohyeah
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '16 Tundra 1794, '12 Prius
    Madison, AL
    +1
    Ross-Tech VCDS (VAGCOM)
    07 Phantom Black JHM-SC
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Vag com and its not even close. 199 for a 3 vin one
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Veteran Member Three Rings badger.'s Avatar
    Mar 31 2014
    '05 S4 Sedan | '05 S4 Avant | '01 Lexus IS300
    KY
    Quote Originally Posted by tar View Post
    Check the general classifieds on here as well, often can pick up a used 10-vin or unlimited vin one for $150-175 as people sell them when they leave VAG platform.
    '05 S4 Sedan Arctic White: JHM Intake Spacers | JHM ATF Cooler | JHM Auto-tensioner | 034 Motor Mounts | Apikol Snub | Slotted & Dimpled Rotors | AQ1200D w/Dual 10" CVRs | 35% Tint | Piggies | Fast Intentions Catback
    '05 S4 Avant Brilliant Red: JHM Tune | JHM v1 Headers | JHM LWCP | JHM Ported IM| JHM ATF Cooler | Koni Yellows | Apikol Rear Diff & Snub | Thor Skid Plate | JHM LW Rotors | Fast Intentions Catback
    Senior Member Three Rings roboto_1337's Avatar
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Don't waste your time with anything other than VAG-COM
    Piggy Pipes, Milltek non-res cat-back exhaust, JHM 93 Tune, JHM Short Throw Shifter, Updated RS4 upper and lower timing guides, Brembo 18Z w/RS4 SS lines, Hotchkiss RS4 Front Anti-sway bars, BC racing BR coilovers, EB-Works adjustable rear end links, 034 Motorsports spherical end links. 034 Motorsport Engine mounts, 034 Motorsports Silicon MAF hose, Hartmann 19" RS4 Reps +5mm 42DD front +10mm ECS rear.
    Oct 11 2015
    Atlanta, Georgia
    VAG-COM it is...thanks for the input
    Active Member Two Rings Doubleredrolex's Avatar
    Jan 08 2017
    1969 gmc truck 383 and air ride.
    BC Canada
    Ross tech vcds enthusiast version. It's like $199 with the cable. It's prob one of the most helpful tools you can buy for your audi.
    2004 S4 6MT Dolphin Grey on black leather. Yes the chains and guides are done :)
