Page 3 of 3 FirstFirst 123
Results 81 to 116 of 116
  1. #81
    Veteran Member Three Rings iparatroop's Avatar
    May 31 2010
    Avus/Ti/Excl/TTS SC B7RS4 (Past: Imola/Ti B7RS4 and too many VWs)
    NC
    Some waterfest runs
    Quote Originally Posted by Quattrors4 View Post
    the pictures speak for themself
    Perfect, I can see them now. Now explain why there are zero marks on the fan shroud aside from the groove that was put there by the kit installer. A gates HD belt would leave scars all over the shroud if it were to make contact.
    Also, explain why the belt would walk with the car in service position. That's fucking magic right there.
    I park far away so your car will look better, I promise.
  2. #82
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by iparatroop View Post
    hold on you told me very specificlty that the belt was only moving or sherdding @ high load high rpm band you never ever told me that this was happening at idle ,also you can clearly see the bolt off the pulley hitting the front that means there is a shit load off engine rocking out off place and I garranty you with that mnush movement the belt is touching and rubbing somewhere down bellow on the fan
  3. #83
    May 31 2010
    NC
    1. False. I told both you and TTS that the belt will walk even at idle at times, but without a doubt will walk at high load.
    2. False. If you had ever assembled one of the kits that you supposedly distribute, you would know that the belt is protected by the gates (or shoulders) on the blower pulley, and any other pulley that runs an accessory driven by the belt. Furthermore, the pulley will make contact with the shroud before the belt ever gets a chance and will prevent the belt from contacting the shroud 100% of the time. Remember, the belt rides in the recesses of the pulleys, it is impossible for it to contact the shroud unless the pulley in question is without shoulders.
  4. #84
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    bro you have no f....clue just stop with your nonsense ,the older kit like you have have been running for a while with no incedent in Europe ,and yes I did not install one off those kits yet but I installed a few of odder kits and I also fixed a few with your kind off problem and it was always related to to mush engine movement or belt miss aligned or a bad pulley,but here on your car you have the evidence right there ,motor mount complitly loose and pulley bolt hitting on high load ,
    god damn it man,i don't even care anymore ,you want to be wright be my guest here we go iam going to tell you !!!YES YOU ARE RIGHT IAM JUST A DUMM ASS I WAS WRONG !!!!here we go be happy nowlol
  5. #85
    May 31 2010
    NC
    1. Not your bro
    2. You just plainly stated "bad pulley" as a possible issue. Thank you for the reinforcement. In my case it was the issue, as like I said before, I'm running the same motor mounts. So there's the evidence. I got the right pulleys and bracket, didn't swap mounts, and no longer have an issue. What more evidence do you or TTS need to see that their equipment was faulty?
    3. You do care. You want to be a nice guy but you prevent people from liking you because you can't keep your stories straight. And I know I'm right. I gave you the benefit of the doubt when all others couldn't stand you. I just wanted to see your car go fast. Like others though, my whole view of the project has been tainted by you being you. I'm still pulling for your car, but you're full of shit.
  6. #86
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    1. Not your bro
    lol ok man no problem
  7. #87
    May 31 2010
    NC
    Not a great shot as I got to the track portion at the last minute, but you know who it is.
  8. #88
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    nice picture thanks for posting it
  9. #89
    May 31 2010
    NC
    I was all the way down by the board. I wish I could have been in the bleachers. I could have gotten way better shots.
  10. #90
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
  11. #91
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    to bad nobody made some videos just got one from a guy that he sent me
  12. #92
    May 31 2010
    NC
    That's the only run I saw. 11.7xx if I remember correctly at 131 or something. You're horrible out of the box but on the big end it's ridiculously strong. Out of the box it's almost as if you have TC not completely defeated.
  13. #93
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Yes I know I can't get it right out off the box! Or I spin or I hope Ext.... I can't never get it right
    I need more Practice
    I just get over exited off the line and I fuck up all the time
    Accualy the 11.7 run trapped 133.6
  14. #94
    Aug 09 2012
    Bay Area
    Wait so you have installed other TTS kits in the US? How many more are out there or is paras the only one currently?
  15. #95
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Kambesama View Post
    I meant another companys then tts ,I know sometimes it's hard to understand me,para is the only one with an rs4 tts kit in the us
  16. #96
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Items for Sale
    bro you always have to say something negative,at least I run my car!!how come you don't run your car ??and show us some numbers with your super dooper jhm stage 56 kit ?or are you to afraid to blow it up!!
    I am not your bro.
    Then I don't always say negative things and some of the things that I do say are positive but you have your emotionally hurt blinders on so you probably missed them. It is ok because criticism hurts but if you take it the right way then you will eventually do better. For example, Saki on Audi-Revolution.net had to point out to me that my shifting was taking too long so I worked on it and got faster. Actually finally got my launch close to what I want in May so that I stop breaking axles or spinning too badly. That is why I recommended putting gopros on to look at the tires. There is a method to my madness but most people don't see it.
    It does look like your car has nothing in first gear. What is the maximum boost pressure that you hit in first gear? When you shift to second gear the front end should barely drop (not bounce a few times) and it would be great to hear the tires chirp. My S4 will chirp the tires going into second and I have video to prove it. By the way, this is funny because in the past you have claimed to chirp the tires going into fourth gear. Which is bullshit. If you were honest then a lot of this criticism wouldn't be so bad, just saying.
    Funny how when you don't like the message that you come after the messenger. I run my S4 whenever I feel like and it has run the times and trap speeds that it should for the mods that it has.
    Quote Originally Posted by q_dubz View Post
    Hell they never post anyway. You're pretty much the only one. PS did you go this weekend?? Did you run?
    It is interesting how those cars work and the owners actually get to enjoy them so they are probably too busy to be posting. This section is just worth lurking through on occasion when I am in between helping someone. I was working this past weekend and didn't need to take a bunch of time off this year after my long cross-country trip last year.
    Quote Originally Posted by MarcusDubya77 View Post
    Actually..you did the calling with your initial post...
    This is true.
    Wait, so I offended you by saying "oh, you're Mario", followed by "I'm Dave" and then walking away? What did you want, a pat on the back? A handshake? A fucking hug? I don't hide behind the internet like it's my safe spot. You got exactly how I feel in about 10 seconds of interaction. From you constantly spewing bullshit on this forum, to you spewing bullshit in private messages, I'm over you and your antics.
    Let's set this straight, coming from a guy who doesn't like these forum games. I told you long before waterfest took place exactly where I'd be during the show. My car was there the whole weekend. You managed to find Steve on Sunday and from what you've said two other blower cars. I'm assuming one was Ardy. Ardy had less than 100 miles on his clutch, he wasn't going to race anyone. You dodged Steve for years, why should he give a shit anymore? The only other blower car that I saw there was Ramon, and he doesn't race, he just likes his car. So that leaves me. You didn't approach me, or my car. You could have talked to anyone at the booth if I wasn't there and asked them to find me. Would have been simple. I didn't go to waterfest with the sole purpose of drag racing, but had you approached me, I would have run even at the risk of breaking my car over eight hours from home.
    Stop sensationalizing your existence and just be a normal human being, you'll get more respect that way.
    Remember calling me incompetent on this forum? Remember telling me how my one not perfect motor mount was the root of my belt issue? That's part of why I don't like you. That's why I didn't shake your hand or give you a hug or whatever intimate response you desired. Man the fuck up and quit making shit into something it isn't.
    This sounds like what I expected happened.
    Funny, I said that he had nothing in first gear, which would be out of the box too. Also said that after he gets the rpms up in second gear it does take off until it noses over going into third gear. Can't see much of the car after it goes into third gear so it could pull hard from that point on. That type of acceleration would suit what someone else has described in another thread about this TT RS4 being laggy.
    http://www.audizine.com/forum/showth...Mario-s-TT-RS4
    Quote Originally Posted by mr_dennis_s View Post
    Short Version
    WOW! HOLY S*^&T! Lag until 4-4.5K RPMs but when boost hits HOLD ON!!!!! He killed a street bike on the highway. Earlier in the day he pulled on my Supercharged RS4.
  17. #97
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by JimmyBones View Post
    I am not your bro.
    This is true.
    but its funny you still don't post your times ,if you feel that what they should be at then why are you scared ?I know you are trapping 115 116 mph witch is barely 400 whp
    just to tell you what I saw on my logs from waterfest,i just cant get a good launch out off it,power is there even in first gear
    launch control set at 4500rpm I get 10psi
    1 gear 12 psi
    2 gear 12 psi
    3 gear 12 psi
    4 gear 12psi
    5 gear 12psi
    6 gear 12 psi
  18. #98
    Registered Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Items for Sale
    thanks man,i know,i met a lot off people at waterfest that where so impressed with the car but like I said I'm not scared running it even at 100 f ,I do turn it down a bit to be safe when its that hot but its still making good power but when you have this doush telling me the car has nothing in first gear makes me want to cry lol,but hey whatever thanks for the kind words
    and ps I'm not afraid to post my times
    Have you considered adding a killer chiller to your setup? $800 universal kit. Sure youd be in the 10s even with a bad launch
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
  19. #99
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by S4orgy View Post
    I have an air to air intercooler it wont work on that set up ,I could spray some co2 onto the intercooler it would help,i should be running 10s already easely with that trap speed
  20. #100
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    here is a log off the week end you see the problem with my launch
  21. #101
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Items for Sale
    10psi by 4500 in first... Lucky you lol
  22. #102
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    :-) ,and he says I lag a lot lol
  23. #103
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Items for Sale
    You only launched at 2500?
  24. #104
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    no 4500
  25. #105
    Jan 14 2009
    Audis
    Items for Sale
    Nice runs!!!! I got to see the 11.2 run......car sounded badass!!!! cool to hear a mean V8 with tunner turbo sounds haha. The red RS7 that was running Sunday was putting up very similar times.
    B6 Nogaro with lots of mods
    BUILD THREAD
  26. #106
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Mr. Corey View Post
    I know that rs7 is bad ass !he was running 10.9 @ 124 mph he has a stage 2 unitronics running 116 oct race gas ,what a beautiful car it's realy nice to have an automatic lol just floor it !
  27. #107
    Apr 03 2010
    Northern Virginia
    Items for Sale
    1 gear 12 psi
    2 gear 12 psi
    3 gear 12 psi
    4 gear 12psi
    5 gear 12psi
    6 gear 12 psi
    Scared of what? My car does what it is supposed to for the power that it makes yet yours underperforms.
    How about you post a picture of the whole screen and log than a tiny portion? Or are you trying to hide things like usual? A time and date of the log included in the picture would be great too since you will get no benefit of the doubt from me. It is so simple to take a screen shot that even you can probably figure out how to do it.
    Why haven't you actually tried to improve your launches? It makes no sense unless you just want to use that as an excuse.
    That is not all correct. He claims to be running 109 octane and it looks like he is only stage 1 unitronics tuned from the posts that I have seen. The 10.9 @ 124 mph is correct though. You have a tendency to exaggerate things to try to make yourself look better and instead you just look like a fool.
  28. #108
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    yes you are right 109 oct and stage 1 plus
    but why don't you post your times then?????
  29. #109
    May 31 2010
    NC
    I like to call this piece "A Conversation With Mario". The look on Ardy's face is priceless. Funny, I only realized this was Mario just now when editing.
  30. #110
    Registered Member Four Rings Peter1.8t's Avatar
    Dec 03 2009
    PNW, Washington
    Lol that facial expression is great.
  31. #111
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    we did accualy did have a nice conversation about he s car
  32. #112
    May 31 2010
    NC
    I know man. I talk to Ardy a lot. I just thought the pic was funny when I actually got time to sit down and go through the 1700 images I shot over the weekend.
  33. #113
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    that's a lot off pictures you took lol
  34. #114
    Dec 03 2009
    PNW, Washington
    Mario you should just drive over here to the west coast and I'll race you.
    I've been putting tons of miles on the RS4 lately. Was 95-100*F one weekend and I had no issues driving it hard, was around 450miles in one day, over 4 different mountain passes, rarely following the speed limit, reached the top of 5th a couple times, but the car performed flawlessly. So no tuning issues with heat like whomever made up that excuses for us.
    I think I could speak for all the blower RS4 guys when I say we know we aren't the fastest cars out on the road. Hell bolt on c63's and m4/3's are low 11/trapping 130mph cars nowadays. However these cars are very fun to drive and extremely rewarding, Audi and other competing manufactures haven't built another analog style car like this one since.
  35. #115
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Peter1.8t View Post
    we are talking at the drag race track where supercharged rs4 tend to heat soak like creasy in witch its kind off normal,when driving them on the road its not as much off an issue because its cooling much better
  36. #116
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '16 Tundra 1794, '12 Prius
    Madison, AL
    Items for Sale
    Agree 1000%
    07 Phantom Black JHM-SC
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
