Results 1 to 9 of 9
    Active Member Two Rings Humbledrew34's Avatar
    Aug 02 2016
    B6 s4 giving problems already
    Hey guys! Got my first b6 audi s4 a couple of days ago and off the bat I have a couple of problems . I believe the top chain guides need to be serviced because I hear a little rattle near the valve cover but that maybe due to the type of oil the previous owner used the oil isn't thick at all it's really loose and smells a little like gasoline. My questions is the oil light comes on at idle but it doesn't flash would that be a sensor or maybe the bad oil ?..... the oil is black so I'm changing it sometime this week when I have time But another problem is the speedometer doesn't work and the coolant gauge doesn't work as well sometimes however the tachometer works and the gas gauge works does this mean the cluster is dead ?
    Senior Member Three Rings badger.'s Avatar
    Mar 31 2014
    '05 S4 Sedan | '05 S4 Avant | '01 Lexus IS300
    KY
    Items for Sale
    I would start with checking and/or changing the oil. Then get codes pulled and report back.
    '05 S4 Sedan Arctic White: JHM Intake Spacers | JHM ATF Cooler | JHM Auto-tensioner | 034 Motor Mounts | Apikol Snub | Slotted & Dimpled Rotors | AQ1200D w/Dual 10" CVRs | 35% Tint | Piggies | Fast Intentions Catback
    '05 S4 Avant Brilliant Red: JHM Tune | JHM v1 Headers | JHM LWCP | JHM Ported IM| JHM ATF Cooler | Koni Yellows | Apikol Rear Diff & Snub | Thor Skid Plate | JHM LW Rotors | Fast Intentions Catback
    Established Member Three Rings roboto_1337's Avatar
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Check codes with VCDS... PCV valve is probably due to be replaced.
    Is the rattle only on startups or all the time?
    Piggy Pipes, Milltek non-res cat-back exhaust, JHM 93 Tune, JHM Short Throw Shifter, Updated RS4 upper and lower timing guides, Brembo 18Z w/RS4 SS lines, Hotchkiss RS4 Front Anti-sway bars, BC racing BR coilovers, EB-Works adjustable rear end links, 034 Motorsports spherical end links. 034 Motorsport Engine mounts, 034 Motorsports Silicon MAF hose, Hartmann 19" RS4 Reps +5mm 42DD front +10mm ECS rear.
    Aug 02 2016
    Quote Originally Posted by badger. View Post
    P0501 (vehicle speed sensor)
    P0404 (exhaust gas recirculation)
    P0174 (system too lean)
    P0171 (bank 1 system too lean)
    P0455 (leak evaporative emission control)
    The previous owner didn't know anything about the car he just bought the car because it looked cool to him he said the chain guides were done before by the last owner but he lost the records. He gave it to me for 1500 thinking it had a timing guide problem but no codes were related to that. The car has 150k on the odometer and starts up with a little rattle but that's really it after it warms up you can hear a little rattle at idle but that's all. I really think he went cheap on the oil because the oil is literally like water no coolant in the oil though it just smells like a little gas though. The car pulls hard and clutch and tranny have both been replaced recently
    Aug 02 2016
    Quote Originally Posted by roboto_1337 View Post
    The previous owner didn't know anything about the car he just bought the car because it looked cool to him he said the chain guides were done before by the last owner but he lost the records. He gave it to me for 1500 thinking it had a timing guide problem but no codes were related to that. The car has 150k on the odometer and starts up with a little rattle but that's really it after it warms up you can hear a little rattle at idle but that's all. I really think he went cheap on the oil because the oil is literally like water no coolant in the oil though it just smells like a little gas though. The car pulls hard and clutch and tranny have both been replaced recently but the car does have a catback exhaust and you can hear a little rattling in the exhaust at idle and when i rev it high just a little black smoke comes out so I think it's time for to clean the catback
    Aug 02 2016
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Seems like PCV and the 2 EGR valves are probably clogged up. Top guide could be shot. Sounds like you could put some work into it. If it's just a little smoke on startup your valve guides may be shot.
    The lean code could be a tricky one.... not really too sure where to start on that one.
    Senior Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6
    Billings, MT
    Possible vacuum leak did the lean codes?
    Sent from my XT1650 using Audizine mobile app
    Clarice
    JHM intake spacers, heat wrap IM, 034 motor mounts, 15mm wheel spacers, ZimbuCAI
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Quote Originally Posted by Humbledrew34 View Post
    I'm working nights and didn't want to text you at 2:00am... check out this thread
    http://www.audizine.com/forum/showth...pgraded-guides
    Good part sites are ECStuning.com FCPeuro.com JHMotorsports.com if you want individual parts, but not as cheap as Terry's contact for a basic kit.
