    Mar 30 2017
    denver
    Any Tips On Replacing My Coolant Recovery Tank
    I Have A 08 S4 , I Need To Replace The Coolant Recoverery Tank. Is There Any Tricks On Putting That In
    Senior Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    Oregon
    First trick is using the search button. Second is to ask in the right forum section :)
    Seriously tho.... iirc its only like 1 or 2 screws, one electrical commector and 2 hoses...
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S4
    Mar 30 2017
    denver
    Which would be the right forum section
    Sent from my SM-G930P using Audizine mobile app
    Established Member Three Rings roboto_1337's Avatar
    Jul 05 2016
    2006 S4 6MT
    Ontario, Canada
    Main model line B6/B7 S4/RS4. This is the classifieds... make sure you put the hose clamps on the hose before putting the tank in place. Very easy job. May want to drop the coolant level from the rad before removing the tank. And make sure you have the proper coolant/mixture to top it back off after.
    Piggy Pipes, Milltek non-res cat-back exhaust, JHM 93 Tune, JHM Short Throw Shifter, Updated RS4 upper and lower timing guides, Brembo 18Z w/RS4 SS lines, Hotchkiss RS4 Front Anti-sway bars, BC racing BR coilovers, EB-Works adjustable rear end links, 034 Motorsports spherical end links. 034 Motorsport Engine mounts, 034 Motorsports Silicon MAF hose, Hartmann 19" RS4 Reps +5mm 42DD front +10mm ECS rear.
    Mar 30 2017
    denver
    Thanks You
