Results 1 to 12 of 12
    Established Member Two Rings Marc R's Avatar
    Jan 29 2017
    Amsterdam
    Fitting RS6 turbo's for stg 3 ... time, parts ...
    In a few weeks i want to fit the rs6 turbo's on my S6 just prior to the custom mapping.
    I am wondering which additional parts i need to order for the swap...gaskets etc...
    And how long should this operation take? I have some reasonable mechanical experience (did most of the build of my RS4 b5 engine)
    any input welcome.
    RS4 B5 mingblue 650 hp
    Mercedes W124 E500 Limited
    Audi S6 4G stage 3 RS6 steering wheel RS5 20" RS6 exhaust..610 WHP and more to come
    Feb 25 2014
    Texas
    Do you have upgraded cooling on the car yet? Will need that for stage 3
    Mickey (AKA: AudiS4B8)
    2017 Nardo Grey S6 | APR Stage 3 | RS Turbos | Akrapovic Exhaust | AMS Downpipes | AMS Cooling System | MRC Carbon Inlets | Eventuri Intake | Satin Black HRE P44SC Wheels | Cete Lowering Module | Alu Kreuz | Eurocode Sways and Endlinks | Neidfaktor Carbon Mirrors | Full Suntek PPF | Opticoat Pro+
    Instagram: ze_nardo6
    10.69 @ 129mph
    Very Nice I will follow your Progress. Please post pics along the way.!
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Following aswell but like AudiS4B8 mentioned, i also would consider trying to upgrade cooling (but since you going to JD you maybe do their custom cooler?).
    Good luck!
    Current S6 C7 avant 2013: estoril | ceramics | JD engineering stage 2 | LightVan no backseats | Milltek non-res valved | 034 trans-diff mount |CETE ASCv2 & EVC | FL dynamic tails | Thermo ZO coated catless DP | Custom HX cooler (JD) | RS6 c6 matt gunmetal 20" wheels | custom tailgate spoiler & diffuser | Armor heatshielded mani-turbo-dp
    In development: R8GT steeringwheel | FIS controler (mmi gauges)
    Senior Member Four Rings DGVR6's Avatar
    Aug 03 2014
    TV and a sofa
    Brooklyn
    Quote Originally Posted by Marc R View Post
    any input welcome.
    Oil tube O-Ring (4) N91056801
    Oil pressure line seal (4) N90303801
    Adapter O-Ring (2) WHT006901
    Turbocharger Gasket (2) 079253039M
    Exhaust Manifold stud (8) N91153902
    Exhaust Manifold nuts (20) N90894601
    Intake Hose Seal (1) WHT005529
    Outlet tube O-Ring for exhaust (2) WHT006537
    I believe that's all the hardware or most that's needed
    C7.5 S6 P+ Mythos Black
    11.081@122.59 100oct Stage 2 100 File
    11.284@121.29 100oct Stage 1 93 File
    Best Trap
    11.428@124.94 100oct Stage 2
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 11.978@117.71 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jan 29 2017
    Amsterdam
    Well thank you sir!
    I'm still looking at the possibilities for the cooler rad....
    Sep 07 2010
    Belgium
    Well thank you sir!
    Keep us updated (us = europeans ;) ). Personally still aiming at apr's cooler, but don't really want to fab my own mounts untill i know more about them.
    Jan 29 2017
    Amsterdam
    I'm working on another solution at the moment but not at all sure it's going to work
    Aug 03 2014
    TV and a sofa
    Brooklyn
    Almost forgot ngk step 8 cold range spark plugs
    Best Trap
    Previous
    Established Member Two Rings lapsandwich's Avatar
    Sep 28 2015
    Langley BC Canada
    What might that soultuon be?
    2014 S6 - 3" catless downpipes - HPA motorsports stage 2 - Aem methanol injection - Forge atmospheric Bovs
    2007 Ram 3500 - 5.9 cummins - 66mm turbo - built trans - mild fuel
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Quote Originally Posted by DGVR6 View Post
    Helpful list! Thanks a lot for sharing it
    13' S6 - Phantom Black - Unitronic ECU and DSG - Roc Euro - Links and Spacers
    Aug 03 2014
    TV and a sofa
    Brooklyn
    Quote Originally Posted by MikeDwerks View Post
    NP, as you can see Ive been prepping for my RS project ;)
    Best Trap
    Previous
