Results 1 to 39 of 39
    Active Member Two Rings Jackfults's Avatar
    Jun 20 2017
    Durango, Colorado
    Going crazy over finding 350mm/325mm rotors
    Well I've just about had it trying to find a set of rotors that will fit the JHM Porsche Cayenne BBK without spending 1200 on theirs. Gone through 3 different companies and sets of rotors with no success. Last one from Brake performance.com was close but the offset was way different.
    Sent from my Nexus 6P using Audizine mobile app
    Feb 21 2012
    MB S55 - (607hp/671tq), Suzuki GSXR 1000
    Chico/CA
    (18z) Mercedes Ml55 rotors = 350mm, center needs to be bored out a bit (66mm to 68mm, if memory serves me correct). I got my rotors for about $75 each. I believe the 17z uses the c32 rotors and the lug holes have to be bores out a bit. There is a huge thread in the general section that has a lot of useful info about the 17z/18z conversion.
    2000 Laser Red Stage III+
    Sep 22 2015
    South of Atlanta
    How do these dimensions stack up against your needs?
    Dia - 345
    Thk - 32
    Hgt - 51
    Hub - 67
    Blt - 15.3
    Jun 20 2017
    Durango, Colorado
    Pretty close I'm just unsure on the offset but that seems close. Thanks I'll check out the 17z/18z conversion
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Isn't jhm 750 for the pair?
    GIAC-X, STASIS TS,VAST,034 MS
    Sep 22 2015
    South of Atlanta
    Quote Originally Posted by Jackfults View Post
    Using this info
    http://forums.quattroworld.com/s4/msgs/190346.phtml
    It seems that should be a good fit.
    I have a set of New EBC slotted/coated rotors that have those dimensions for $168 (shipped 48 states) if you're interested.
    Jun 20 2017
    Durango, Colorado
    Are the 6 piston Cayenne Calipers 17 or 18z?
    Sep 22 2015
    South of Atlanta
    Depending on the trim level, the car would have had either 330MM front rotors (17z) or 350mm front rotors (18z). Thru my research, it seemed guys would run 18z calipers with 17z pads to allow use of 345mm front rotors with no over hanging pad.
    I've also heard talk of 19z??, but that just adds to the confusion.
    Jun 20 2017
    Durango, Colorado
    Yea I've been struggling haha. Guess I have the 18z
    Sep 22 2015
    South of Atlanta
    Sorry, should have mentioned, it should be clearly marked on the caliper.
    For example
    I have seen cases where the original manufacturer castings were ground off, but that's usually on refurbished ones, where the company doing the refurb is attempting to remove the "OE" markings. Had a set of Audi S8/D2 where the marking were removed from 1 caliper & carrier, but not the other??
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    Go to rotorlab.com. I have never bought something from them, but there rotors will work with 18z
    Sent from my SM-T710 using Tapatalk
    Jun 20 2017
    Durango, Colorado
    Quote Originally Posted by rage385 View Post
    Thank you for the tip I'm looking now and it seems like THE best option for people running Porsche BBK. Will update when the rotors from them arrive.
    Senior Member Two Rings wpfahl's Avatar
    Jan 07 2013
    2001.5 S4 Avant. 1997 A6 Base, 1997 A6 Avant, 2014 Jetta Hybrid, Ford F250
    California
    Jan 07 2013
    California
    Low cost but not the light weight solution. Needs to open up the center bore with a flapper wheel on a drill. Be sure to grind your steering knuckles before fitting the center bores to ensure fitment.
    Jun 20 2017
    Durango, Colorado
    Update: I Have been talking with Rob from Rotorlab and he has been incredibly informative about the issues with rotor fitment on B5 S4s utilizing JHMs 18Z setup. I will be getting them in about a month since I am a few orders behind.
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    I didn't want to have to open up the center bore on the rotors so I used B7 S4 rotors without problem. I shaved the retaining pegs on the calipers down about 1/16" to get good clearance. Had no problems so far. I have 18Z calipers
    Eurosport Tuning at it's Finest
    Nov 14 2006
    Land of the Eagles
    there is problems with using jhm 350 18z setup?
    Jun 20 2017
    Durango, Colorado
    Quote Originally Posted by Tiluleshpingen View Post
    No, the only problem is finding rotors if you don't want to pay 1200 for a new set.
    Jun 20 2017
    Durango, Colorado
    Sorry that was very badly worded. JHM fitment with their setup is great. Trying to find rotors from a different source is where it starts to get tricky.
    Dec 10 2011
    Stage 3 S4, E46 M3
    WI ✈ NC
    To be clear, the best off-the-shelf solution for 18Z are ML55 AMG rotors. The offset is perfect, and they only require opening the center bore by 1mm.
    Furthermore, JHM's 18Z rotors aren't $1,200.
    -Hayden
    Jun 20 2017
    Durango, Colorado
    Look them up on their site. I see 725 for the front set. 695 on the rears. Says bbk kit but doesn't include calipers just brackets.
    Jun 20 2017
    Durango, Colorado
    Looking at 350 mm fronts and 325 rears on the site.
    Dec 10 2011
    Stage 3 S4, E46 M3
    WI ✈ NC
    I understand what you mean now. The rear is not a "Cayenne" BBK so I was confused as to what you meant. But yes, that rear 325mm rotor/kit seems to be proprietary to JHM so finding an appropriate rear rotor elsewhere may be very tough.
    -Hayden
    Established Member Two Rings Lanorg's Avatar
    Apr 22 2013
    1997 1.9 TDI Jeep TJ
    I'm running ML55 rotors that were opened up 1mm. They have worked quite well and I don't experience fade on a small track.
    Just wondering what the weight penalty is with rotorlab.com rotors. Also, the benz rotors seem to have cooling fins in the same direction (mine are anyway), is this standard or do I have two rights/lefts? Was wondering if this is a major concern or not.
    B5
    Sep 22 2015
    South of Atlanta
    Quote Originally Posted by Lanorg View Post
    I think this is consistent across most rotors nowadays. I've even seen dimpled/slotted/grooved rotors where the vanes inside aren't R/L specific.
    Oct 09 2011
    SF
    Don't really understand what you're trying to achieve but from what I gather you're trying source "big brake rotors" for the front that's compatible with 18z and rear big brake "kit" to balance it out. Here's what I'd recommend.
    Established Member Two Rings Marchell's Avatar
    Jan 19 2012
    Moscow
    Try the s4 b8 rotors 345x30. They just sit as inteded but the rotor is a bit thin. Still they are very cheap.
    By the way, for the 18z owners. I also have the 18 with ml55 rotor installed and i seem to burn the rotors oftenly so they start to wobble. If i get a new pair its ok for a while but then again i have the same problem with wobbling disks.
    Any thoughts why thus happening?
    Sent from my PRO 5 using Tapatalk
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by Marchell View Post
    yea since this is opened an new discussion.. can you all please post up the mileage on the rotors you all using with 18z
    Jan 19 2012
    Moscow
    10k km on 18z with ml55 345x32 zimmerman rotor ate ceramic pads. Twice recutted the rotors, still the same wobbling problem on a a6 c6 2.7t avant
    Jun 20 2017
    Durango, Colorado
    I well my order is in with Rotorlab but I'm a few orders behind so it will take awhile. Fresh 18z BBK with any color powder coating, front 345, rear 325, ebrake calipers for rear rotors also powder coated. All necessary hardware for complete install minus brake lines and brake pads are included for a total of 975 before shipping. If you send them your old calipers you will get 300 refunded or sell them yourself for more. I will post in about a month with details of install and how it all fits.
    Jun 20 2017
    Durango, Colorado
    The BBK kit is almost here after a long wait I will update when it arrives hopefully next week. Due to a supplier error the Rear Calipers will be a week late.
    Jun 20 2017
    Durango, Colorado
    Alright here is the long awaited BBK from Rotorlab. They modify the Calipers and have new mounting hardware to allow you to run 350mm fronts and 325mm rear rotors. The rotors from Rotorlab are only 400 instead of 1200 from JHM. No other mods are needed once you receive them. Next week the rear kit will be in.
    Jun 20 2017
    Durango, Colorado
    Established Member Two Rings aFOURstance's Avatar
    Jan 30 2011
    '04 DBP R32 Turbo, '01 Nogaro S4 Stg 3 & Bagged
    FAIRFAX, VA
    Post some pics of them mounted on the car
    Life is too short to drive boring cars.
    Jun 20 2017
    Durango, Colorado
    Will do. Sorry I haven't updated anything it's been a crazy past few months. Everything mounted perfectly and I'll take pics when I get home this Monday.
    Nov 14 2013
    earth
    You seem to have things mistaken. JHMís rotors are 2 piece lightweight rotors. These are always more expensive than regular one piece rotors. As already stated in this thread you can use ml55 rotors for $75 a piece. A lot cheaper than $400.
    You arenít getting a 2 piece rotor for $400 a set.
    Jun 20 2017
    Durango, Colorado
    Yes I'm aware of the difference and never said the Rotorlab ones were two piece. You can see the pictures of the the front ONE piece. I did not want to buy rotors and modify them (seems that you have to bore a bit) after going through 2 different rotor sets and returning them and waiting more than a month. Again never did I say they were two piece.
    Nov 14 2006
    Land of the Eagles
    please keep us posted on how they fair. and if notice any good or bad differences between stock and or other ones
    Established Member Three Rings canduchita's Avatar
    Jan 11 2017
    ypsilanti
    I also run the ML55 rotor But one thing you have to do when running these rotors is you have to run the Z17 pad So you don't get any overhang on the braking surface from the bigger pad because the rotors are 345 mm20171217_170109.jpg20171217_170103.jpg
