Results 1 to 10 of 10
    Established Member Two Rings theplyamm's Avatar
    Jul 10 2010
    A5/S5 convertible maintenance?
    Is there a way to clean the inside of the little compartment in the trunk that's stores the soft top?
    May 21 2017
    Phoenix
    Subscribed...
    Dec 15 2015
    2016 S5 Cabriolet
    NYC/Cary, NC
    I use a air blower (the ones that are used for keyboards) and wipe it down with a quick detailer.
    Active Member Two Rings S5droptop's Avatar
    Nov 26 2016
    '12 Audi S5 cabriolet
    SE Wisconsin
    I just vacuumed it out, and took a damp rag and wiped the bottom side of the tonneau cover.
    Jul 10 2010
    How did you access it?
    Aug 13 2008
    Reston, VA
    Quote Originally Posted by theplyamm View Post
    stop the roof in mid cycle
    so when the back cover is open
    but the roof is still up
    that way you can clean it
    you also have to clean around the edge of the roof compartment
    there are drain holes near the rear windows
    mine were almost clogged with tree debris
    Nov 26 2016
    SE Wisconsin
    As mentioned, stop it mid cycle. I used the Carista app to enable remote top operation, which makes it very easy to stand at the back of the car and pick the perfect time to stop it for specific areas you want to access and clean.
    Jul 10 2010
    What is carista app?
    Nov 26 2016
    SE Wisconsin
    http://www.caristaapp.com
    It is kind of like a Vag-com lite. It allows you to make some customizations, will display error codes, allows resetting service intervals, releases e-brake for brake pad changes amongst other things. Worth the $40 IMO
    Jul 10 2010
    Just ordered it lol.
