Results 1 to 29 of 29
Thread: Spacer sizing
    May 15 2017
    Montreal
    Spacer sizing
    Hey guys,
    looking to add spacers to my s3.. so far the ecs kit looks good however i think the 10mm option up front may not be enough.. anyone running a 20mm in the rear on springs? any rubbing? I am talking about the OEM 19" wheels. would love to see a more aggressive setup, like 20mm rear and 12-15 up front. tried searching but couldnt find anything relevant. Thanks!
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    sub'd. so far in my research i like the 12mm/15mm combo by h&r. would love to see more pics though.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Nov 21 2012
    1972 Volvo 142E, 2017 Triumph Thruxton 1200 R
    Deer Park, IL
    (Edited with corrected front spacer info) I'm running ECS 12.5mm front / 17.5 rear. Very happy with that setup. Others on this forum have concurred that 10mm on the front is conservative and 12.5mm is perfect, I agree.
    Senior Member Three Rings deadbolt's Avatar
    Aug 29 2014
    NY/LA
    I'm running 15mm all around
    Stage 2+ 2015 Audi A3 2.0T Prestige
    My Build Thread
    @D3ADBOLT_
    @EUROGRADE_
    Nov 21 2012
    Deer Park, IL
    Quote Originally Posted by deadbolt View Post
    Looks great, but the OP is running stock rims I believe. Not certain if your offset is exactly the same or not.
    Aug 29 2014
    NY/LA
    Quote Originally Posted by MonzaA4 View Post
    those are 19x8.5 et 45 so pretty close to the oem 19's
    My Build Thread
    @D3ADBOLT_
    @EUROGRADE_
    May 15 2017
    Montreal
    This looks great. i want this kind of fitment. Any fender mods? any rubbing?
    - - - Updated - - -
    also, for reference does anyone have on hand the specs of the oem 19's ? #lazy
    Jan 15 2010
    Palo Alto, CA
    ECS 12/17.5 here as well. IMO this is the perfect sizing for OEM wheels.
    Active Member One Ring stephan_sv's Avatar
    May 16 2016
    Puerto Rico
    15mm front & 20mm rear
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Do you guys mean 12.5 ECS spacers? ECS doesn't make a 12mm spacer that I can see.
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    May 16 2016
    Puerto Rico
    Aug 29 2014
    NY/LA
    Quote Originally Posted by TW60 View Post
    - - - Updated - - -
    No rubbing for me. Didn't have to roll my fenders. tire specs are 235/35/19
    I believe the oem are 19x8 et 49
    My Build Thread
    @D3ADBOLT_
    @EUROGRADE_
    Nov 21 2012
    Deer Park, IL
    Quote Originally Posted by Mattgfx View Post
    CORRECTION: I am using 12.5mm in the front, not 12mm. You are absolutely correct, my bad. Here is the link:
    https://www.ecstuning.com/b-ecs-part...403ecs02a13kt/
    Nov 21 2012
    Deer Park, IL
    And here's another shot of the fronts with the 12.5mm's:
    Established Member Two Rings PsiBlast's Avatar
    Jun 08 2015
    0.5" difference in width = 12.7mm. So half of that would be 6.35mm. Then add the 4mm difference in offset and your wheels (w/out spacers) is the equivalent of running the stock wheels with a 10.35mm spacer all around.
    2016 Audi S3 Premium Plus | Sepang Blue Pearl Effect / Black Interior | Technology package | 19" Performance package | Bang & Olufsen Sound System
    MSS Sports Fully Adjustable Spring Kit | SuperPro 24mm rear sway bar | SuperPro front end links | SuperPro rear end links | 034 Motorsport rear subframe mount inserts | 034 Motorsport dogbone mount insert | Resonator delete
    Oct 25 2008
    15mm spacers on all 4 corners. EBay seller rdcobra91. They are hubcentric don't vibrate and come with Lug bolts. $85usd
    15mm up front looks perfect imho (have to see it in person, pixs don't do it justice), but I rub with a combination of a hard turn + hard braking. I still have 10mm in rear, it was rubbing like crazy with the PSS tires until I added a decent amount of negative camber. I have the 15mm's for the rear on the shelf, been tempted to try them out, but no time. zero rubbing in the rear with 10mm in all conditions now.
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    2007 Audi A3
    Atlanta, Georgia
    Hey guys,
    Running OEM 19" wheels and put the ECS 12.5 mm in front and 17.5 mm in the rear. I think this the prefect setup and has really made the car look mich better.
    Sep 28 2010
    '18 S4, '16 SQ5
    Winston Salem NC
    May be the incorrect wheels, but might help someone eventually. 10mm front and 15mm rear...
    NO.-6054 by Audiyos, on Flickr
    NO.-6056 by Audiyos, on Flickr
    Established Member Three Rings sean_entrust's Avatar
    Feb 11 2017
    Portland OR
    I'm running 12mm up front and 15mm. If I could do it again I would do 15mm up front and 20mm out back.
    2017 S3 P+ (Mine) Daytona Gray Pearl / Black Optic / Carbon Fiber Package / 034 springs / Stoptech BBK / 12.94 @105.3mph stock
    2012 Q5 P+ (Wife) Ibis White
    Active Member Two Rings s-line.B8's Avatar
    Dec 23 2016
    Utah
    I'm at 17s all around, OEM wheels
    Sent from my iPhone
    Established Member Two Rings Dcferolino's Avatar
    Jan 10 2015
    Salinas, ca
    Quote Originally Posted by stephan_sv View Post
    Are you using hubcentric spacers? What kind and what brand if you dont mind me asking?
    Mar 08 2015
    OEM 19" wheels -- 15/20
    OEM 18" wheels -- 12/15
    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    I'm running ecs flush kit (10 front/ 17.5 rear). TBH, I'd go for at least 12.5 front if not 15. The 17.5 rear is fine though. Although I believe you can go 20mm without issues.
    Sent from my STV100-1 using Audizine mobile app
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    May 15 2017
    Montreal
    So i went with 20mm rear and 17mm front due to availability with a local dealer and not wanting to wait. Will post some pics of the result, lowered on 034 springs and no rubbing at all.
    May 15 2017
    Montreal
    dirty....
    aaaaaand clean :D
    Jul 18 2017
    Quote Originally Posted by S3owner View Post
    ...did you lower the car with springs?
    Jun 16 2016
    Ontario
    Quote Originally Posted by brianlyoung View Post
    Yes, H&R sport springs.
    Instagram
    Mar 14 2014
    E46 M3 [sold] | Audi RS4 [sold] | 2010 GTI [sold]
    Northern Ohio
    that looks very nice. 17/20 looks perfect IMHO.
    2015 Sepang S3
    APR Stage I [ ECU & TCU ]
