Results 1 to 12 of 12
    Established Member Three Rings edb8s4's Avatar
    Feb 19 2017
    New York
    Changed control arms
    Changed control arms and it's still making the same clicking and knocking noises it was making before I changed them after everyone that looked the car said it was the control arms any suggestions guys thank you
    Ed
    Apr 26 2017
    Dubai, United Arab Emirates
    I think it could be the shocks or the front sway bar could be the problem. Try using some silicon around bushings and makes them fit in a little easier.
    Active Member One Ring creekwater's Avatar
    Jun 24 2017
    Denver
    Im having the same issue!! i replaced all control arms, Sway links, tie rods, cv axels and wheel bearings and still have a weird noise up front!!! Any advice?
    Jun 24 2017
    Denver
    I put new bilstien shocks and eibach springs all the way around also..
    Feb 19 2017
    New York
    Quote Originally Posted by creekwater View Post
    Idk what to tell you man same happened to me no one seems to know anything. Audi keeps saying it's the controls arms even after replacing them. Just do what I did and get you a new car lol
    Ed
    Established Member Two Rings vw754's Avatar
    Jan 18 2008
    stoke on trent
    try shocker top mounts ??
    anti-roll bar bushes ??
    Jun 24 2017
    Denver
    I just changed my motor mounts and snub mount and the front end is quiet!!! Its been 3 days so hopefully i found the culprit
    Established Member Two Rings SimbadCA's Avatar
    May 11 2016
    Audi TT (MK1, 8N) Quattro
    Camarillo CA
    Iím also replacing my LCA bushing. Presently the LCAs have aluminum outer sleeves on the original bushings.
    Do I re-use or replace these sleeves?
    Do the power flex bushings come with the sleeves?
    Feb 19 2017
    New York
    Quote Originally Posted by SimbadCA View Post
    They should come together I believe with the sleeve that youíre mentioning, if Iím correct thatís what makes the bushing
    Ed
    May 11 2016
    Camarillo CA
    Quote Originally Posted by edb8s4 View Post
    Ed
    Iíve confirmed with Powerflex USA, that the complete OEM bushing should be removed. The Powerflex solution does not require the use of the outer sleeve...their solution does not require it.
    May 11 2016
    Camarillo CA
    For the front LCA, the nuts and bolts are being replaced. Why would the rear LCA bolt not be self locking, while the nut on the spindle for the strut is self locking? Should I be concerned?
    Established Member Two Rings Eclemente's Avatar
    Apr 19 2016
    Kings Park, NY
    I had clicking - ended up being rear axels
