Results 1 to 18 of 18
    Established Member Two Rings wam22's Avatar
    Feb 23 2017
    chicago
    2018 Audi S5 Wheel Offset
    I am looking to buy winter rims/tires for my B9 S5 and I can't find the offset and the service department does not have any info either. Was wondering if anyone here knows the 19" wheel offset (I know it is 19x8.5 and 5x112) or wheels I can find the info?
    Audi Customer Experience Three Rings Audi USA's Avatar
    Mar 24 2017
    Auburn Hills, MI
    Hi, I would be happy to engage the parts department at your local Audi dealership. Can you send me a PM with your full name, mailing address, phone number, email, and VIN.
    Vincenzo F.
    Audi Social Community Manager
    Feb 23 2017
    chicago
    I work for an Audi dealer. No one there can find it out.
    Apr 05 2012
    Earth
    I've been told by a few dealers and tire shops that they're identical to the B8 offsets.
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by wam22 View Post
    Expect a PM from me.
    Vincenzo F.
    Active Member Two Rings CAT3's Avatar
    May 03 2017
    Farr West/Utah
    would like to know the answer to this as well
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by CAT3 View Post
    For 8.5J x 19 W032, 5-spoke Ramus design winter wheel in gloss black, the Offset is 32.
    Vincenzo F.
    Sep 01 2017
    Franklin Pennsylvania
    perhaps an answer to your question will help with a question I posted just today. I am anxiously awaiting delivery of a 2018 S5 coupe. I am not at all fond of the (only available) wheels when ordering the all-season tires. I'm looking to replace the wheels, but would like ones that accept the Audi center logo cap. Do you know if such a wheel is available?
    Jim Hanna
    Franklin PA
    jamesphanna2@msn.com
    Mar 24 2017
    Auburn Hills, MI
    Quote Originally Posted by Jim Hanna View Post
    Jim Hanna
    Franklin PA
    Hello Jim. I am going to look into this a little further for you and see if I can uncover anything.
    Vincenzo F.
    Dec 06 2017
    2017 Q7 S Line, 2004 A4, 2014 Jetta
    Mississauga ON
    Quote Originally Posted by Audi USA View Post
    I have a 2018 S5 Sportback, and would like to know what Audi has to say about the offset. The various on-line tire resellers websites show offsets that vary by site but I have found a range of 29-35. I have new snows made up with 35 offset, but they are against the front caliper. I measured the actual offset, and it is indeed 35. I did a rough measurement of the factory wheels (eyeballing the tape without removing the tire), and get 42...so something is wrong with the data produced by Audi and provided to the tire resellers. I will also call my dealer but am not holding my breath on receiving a trustworthy response.
    http://www.audizine.com/forum/images/smilies/s5fan.gif
    Dec 06 2017
    Mississauga ON
    Quote Originally Posted by Steveofthenorth View Post
    The dealer just said the offset is 32 according to their records, but they are specing out 31...with no problems! So...how can that be?
    Apr 07 2010
    2015 VW Sportwagen Diesel
    Southington, CT
    1 mm difference is so small that it probably makes no difference
    Dec 06 2017
    Mississauga ON
    Quote Originally Posted by ManyAudis View Post
    Yes. I meant how come my 35 offset rim won’t fit? Yet they can get 31-32 to fit?
    Dec 06 2017
    Mississauga ON
    Well I answered my own question. I removed the stock wheel, and the offset is marked as 32. I did not measure it, but its got to be 32. The reason my snows with a 35 offset do not fit is because of the spoke design. The stock spoke "hooks" around the calipers, while the snows I got are linear. So that means the only sure way to know if a rim will fit is to try to install it. I was not aware that you use trial and error. I never had to do that before.
    Dec 06 2017
    Mississauga ON
    As an update, Audi does not care about aftermarket providers of anything Audi makes themselves, including rims for snows. So the aftermarket suppliers are now down to trial and error for specialty or all-new fitments such as the 2018 S5. In my case, I went with 5mm spacers and longer bolts. Problem solved. The Sotozeros grabbed quite nicely in tonight's Alberta Clipper...
    Nov 06 2017
    I have a Rookie question, if I'm going from OEM 18" to OEM 19" do I need to think about the offset??
    Sent from my SM-G950U using Audizine mobile app
    Nov 06 2017
    I forgot to mention that my ride is A5 SB
    Dec 01 2017
    Dallas
    Quote Originally Posted by coupegt7 View Post
    Nope you'll be fine if your going from an A5 18" OEM wheel to a 19" OEM wheel as long as they are both from the A5 platform. If your trying to go to a 19" wheel from say the A3/S3 then it won't work as the center bore is too small. Any OEM wheel that works from the A5/S5 platform will work on your car.
