Results 1 to 4 of 4
    Veteran Member Three Rings audidriver4ever's Avatar
    Dec 20 2005
    Audi A4/B7 3.0 TDI Quattro Tip
    The Netherlands
    Upgrade frontdiscs 2005/B7?
    Hi,
    Is it possible to have more stopping power on the front of my 3.0TDI Quattro? The stockbrakes are good but I like to have more 'bite' and stoppingpower.
    There could be a problem doing that, because I don't want to change from 16" to 17" winterwheels.
    The stockdiscs are 321x30mm (the same as on the 3.2 version).
    I tried Brembo the GT-Kit (330017xx) but thats not gone fit with using 16"
    Any suggestions?
    When someone asks me something, I'll do my best to help in any way I can.
    AudiBlog
    Harry
    Twitter: audidriver4ever & AudiBlogdotNL
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    997S, B7 A4 SLine-Ti, B5 A4...
    Portland, OR
    Re: Upgrade frontdiscs 2005/B7?
    Originally posted by audidriver4ever
    Hi,
    Any suggestions?
    Hi Harry,
    12.6" is about as big as you can fit behind a 16" rim so I'm afraid you're stuck there. Try a better pad set like a Hawk, Mintex red box, or SBS pad set. Also, fresh brake fluid flush with Motul600.
    HTH,
    Jeremy
    Jeremy Williams
    Matrix Integrated Inc.
    Dec 20 2005
    The Netherlands
    Hi Jeremy !
    Thank you for your help.
    I do now know for sure that there are no more options as you mentioned.
    I think I go for that
    AudiBlog
    Harry
    May 27 2004
    Portland, OR
    Hi Jeremy !
    You're very welcome for the help, anytime!
    Let us know if you need help sourcing pads as well. We ship all over the world.
    Best regards,
    Jeremy
    Jeremy Williams
