Page 15 of 15 FirstFirst ... 5131415
Results 561 to 571 of 571
  1. #561
    Established Member Three Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by jokerz View Post
    I have one more all out port usually charge $950 for this but Iíll do $900 plus $550 core swap plus shipping
    With the core exchange program, is there any testing/verification done that ensures we're not getting a blower that needs a rebuild of any kind?
    '15 SQ5 Daytona Gray
    APR stage 2 (93 v4) - Fluidampr w/iABED 187mm - aFe filter/034 tube/modified box - MercRacing stacked h/x - AWE Touring
    21" Forgestar CF10s w/295s - 034 mounts, RSB & end links - ecodes - deAuto LEDs - VCDS - P3
    12.054 @ 113.27 (-224 DA)
  2. #562
    Senior Member Two Rings trip'n's Avatar
    Dec 28 2009
    2000 B5 S4
    just an update that this
    "I have one more all out port usually charge $950 for this but Iíll do $900 plus $550 core swap plus shipping"
    Was sold Yesterday..bitches ..WEG
  3. #563
    Dec 28 2009
    2000 B5 S4
    BGSQ5... Its a good question and Brett AKA Jokerz is a good guy. Seems to care about what he puts his name on and does inspect assembly, rotors and so on-
    He's been at the SC game for some time regarding other platforms and his work speaks for itself-
    He actually respects this (Audi ) community a ton-
    I've only spoken to him once and just grabbed / ordered a unit from him.
    All that being said, like anything else, tune things for more power and shit can go wrong.
    However, the risk is low regarding a properly ported blower IMO. We are not spinning these things full speed 247.
    I'd think a greater risk would be not changing your SC oil every 45,000 to 50,000 or so, but thats just me-
  4. #564
    Mar 14 2016
    doesn't matter
    quick qns for those that have taken the plunge.
    will i need to change the SC oil on the ported blowers before the swap?
  5. #565
    Established Member Four Rings JD S4's Avatar
    May 07 2016
    Boulder, CO
    Jokerz - is there a non-core option? Iíd be worried about trading my low mileage blower for a 120k blower with old oil, 5x mileage rotors and getting whatever snout pulley. What would the turn/down time be without the core? Stoked on the new nasty port.
    Sent from my
    '11 S4 with all the mods
  6. #566
    Dec 28 2009
    2000 B5 S4
    ReD. They come with fresh, makes this Mod a no brainer-
    The interesting thing is, I was informed that GM had posted builtins regarding SC oil. Seems 20/50 Mobil 1 is basically all it is. I am still kind of in disbelief of this as I'd think SC oil to have additives of some short but I'm told this is not the case. Used SC oil smells like SHIT...not sure why that is if its just a 20/50?
    There is also an interesting side note regarding our SC's. Audi actually installed a bearing on our units therefor changing their original design and from what I was told Audi actually has a Patent on this and will NOT let Eton service the units....I am looking to confirm this.
    For one I own Patents and I do not see how any manufacture could take someones design and product, add to it and call it their own. That would mean Eton never had it protected in the first place....Point being not sure if the Audi Factory SC Oil or service part # for the qt's is also different....Who knows
  7. #567
    May 12 2008
    Quote Originally Posted by trip'n View Post
    IIRC its a straight 30 weight.
  8. #568
    Dec 28 2009
    2000 B5 S4
    wee-- No Shit, a bit shocked at that-
    Thanks man
  9. #569
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    is the oil not drained to do the port work?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2 & TCU Tuned / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    THEN THEN THEN Rinse & Repeat!
  10. #570
    Jan 26 2014
    66 Shelby Cobra
    Kansas City, MO
    I did the core exchange and since I wanted to keep my EPL SC pulley, I just swapped my existing SC snout with the ported SC. They are shipped with no oil and Jokerz provided a bottle of oil to fill it up.
    2012 S4 - EPL Stage 2 E85 DP and TCU Tune, 3.25 PR, Jokerz 'Chaos', APR CPS, CTS Intake, AWE Touring Exhaust & Resonated DP's, Tampa AutoSports TP's, Autotech HPFP, AEM Meth, Zeitronix E-Analyzer, CR-15, Trans Mount Insert
  11. #571
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2015 VW GTI SE
    Quote Originally Posted by theweebabyseamus View Post
    I thought someone in this forum posted the GM part number (at 1/3 the price mind you) within the last year?
    /// 2012 S4
    3M CS 50 | RocEuro (44.5k mi) | AWE/GIAC Stage 2 (49k) | Ziza Yellow Fogs | 19" Titanium Rotor Wheels 10mm H&R spacers (58k) | RS5 wave BBK & rear wave rotors (59.5k) | Renn RS-51 19x8.5 20.5lbs (65k) | JHM LW/HD Pulley (67k) | MMI 3G+ rev. G and B8.5 MMI controls retrofit (81k) | black optics grille | vagcom
    Mid-Atlantic Forum (MD/DC/VA)
