Results 1 to 17 of 17
    Active Member One Ring 710motorsports's Avatar
    Mar 24 2017
    Denver
    B7 2.7t swap Ecu tune
    First off, this is my first real post here so bare with me, I am new to the site but have learned so much from other form members, so let me start by saying thanks. I am currently swapping a 2.7t into an 06 A4 Quattro, was a tip car, will now be swapping to 01E 6speed. as the title states I am looking for someone to tune my ECU the motor is and ecu are from an 01 s4. Clint is currently handling the wiring harness like a boss but I need someone who can tune me for 450-500hp. I'll list all mods below. I'd like to keep stock MAF for now unless someone has an RS4 MAF for cheap, I'd like to tune that in if possible. Will post pics as the project continues now I'm just replacing seals, sensors, hoses, painting the motor and accessories, getting the engine bay prepped and painted for the day the turbos and wiring harness is done. PM me if you have experience with costs and precious results??
    01e 6speed
    ECS single flywheel stage 2 clutch
    RS4 KO4s
    SACCS 3-2.5inch Downpipes
    2.5in Straight pipe exhaust
    EBAY BI pipes
    eBay FMIC
    Custom cold air intake
    SAI delete
    Im open to getting more upgrades just not sure what else to get to get me to that 500 mark for sure, open to all suggestions.
    Active Member Three Rings Xplycko's Avatar
    Jan 13 2017
    01 A6 2.7t 6 Speed, Nissan Xterra, Jeep CJ7
    East Tennessee
    I know solo motorsports custom tunes. And you also have Apr and giac respectively. They can all build you what your looking for. Chicago Phantom also has a good tuner.
    Sent from my ALCATEL A564C using Audizine mobile app
    Veteran Member Four Rings jasonsowers's Avatar
    Feb 18 2007
    Porsche Cayenne Turbo
    Denver
    You're going to have to go to you local tuner for support no way would I dare do this over sending an ECU back and forth 40x's for revisions.
    http://i37.tinypic.com/2u637gk.jpg
    2002 Laser Avant that is amazing
    2000 Brilliant Black Stage 3 K04/RS6 hybrid sedan that was just as amazing (sold)
    aka : johndoes4
    aim : johndoe4742
    Dec 10 2011
    S4, E46 M3
    WI ✈ NC
    Items for Sale
    SoloMotorsports
    Blake Beadle @ ETSpec
    @stuklr on the forums
    EPL
    Mirza @ VAG Autowerks
    Quote Originally Posted by jasonsowers View Post
    Email . Can flash the file yourself with the Nefmoto software and a FTDI cable.
    -Hayden
    Mar 24 2017
    Denver
    Okay I'm in Denver, I was pretty sure someone could email me files and I could upload them. I also forgot to add 52lb injectors. If someone here can do it PM me with the cost and how quickly we could get it done
    Jan 06 2009
    First off, budget + build is never a good outcome. Budget + 2.7t + stage 3.....I hope you have lots of free time for tinkering, repairs and upgrades. :-)
    Dave @ Motoza can tune the 2.7t and is likely the lowest cost for an established business. He's also close to you.
    What are you doing for fuel? You won't get to 500hp (crank?) with the stock fuel setup....or stock MAF or stock intercoolers.
    And clutch. What is that ECS kit rated for?
    Are those genuine Borg Warner KO4s?
    B6 2.7t -- F21 MF -- Tuned by Bische --
    B7 2.0t
    Mar 24 2017
    Denver
    Borg warner ko4s yes.
    85mm MAF
    Not sure On clutch kit good question.
    I have plenty of time hence the swap. Who said anything about budget build? Because you saw the word eBay? Ha
    Jan 06 2009
    Your post came off as budget conscious when I read it... didn't mean to offend you...
    Anyways, Motoza is a good option for tuning if you want a somewhat local tuner to you that is very good. It would be remote tuning but at least he would be in the same timezone. If you want a remote-remote tune contact Bische. He is the motronic master.
    Curious what the ebay FMIC is.... The plumbing should be interesting with a FMIC and bitrubo?
    B7 2.0t
    Mar 24 2017
    Denver
    Yeah I think it's going to be a bitch and make me hack the front bumper up, it's basically 2 front mount intercoolers stacked.
    Mar 24 2017
    Denver
    Went ahead and picked up the 034 LWFW, and a new stock RS4 clutch.
    Sep 30 2009
    08 A4, 87 Jag XJ6, Lex RX300, HD Street Rod, Grumman Yankee AA1A
    Indiana
    There seems to be a lot of enthusiasm for the 2.7 L engine. For some of us uninitiated could someone briefly explain? Is it preferable to the 3L? Is it a TC or NA? Guessing it's TC and therefore has a lot more potential than the NA 3 L. Are they factory fitted in some A4s and sold in non-US markets? What ever happened to that narrow angle V6 that VAG was working on years ago? Thanks, Brillo
    Mar 24 2017
    Denver
    No the 2.7 was never put in the A4, it was the b5,b6 s4/a6/all road motor. The 2.7t are actually bi turbos meaning one turbo per exhaust manifold. Not sure what narrow angle v6 your talking about. Unless you mean the vr6. Someone just pushed their s4 with the 2.7 to 530hp 470ft/lb tq with a stock block and stock turbos
    Mar 24 2013
    '01 Chevy 2500HD Duramax
    Griswold, CT
    B6 S4 was a 4.2 V8. Only the C5 A6 and Allroads had the 2.7 as an option.
    -Adam
    Jan 13 2017
    East Tennessee
    Quote Originally Posted by Brillo View Post
    The 2.7t is a bi-turbo engine as mentioned. It has much more potential solely because it is a turbo engine from the factory. Most tuning setups initiate more fuel and boost unlocking said potential. The c5 a6 cars are identical from the 2.7-3.0 save for factory options. Most 2.7 cars are also quattro cars (maybe all) while other c5 a6 cars are fwd.
    Sent from my LGL62VL using Audizine mobile app
    Sep 30 2009
    Indiana
    Appreciate the education. Thanks.
    710motorsports I think it was the VR6.
    Brillo
    Mar 13 2015
    Upstate NY
    There was a B5 Rs4 that was 2.7tt too.
    The vr6 came in 3.2 & 3.6l versions in the Touareg and cayenne. Also a 2.3l vr5 version overseas in b5 passats.
    Sep 30 2009
    Indiana
    I know this is way off topic so apologies ahead of time.
    You motor heads might be interested in an engine I saw this past winter in New Zealand - A Napier Lyon II.
    It's a W-block 12 cylinder engine (3 banks of 4 cylinders each) with twin overhead cam (gear driven), 4 valves/cylinder, two plugs per cylinder (like all good aircraft engines) first built in 1917 - 100 years ago!!
    My recollection is that the NA version put out about 500 HP at ~2000 rpm (1300 pound-feet or torque!) and the turbocharged versions put out up to 1350 HP.
    Displacement was a monstrous 1400 ci. The block was a monolithic aluminum construct. It was used to power over 150 different aircraft and set many land, air, and water speed records for a period of almost 40 years. I had no idea.
    There you have it.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
