Results 1 to 16 of 16
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW ECS Performance Baffled Oil Catch Can System | Audi 8V S3
    Today's direct fuel injection systems have taken engine performance to a new level, but there’s a drawback. With no fuel vapors to clean valves, oil particles will deposit themselves onto the valves and ports. Over time this will result in an excessive carbon buildup, resulting in lost power and poor drivability.
    ECS now has the solution with our Performance Baffled Oil Catch Can System. In-house engineered, our system is designed to collect toxic blow-by gasses, reduce carbon build-up and reduce concentrations of acids, oxidants and water within the engine oil.
    Key benefits of the ECS Tuning Performance Baffled Oil Catch Can System:
    • Highly Efficient Oil Separator (Catch Can):
      *Strategically positioned 4 chamber baffle system maximizes oil / air separation
      *Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
      *Knurled and black anodized integrated oil dipstick makes inspecting oil volume of the reservoir clean and simple
      *Fully serviceable for routine cleaning and maintenance; Includes 2.5mm allen key to remove baffle plates for cleaning
      *-10AN ORB (O-Ring Boss) fittings for leak-free fitting connections
      *6061-T6 billet machined body, anodized black for lasting protection and appearance
      *Easy to drain reservoir, simply un-threads from the oil separator for quick draining or cleaning
    • The OEM Audi fine oil (cyclonic) separator is retained. Due to the retention of this component, the catch can will not have to be emptied as often, as its focus will be on capturing the ultra-fine oil vapor*
    • Engine cover fitment is maintained with no modifications needed
    • Completely reversible installation, as no OEM components are permanently modified
    • OE style appearance once installed
    • Engineered and manufactured in the USA, you can expect the very best performance, quality and longevity with our superior Oil Catch Can System from ECS Tuning!
    Caught in the act
    Fits:
    Audi 8V S3 (2015+)
    Be sure to check out our -----> Installation PDF <-----
    Jason
    sales@ecstuning.com | customerservice@ecstuning.com
    Customer Service Hours: 8:00AM to 8:00PM EST
    Sales Team Hours: 8:00AM to 11:00PM EST
    800.924.5172
    OEM Audi Part Number Search with Pricing<--- Click me!
    Active Member Two Rings mugenr's Avatar
    Dec 30 2016
    Bothell, WA
    Just double checking. Your catch can just adds on to the existing stock PCV system? It doesn't remove it, right? If so, this is what I've been looking for. APR does it, but requires their intake for attachment.
    Sent from my Nexus 6P using Audizine mobile app
    Oct 30 2012
    Arizona
    Looks good. Price is decent too!
    Just ordered mine. Can't wait to get it installed with a couple of other items. Thx ECS for making an S3 catch can.
    2015 S3 - Full OEM RS3 Front End Conversion - CTS BOV/LW Crank Pulley/Turbo Muffler Delete/Throttle Pipe/IC Pipes - Bull X Catless DP - UM STG 2 RED FILE/STG 3 TCU - XBQ/UBQ - HG Intercooler - ST XTA Coil Overs - Black Optics Trim - PURE CF Trunk Spoiler/Mirror Caps/Rear Diffuser - 19x9 GT5 wheels - E Codes - ECS LW Rotors - Blacked Out Roof - Full 3" Valved MF Exhaust - Blacked Out Badges - 034 R/Sway/RSFM - BFI STG 1 Engine/Trans Mounts/Torque Arm - RS3 Vents - 3M Crystalline
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mugenr View Post
    Correct. Our catch can system works with the factory oil seporator/PCV.
    Quote Originally Posted by A20V200 View Post
    Looks good. Might have to pick one of these up. Price is decent too!
    Apprecaite the feed back!
    Jason
    800.924.5172
    May 17 2016
    Hong Kong/LA
    Does it work with GFB DV+ already fitted? Can't tell from the pictures if it would get into the way of the hoses...
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by larbel View Post
    I don't see why it wouldn't work with our catch can.
    Jason
    800.924.5172
    Stage 2 Banner Advertiser Four Rings PK Auto Design's Avatar
    Oct 24 2016
    Sylmar, CA
    Would Audi flag our car TD1 if we install this?
    Avant Garde Wheels | AL13 Wheels | HRE Wheels | More
    Wheels |Tires | Aerodynamics | Suspension | Exhaust
    Shop Phone: 818-408-6989
    Email: Paul@PKAutoDesign.com
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by PK Auto Design View Post
    They shouldn't because it does not change ECU programming.
    Jason
    800.924.5172
    May 17 2016
    Hong Kong/LA
    Jason
    Is it possible to get a group buy going? If I can arrange like 5 to 10 people to get in, what kind of discount could I get and it will be ship in one lot to Hong Kong or China... Thanks!
    Oct 02 2006
    Wadsworth,OH
    Unfortunately, we do not offer group buys. We try and price our products as competitive as possible so everyone can take advantage of the same savings.
    Never hurts to ask though!
    Jason
    800.924.5172
    May 17 2016
    Hong Kong/LA
    Ok. Ordering with a friend and he has GFB DV-X, you said DV+ would fit but how about DVX? Thanks!
    Oct 02 2006
    Wadsworth,OH
    You won't have any issues installing the catch can and a diverter valve upgrade.
    Jason
    800.924.5172
    May 17 2016
    Hong Kong/LA
    Jason... question... I just got the VWR turbo inlet elbow and it won't fit with the PCV hose's adapter, the 90 degree bend hose is too tall and touching the firewall when fitted... Do you guys have shorter/sharper turn adapter for the hose? Thanks!
    Oct 02 2006
    Wadsworth,OH
    Unfortunately not at this time. I can mention it to our engineers and see if they are willing to offer a revision.
    Jason
    800.924.5172
    Feb 18 2016
    Infiniti QX60
    SD
    Jason
    What is the advantage of this? I have seen other kits like the CTS that replaces the whole thing.
    Dec 23 2016
    Savannah Ga
    Jason
    Will your catch can have the same fitment issues with the APR turbo inlet?
