Results 1 to 3 of 3
    Established Member Two Rings angrypanda's Avatar
    Feb 03 2017
    Halifax, Nova Scotia
    Seized trunk button
    Can't push it. Power locks make the right noises, but button won't go in. Pushing hard enough to flex the rear panel... Thought about using a hammer but decided to wait until I could use it strategically instead of angrily.
    Is my destiny crawling in the trunk and trying to remove the inner liner to get at the mechanism? Is that even possible to do with the lid closed?
    Established Member Two Rings SteveAudi99's Avatar
    Jun 28 2013
    ontario
    Yes you can access from in the trunk. Been there done that. Bring a flashlight and some snacks. Screws are Philips holding the panel on. Some good old trunk spelunking. I would try that before possibly damaging your trunk. Try some penetrant on the outside and let it soak
    Sent from my Pixel using Tapatalk
    Established Member Two Rings dalazybastard's Avatar
    Apr 08 2016
    '01 A4 1.8tqm '01 A4 2.8qm
    Orange County, CA
    Like said by SteveAudi99,
    The panel is the the lower "kick" panel at the entrance to the trunk. The Phillips screws are a decently small size so be careful not to strip them.
    Play with the latch with a screwdriver and to get your trunk open. From there you'll be able to try to fix latch by removing the larger panel on the trunk itself.
    '01 A4 1.8tqm (Pseudo-Daily) Light Silver Metallic
    stg 1 APR 91 -Stock 100k Original Slipping Clutch - BBS RC326 w/ PS A/S3+
    '01 A4 2.8qm (Daily) Brilliant Black
    17" Celebrations w/ PS A/S3+
    '05 Passat 1.8t 4mo. Wagon ***sold to parentals
