Results 1 to 27 of 27
    Jul 28 2015
    New Brake Pads for RS5, street use only
    I know there have been a variety of threads on this, but decided to start a fresh one since many are looking for advice for track use. I'm in a 2015 RS5 with 23K miles, and my OEM pads still have some life left but I really want something with more bite. The guy I use is suggesting Stoptech saying they make a good compound (can't remember the exact pad) for the street, but also said there will be some noise (which I can't stand) and dust. Don't care as much about dust, but can't understand whether it's worth it (around $480 for a full set installed) or really if I'll get that much more bite out of them. I'm willing to tolerate some noise if I'm getting a considerable bump in bite. I know many people here have also used Hawks with varying levels of satisfaction, but really what I'm looking for is a pad with a decent upgrade in bite than OEM but also isn't going to sound like a Kenilworth jake brake. Thanks for thoughts/suggestions.
    Veteran Member Three Rings dazed1's Avatar
    Jan 18 2013
    SF Bay Area
    Stoptech 309. I've used them on the street, and for a low braking track event as well. Cheap, reliable, low dust, no noise.
    Mar 08 2013
    2013 RS5 Cab / 2015 Q7
    Southern Illinois
    Comparable usage/ life span? better or the same stopping "feel"?
    Quote Originally Posted by dazed1 View Post
    Jan 18 2013
    SF Bay Area
    Quote Originally Posted by ICU2 View Post
    Better stopping. Longer life is debatable as I had track use in it and I'm pretty harsh on braking in general. For the price point, and compared to OEM, they are much better.
    - - - Updated - - -
    Also as comparison, I run Pagid RS29's on the street (too lazy to change after track days). So my bite point and braking feel is much different.
    Jul 28 2015
    Thanks for the feedback - I ordered the Stoptech 309s and will see how they fare.
    Oct 21 2009
    OC CA
    Please update, I'm at 29k miles and still on OEM pads myself....
    Jul 28 2015
    So I got the stoptechs installed today and they'll need some break in time, but already I can see where they will perform better than oem. More importantly, when I got my old pads removed they were about 40%, but the hardware in the pic below was at a near breaking point and had to be replaced. I'm a little surprised at this after 23k miles?
    Active Member Two Rings SoCal_OOOO's Avatar
    Apr 10 2016
    Southern California
    Dumb question... what is that?
    Jul 28 2015
    Beats me lol.. I just assumed you guys knew. Mechanic said it was some kind of rod, forgot the name
    Jul 28 2007
    RS5
    Its the pins that hold the pads in places.
    Senior Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    How were they near breaking point? Or are they just saying that because it's covered in gunk?
    Jul 28 2015
    I'm not sure if those are the same pins. I actually called the guy and asked and he will send me a diagram of what it is. He said something like they are the pins that connect the calipers to the rotors. I will scan it and upload tomorrow. They were definitely in bad shape - not just rusty but almost coming apart. Strange for a relatively new car.
    Jul 28 2007
    RS5
    The rotor and the caliper are not connected, the caliper is mounted with two bolts to the wheel bearing housing/wheel hub, the rotor is mounted to the same with just a screw to hold it in place. I'm pretty sure it's got to be those pins, can't see what else they would be...
    Jul 28 2015
    Yes my mistake, Spa is correct. Here is a diagram of the assembly - also, fyi, an Audi dealership told me they charge $50 for each pin, which seems ridiculous at best.
    Jan 18 2013
    SF Bay Area
    Yup. that is the brake pin. They'l be fine, and you don't need to replace them.
    Aside from that, how are the pads now that you've had them for a few days?
    Jul 28 2015
    I saw the condition of my brake pins and the ones on the front left were almost coming apart - it was pretty surprising. As far as the pads go, I am not seeing dust or hearing noise. In terms of performance, I am feeling some improvement - but to be honest, I'm not sure whether it's enough improvement to have justified the cost of the switch, and I hoped for maybe a bit more grab out of them. But there is definitely some improvement over the OEMs.
    Jan 18 2013
    SF Bay Area
    Quote Originally Posted by PeregrineNYC View Post
    They are cheaper than OEM pads. So it would still seem worth it IMO.
    Jul 28 2015
    Bump on this with an update - as the pads have broken in they've improved quite a bit in performance. Much more grab now and well worth the purchase.
    Jan 18 2013
    SF Bay Area
    Good to know!
    Jan 18 2013
    SF Bay Area
    I just switched from my pagid back to the stop tech 309. I cry for bite every time I have to brake, but at least I do not have any more squeaky pads!
    Jul 28 2015
    Give it some time and see how they break in. Curious as to your evaluation over time.
    Mar 08 2013
    Southern Illinois
    So a "better" feel than OEM for stopping & grab, what ~ brake dust? More dust, ~ the same or less dust?
    Jan 18 2013
    SF Bay Area
    These are broken in. But i'm going to wait for them to reshape on the rotors. I've used them before and like it, but compared to Pagid RS29, these are no comparison.
    Much less brake dust than OEM.
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    I just purchased a set of Hawk HPS pads so will report back. The only others I've had are oem, and carbotech 1521. Carbotech
    1521s were becoming complicated to source but i absolutely love them. Hoping the Hawk HPSs don't disappoint.
    2013 SUZUKA GREY RS5
    Eventuri intake + Slam Panel / Milltek non res / 034 Rear Sway and diff inserts / H&R Springs/ 20x10 Volk TE37 in Michelin PS4s
    2015 MYTHOS S4 (Black Optic)
    2008 AVUS RS4
    2004 IMOLA S4
    Dead
    Veteran Member Three Rings Reggie's Avatar
    Feb 27 2005
    11' 3.2Q5 2015 RS5
    Fort Collins Coloardo
    I went with Centric Posi Quiet semi-metallic brake pads for my RS4 and the RS5. Very low dust and quiet pads for the street. https://www.zeckhausen.com/catalog/p...roducts_id=471
    Mar 08 2013
    Southern Illinois
    Thx for posting Reggie & forgive my ignorance, what does the shading in the heptagon represent? Estimated Mileage, braking cycles, calendar mo's/years in overall usage? Have you used them B 4? Totally unfamiliar w/these so again forgive my ignorance. TIA for your reply.
    Sep 02 2011
    Chicago
    Quote Originally Posted by jdmnomore View Post
    Whats the verdict? I'm at 25k miles and I'm shopping around.
