Results 1 to 12 of 12
    Senior Member Four Rings Mattr567's Avatar
    Mar 20 2016
    Prefacelift A4 Vanity/Sun Visor Bulb Type?
    Doing a LED retrofit. Looked everywhere and can't find the answer. Facelifts have them set up in a different way.
    Can't find the thread anymore but they were apparently 3610 type bulbs but I can confirm they aren't. Bulb says "Phillips 12V3W 8J5 Made in France"
    Bottom: Bulb I took out of the vanity light
    Middle: The 3610 it was supposed to be
    Top: LED 3610 replacement.
    The most base A4 in the world
    99.0 B5 A4 1.8TMS
    APR 91 | Forge | APR Catback | Valeo SMF | Bilstein Sports | Eibach | Neuspeed RSB | B5 S4 TRE's | 034 Snub | OEM Strut Bar | Ebay SS w/ Pushdown Delete | 2.0T Coils
    BBS | Podi | DDM HID | OEM RS4 Grille | Euro Mirrors | Facelift stuff | Sport Cloths | Euro Trunk | Valeo E Code
    Senior Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '94 Cummins Ram, 2007 City Jetta
    Victoria, BC
    You should be able to measure the overall length (point - point) and contact diameter, then find the equivalent 3W festoon bulb to replace it with.
    This is what SuperBrightLED says it is for my '98. A #578 44mm Festoon
    https://www.superbrightleds.com/more...44mm-car/3582/
    '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 Tune - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS (Facelift) - VW 18" Bristols - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Mech. Boost Gauge + POD - K&N Cone Filter
    Build Thread HERE
    Mar 20 2016
    Quote Originally Posted by Pringle420 View Post
    Sadly that doesn't look to be it. I actually have one of these, just a slightly different version with glass around the LED (https://www.superbrightleds.com/more...-car/237/1123/). It goes in the center of the overhead unit.
    I measured the length of the original bulb and its around 35mm.
    Socket:
    578 44mm in comparison:
    99.0 B5 A4 1.8TMS
    Mar 20 2016
    This one perhaps? Has to be thin enough to fit into the socket.
    https://www.superbrightleds.com/more...42mm-car/2037/
    99.0 B5 A4 1.8TMS
    Oct 31 2015
    Victoria, BC
    If the bulb measured around 35mm, I think this would be a better bet, a 6418
    https://www.superbrightleds.com/more...-36mm-car/233/]
    Or, according to the bulb finder a 3710 (not 3610) will work.
    https://www.superbrightleds.com/vehi...=347&year=1998
    Build Thread HERE
    Mar 20 2016
    The 3710 is a better bet since it's thin, the 3610 is too thick. Also tried that one.
    https://www.superbrightleds.com/more...car/2161/4950/
    Sent from my A0001 using Audizine mobile app
    99.0 B5 A4 1.8TMS
    Oct 31 2015
    Victoria, BC
    Again, according to the bulb finder, It's the same bulb as the glove box bulb. So maybe pop it out and test it. Then you can order a few and replace them all at the same time.
    Build Thread HERE
    Mar 20 2016
    The glove box is 3610, I know it doesn't work. Bulb finder isn't correct. Facelift vanity is probably 3610. Or 3610 is the right one for the socket but because of the location it doesn't physically fit.
    3710 looks to be correct.
    99.0 B5 A4 1.8TMS
    Dec 05 2007
    This was before companies started to really make the LED kits for our cars.
    http://www.audizine.com/forum/showth...?highlight=led
    Oct 31 2015
    Victoria, BC
    Quote Originally Posted by Mattr567 View Post
    Ya, I am always sceptical of the Bulb Finder
    Build Thread HERE
    Mar 20 2016
    Thanks a lot. That's the thread I couldn't find. It was what I based my original set on.
    From the discussion the prefacelift vanity lights they are 36mm with thin bases. The 3610's I have don't work since the glass casing makes it too thick. A thin 3610 (which I can't seem to find? The non glass ones have a heat deflector that might be too large + pcb size) or a thin 3710 (but might be too long) would work.
    99.0 B5 A4 1.8TMS
    Dec 05 2007
    Just pick up a cheap ebay complete set.
