Results 1 to 40 of 40
    Active Member Two Rings westCOA4's Avatar
    Mar 16 2017
    Fruita,Colorado
    Newbie to the B7 sorry for the noob question.
    So my story begins,
    I bought a 2007 A4 2.0 awd 6 speed MT sline for $1250 (1000 if it doesn't need a bottom end). Its a one owner car with 105000 on it.
    Guy pulls into his drive way one night then goes to start it the next morning and crank no start. Indie shop tells him timing is off and needs the head rebuilt. I buy the car, tow it home, remove the valve cover and turn it over while watching each cylinder with a bore scope. We notice the intake cam isn't turning, figure broken cam chain, pull the rear cover and the chain is still on both gears, rotate engine and watch the intake cam gear just spining on the intake cam.
    I removed the intake cam while leaving the exhaust in. I am replacing the intake cam, follower, chain and tensioner. My question is is there going to be enough slack in the chain without the exhaust cam valve adjuster removed to re time the cams?
    Established Member Three Rings wriscolf's Avatar
    Jul 10 2016
    1993 Nissan 240sx Convertible with Silvia Front
    I have no clue on the machanic end but you just bought a Titanium edition for 1,250. Nice pick up. Even if you get a brand new motor, i think you still winning. I would suggest check electrical but since you are manually spinning motor, it doesnt seem like its that. Good luck.
    Just to add. Last time my car didnt crank over after being fine was the relays under ECU. but again i doubt its that since you are seeing things not working.
    2007 Audi A4 S-Line Titanium Edition/Phantom Black/Magnaflow Exhaust/APR Stage 1/APR Carbonio Intake/Lots of Headaches/
    Established Member Four Rings yxri's Avatar
    Dec 27 2016
    Milwaukee Wisconsin / Detroit
    Surprised their is such a stress crack. Wouldn't think that would be the problem. Good catch and Nice car as Wrisolf said.
    Mar 16 2017
    Fruita,Colorado
    Quote Originally Posted by yxri View Post
    The crack goes all the way thru the cam gear and the gear just spins on the cam.
    Mar 16 2017
    Fruita,Colorado
    Quote Originally Posted by wriscolf View Post
    How can you tell it's a Titanium edition?
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 15 2011
    07 A4 2.0T Q 6MT, S-Line, Ti Pkg, Black, 08 xB, 13 Ex Ltd
    those are the wheels that come on a titantium...
    is the interior trim piano black, the roof line anthracite (black/charcoal), red stitching on the steering wheel?
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | OEM DV Upgrade | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Podi Stepper Boost Gauge | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Mar 16 2017
    Fruita,Colorado
    Quote Originally Posted by mcpcartier View Post
    Does this look right?
    Senior Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    ^^Definitely a TI package car, those always make me jealous haha!
    2005.5 A4 2.0T Brilliant Red | 6MT | Quattro | S-Line
    Go: K04 | ST Coilovers | Carbonio | Maestro | S3 Injectors | IE Rods | JHM FMIC | Autotech HPFP | ECS Short Shifter | JHM Clutch | USP HFC | Quad-tip Exhaust | S4 Brakes
    Show: DTM Rear + Skirts | Recaro | Black Miro 111 19" | RS4 Grille | Votex Spoiler | OEM CF Trim | S4 Mirrors | Black Ext. Trim | CC + Joey Mod Bixenons | LED Tails | A8 Rings | RNSe | 20% Tint | 034 Adj. UCAs
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Damn what a steal. Mine was cheaper at $1000 with timing belt damage. Anyways one thing to look at is take the valve cover off and crank to tdc on cylinder #1. And look at the cam lobes in the rear they should be parallele to eachother. If is out of time then forget it. Either way what ever you do buy the chain, tensioner, cam follower,all new gaskets, and when you put it to tdc take a pic of the camshaft and let us see.
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    CANADA
    Items for Sale
    I'll have an oem intake cam out of my car soon. If you need one I'll sell it to you on the cheap!
    4 turbos (soon 5), 2 motors, 1 B7 A4
    Mar 16 2017
    Fruita,Colorado
    I removed the intake cam while leaving the exhaust cam in with the timing belt on. I am replacing the intake cam, follower, chain and tensioner and all new bolts for the cam cradle. My question is, is there going to be enough slack in the chain without the exhaust cam valve adjuster removed to re time the cams? I am assuming that I can install the new tensioner ( leaving it compressed) put the new chain on the new intake cam and over the exhaust cam gear, and this when things get a little confusing. How I am I going to time the cams and secure the cam cradle? I saw a post in here where this has been done before but it goes "old intake out then new intake in with cam cradle".
    Established Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I can't help you but just wanted to say what a steal you got!!
    Eric
    2005.5 6mt A4 2.0(red T ) Silver metallic outside, Platinum inside.
    Jul 10 2016
    Quote Originally Posted by westCOA4 View Post
    Wheels, the blacked out grill, the door doesnt have chrome and black interior. Unless prev owner did all that which i doubt since car looks stock and owner quit on car rather fast.
    I also have the same exact car. From the pictures, i can tell its a phantom black also. ;)
    Mar 16 2017
    Fruita,Colorado
    Thank you for all the info, like I said newbie to the Audi game.
    Sent from my VK815 using Audizine mobile app
    Mar 16 2017
    Fruita,Colorado
    Quote Originally Posted by pezgoon View Post
    I am trying to explain this to the wife but hard for her to grasp since its not running but the parts will be here tomorrow then I have to wait for the sealnt on the cam cradle to dry. I didn't see any bent valves with the bore scope at least exhust side and all the intakes were fully seated so we will see. I figured it was worth the gamble..
    Established Member Two Rings enizi's Avatar
    Dec 22 2016
    Hell of a deal, even if you need to buy/rebuild a motor for it
    Mar 16 2017
    Fruita,Colorado
    Installed new intake cam, follower,chain and tensioner. Put 50 miles on it today.
    Feb 10 2012
    parts
    CANADA
    Items for Sale
    Awesome!!!!
    Jun 15 2011
    2008 audi A4 06 Mini cooper S "Torro"
    cville,VA
    And that makes you less noob than 90% of us here. That's a steal. I'll give you double what you paid for the car. :)
    08 ibis white A4 quattro 6 mt s-line l APR stage 2 l HPFP fuel pump upgrade l RAI downpipe with high flow cat l custom quad exhaust with S4 valance l ECS snub l ECS ultimate catch can l 034 RSB with adjustable end links l 18Z with EBC yellow pads l ss brake lines all around l B6 S4 aluminum mirrors l tint l Vfiz l Carbonio l GFB l bunch of audio stuff l VMR v710 19x8.5 l Lightwerks retro HID headlights l ECS LED tail lights l S4 Recaro l other things I am forgetting l
    Oct 15 2011
    nice....enjoy her...
    Mar 16 2017
    Fruita,Colorado
    Just rolled 150 miles and got a CEL with code P2181 engine cooling system performance. Screen shot says 162 degrees.
    Jun 17 2013
    jersey city nj
    Items for Sale
    Thermostat
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
    Mar 16 2017
    Fruita,Colorado
    ....How fun
    Jun 17 2013
    jersey city nj
    Items for Sale
    ....How fun
    Welcome to Audi ownership.....
    Mar 16 2017
    Fruita,Colorado
    Super cool oil filter design too...not. It has definitely been fun to drive though.
    Jun 15 2011
    cville,VA
    Quick question for you. As you were replacing (or maybe you didn't have to ) your cam chain and tensioner,did you take off exhaust camshaft adjuster bolt? And if so....does it come off clockwise or counter clockwise? In other words while the engine is in and you are standing on the passenger side did you pull your breaker bar or push it? I know this seems silly but I've read contradicting info and want to make sure I don't mess it up.
    Mar 16 2017
    Fruita,Colorado
    Quote Originally Posted by z_wrecker View Post
    Are you just replacing the chain and tensioner? If so then you would pull on the adjuster bolt standing on the passenger side. I had a crack thru the intake gear and had to replace it. After looking at both option i.e removing the timing belt, and the exhaust cam adjuster and possibly stripping the bolt or breaking one of the seals in the adjuster I chose to remove the cam cradle and not touching the timing belt or exhaust cam adjuster.
    Jun 15 2011
    cville,VA
    So pulling it would mean it comes off clockwise. Ok great! Thanks!! Yes I am just replacing the cam chain and tensioner.
    Mar 16 2017
    Fruita,Colorado
    If standing on the passenger side and pulling towards you would be counter clockwise I always base it off if I am looking directly at the bolt.
    Jul 25 2016
    new hampshire
    Hmmmm no that would be clockwise, counter would be pushing it
    Unless you've got right hand drive then your correct
    I drew you a picture
    Ignore the baguette 🥖 of a ratchet, but you should understand pretty well
    I've no idea which way it needs to turn, but that's which way would be clockwise and counter clockwise
    Eric
    Jan 13 2017
    Score on a good deal....good luck with it.
    Jun 15 2011
    cville,VA
    This picture should be in every DIY! I was under the same impression that pushing it would loosen it, but I've read a few threads where people said they pulled on it rather than pushed
    Mar 16 2017
    Fruita,Colorado
    Yep I was confused
    Mar 16 2017
    Fruita,Colorado
    Wow I was totally off on that
    Jun 15 2011
    cville,VA
    I do the same thing you do. Visualize myself behind the bolt....or take a ratchet and put it in the same position so I don't just BDA (Big Dumb Animal) the crap out it
    Yep I was confused
    Jul 25 2016
    new hampshire
    Haha, thank you thank you *bows*
    Yep I was confused
    I do the same as well in both respects that's why I wanted to draw it out to clarify it, often times I just do the ratchet in my hand like you said to make sure it's heading the right way
    I just wanna clarify, pushing the bolt may loosen it, I make no claims as to knowing whether the bolt is regular or reverse threaded, I simply wanted to show which direction was clockwise and which direction was counter clockwise
    Again, you both may be right that pushing it loosens it \_(ツ)_/
    Eric
    Jul 10 2016
    Oh my god! look at the definition on the bolt! this should be hanged up in a AZ hall of fame!
    I am happy my twin in Colorado is up and alive!
    Jul 25 2016
    new hampshire
    Hahahaha that's hand drawn too ain't no MS paint trickery
    I almost redrew it cause the ratchet came out so terrible, although I was thinking of my 3/4" ratchet since everyone says the bolt is so tight and then realized halfway through that it is not representative of what most people have for the biggest ratchet (1/2") haha
    I even drew the socket to look like this socket
    https://www.europaparts.com/camshaft...metalnerd.html
    That took me some time man! I was thinking about getting more detailed in the engine bay too but I figured it worked
    Eric
    Jul 10 2016
    You know what! I see it now! oh wow... Lets put this in The Met (Metropolitan Museum of Art) in NYC!
    lol Pezgoon. You one cool dude. lol
    Jul 25 2016
    new hampshire
    Hahahaha I could use an additional source of income
    Eric
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
