Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Dec 28 2006
    2003 A4, 2009 CC VR6 Sport, 2013 A5 B8
    Western Maryland
    Items for Sale
    Playing With Fire
    I took a vacation day today to perform a few general maintenance items on the B6. It didn't take as long as expected so i decided to play around a little with my Unisettings just to see what would happen. I turned the Channel 9 Ignition Timing Additive Offset up 5 clicks. Each click equals .75° so the total increase was 3.75°. I wasn't expecting anything dramatic.
    I got the engine up to temperature and did a hard 2nd gear pull. My butt dyno said "Holy Shit!!" I was monitoring my MAF g/s with TorquePro by placing my cellphone in the cupholder. A quick glance showed 235 g/s. Using a .8 conversion factor from g/s to chp indicates 294 chp. It really caught me off guard. I wasn't monitoring anything else like the A/F ratio or the CF's so I immediately set it back to where it was originally.
    I might play with it a little more this weekend and do a full log with the Motoza logging function to make sure I'm not doing something really stupid. Actually doing anything at all is probably really stupid since it's a high mileage daily driver that I would like to run another year or so before replacing it. But dayum, it sure felt nice!!
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / FT High Flow Exhaust Manifold / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi Boost Gauge
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint
    Veteran Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    2002 GSXR 600
    Paramus,NJ USA
    You will need at least a A/F gauge to monitor under load make sure car is not running lean.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicle.As well as SKC/Pin retrieval services.Located in Northern NJ.For inquries pm for details.
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by EuroxS4 View Post
    TorquePro will give me the instantaneous A/F ratio. However, the sampling rate is pretty slow so I'm sure how much I can trust it.
    Jan 24 2010
    2002 GSXR 600
    Paramus,NJ USA
    Your probably better off with a stand alone gauge to be honest.All depends on your goals.
    Veteran Member Three Rings agentsmith988's Avatar
    Fry Sauce, UT
    I think we're pretty similarly spec'd. On my current (final) revision from Dave, I hit 235-237 g/s. It surprised the crap outta me when I took a look at the logs. Didn't you say you were running a bit more on the conservative side with your tune?
    - Steve
    USP CLUB MEMBER #163
    NKAWTG
    2004 A4 1.8TQ 6MT USP | Motoza tuned F21L MF | Treadstone TR6 | 034 HFC | Bosch 550cc Injectors | 3" MAF | FT 3" TIP | FT HF Exhaust Manifold | Hyperboost DV | FSI Coils | BKR7EIX-11 | B7 A4 Brakes/HPS 5.0 | Bixenons Q5-R | B5 Perches | Podi EBG | A5 MFSW/A3 Airbag | B7 Console | Dynavin N6
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Haha I see you like to live dangerously.
    "Beep beeeep bloop boop" - R2D2
    Dec 28 2006
    Western Maryland
    Items for Sale
    I have no goals other than keep my B6 running a few more years. I was just playing around to see what a little more timing would do.
    Quote Originally Posted by agentsmith988 View Post
    That is correct. I asked Dave to stay on the conservative side since I was working with a stock engine with 200k miles on it. The most I was seeing was 226→228 g/s. So on paper that doesn't look like much but it sure felt a lot different. Possibly the increase in torque was a bit more than the increase in HP.
    Established Member Two Rings noldevin's Avatar
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    So you're running unitronic instead of motoza now? What made you decide to switch?
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by noldevin View Post
    I'm running Motoza. I also have Unisettings so I can tweak a little if so desired.
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Oh that's pretty cool. I didn't know they played well together
    Senior Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Items for Sale
    After all these years with the car might as well get adventurous!
    Jun 21 2005
    Milton, Ontario
    Sounds fun Fletcher! I'd be interested to see what a proper AFR gauge would do a long with some drop in rods
    – Steve
    2005 A4 Avant 1.8T Quattro MT
    • Comp Turbo Billet T3/T4 4756 • SPA clone manifold • Turbosmart ultragate • Forge 007 DV • 034 SPA 3" downpipe, de-cat & muffler delete • AEB head & intake manifold • EV14 750cc @ 4bar • Snow Performance Meth injection • Eurodyne Maestro • Bilstein PSS9 • OZ ultraleggera matte bronze w/Conti Extreme Contact Sport • B5 S4 front brakes • 034 street density engine mounts • JHM B7 RS4 LWFW + clutch
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 USP, 68 Camaro, 00 Cavalier
    Crank it up! I know how the button dyno feels bumping up the timing.
    Once I get my tune sorted out I'll take you for the spin like you asked! Im currently reading 419g/s on my 4.2 b6s4 MAF on Maestro. But my next move I'm getting Bische to tune it. Anxious to see what he can do for me.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L
    Before camber and tire stretch, there was horsepower and performance.
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by SleeperAvant View Post
    So would I Steve but it isn’t happening for now :( Not until I pick up a new daily driver. I’ll probably just keep the B6 to play around with instead of trading or selling it. I doubt I could get more than a few thousand $$ for it and it has more entertainment value than that to me.
    Quote Originally Posted by Wet0willy01 View Post
    Wow!! That’s some serious power, Andrew. I will see if I can find my old neck brace before we take a spin. Don’t want to risk reinjuring my neck riding in your rocket!
    Jun 21 2005
    Milton, Ontario
    That's how I figure, I've thought about selling it many times but I'm now leaning towards not. I'm curious as to what your options/thoughts are on a new daily driver.
    – Steve
    Sep 17 2006
    Items for Sale
    Selling the B6 is a tough one these days. They are not worth much and I always look at it as hey, a car that works, why ditch it. Unless you have a problem car or just tired of it, it's worth more as a spare. I'm torn myself. I neglected my car for a while and started shopping for a newer S4 as my daily. Then I realized, I'd better refresh the car a bit, otherwise it's going to need work while I have a newer car taking my attention. So I took a break and for the past two months I've been refreshing it.
    I'd be really curious what you go for next, Fletcher. Another Audi or another make entirely?
    Dec 28 2006
    Western Maryland
    Items for Sale
    Most likely it will be a late model A5 quattro 6-speed. Just a basic chip and a few bolt-ons can get the 2.0L TSFI well north of 300 chp. That is all I need for the fun factor and also remain reliable as a daily driver. Then of course there will be shocks, springs, sway bars, brakes, whatever.....
    Modding never ends.....
    Sep 17 2006
    Items for Sale
    Ha ha fair enough! I'm staying in the Audi family myself. I was an inch short of buying a 2014 S4 Prestige with 28k mileage in January. Steal of a deal, had sport diff and everything barely used. Go figure I sleep on it for a week and finally go to buy it and it ends up having a rear sports diff failure. Apparently a manager won an award and got to pick any car for the week. I was last on record to drive the car before him and all was well. I was livid about that but kept my mouth shut because the sales guy was taking a risk to dig into what actually happened vs giving me BS. He kept me in the loop for a while but the car eventually disappeared from their inventory. These newer cars do make great power. The A5 sounds nice!
    2004 Brilliant Red Ultrasport 1.8t Quattro 6spd
    OZ Ultraleggera (18.6lbs), Pirelli PZero All Season+, APR Snub Mount, Podi Stepper Boost Gauge, ECS Slotted Rotors, Hawk HPS, Nappa Leather Recaro Interior, RS4 Pedals.
    AEM Dry Filter. Mobil 1 0W-40 from the day I bought it. Only 93/94 Octane. Avg. 31mpg, 11+ years.
    142.5k miles and counting.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Torque Pro is an app correct? Do you just connect to it via a bluetooth obd2 adapter such as the Motoza BTX?
    2005 1.8T Quattro
    Motoza Stage 1+ / stock K03 Turbo / Bosch EV14 550cc injectors / IE intake manifold / Carbonio CF intake / BB Stealth cat-back exhaust / APR cast DV / Evolution Racewerks Competition FMIC / JHM short shifter + linkages / 034 street density motor/trans mounts, upper(adjustable) & lower control arms / Neuspeed snub mount / Bilstein PSS9 coilovers / Hotchkis S4 Sway bar set 35/27mm w/ 034 end links
    Jun 21 2005
    Milton, Ontario
    Agreed. I currently have two other stock cars that take daily duties but my commute to work is only 10km so the BAT avant doesn't have issues tackling this. The new golf R looks quite nice, as does the golf alltrack though……
    – Steve
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    HD/SoCal
    Freaking Rad Dude!!!!
    My car only feels really fast when I push it off a cliff :(
    HIS: '05 A4 Atlas Avant 2.7t
    HERS: '08 A3 2.0TFSI DSG SLine
    THEIRS: '03 A4 Polar Sedan 0.0
    IG: @murky_rivers
    Knallhart Motorsports
    Dec 30 2014
    2002 Audi A4 1.8T QTM
    South Carolina
    Did the ecm pull timing during this butt dyno fiasco? :)
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by KHARDa4 View Post
    I didn’t log anything. I just added some timing advance and went for a spin armed with nothing more than my TorquePro reading the MAF g/s. That would be why I was playing with fire. I just didn’t expect such a sharp increase in performance. If I decide to do it again I will log all the appropriate parameters.
    Dec 30 2014
    South Carolina
    I would go back and log it. If there isn't excessive timing pull and the engine wasn't knocking I would leave it :D
    Jun 19 2012
    04' B6 1.8TQ, 04' 330CIC, 01' SV650S, 99' 955i, 91' F150, 90' Corrado 1.8T
    Long Island, NY
    I'm not a "tuner", but I have done a lot of my own work and research and I flash cars for a well known tuner. I don't think increasing timing will offset fueling. Increasing airflow (boost) will increase fuel requirements). You would need to monitor for timing pull / corrections / knock / detonation though. I think VagCom blocks 22 & 23.
    Also, I don't know how your tuner works, but there are safety net maps built into me7.5 that account for timing reduction based on IAT & CTS temps.
    I did my own work here and ran a lot of timing and power... http://forums.vwvortex.com/showthrea...1#post81499532
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Most likely a greater proportion torque increase to hp increase. That is where your setup is probably the most efficient - on the way to hitting its limits.
    Once your revs get up there and the breathing demands start to really matter that is where you would start to feel the hp then you run out of of headroom as your hardware limitations kick in.
    Did you take it all the way to redline like on a dyno?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Dec 30 2014
    South Carolina
    Quote Originally Posted by DougL View Post
    Right, if the ecm is going out of that 7.5* of correction then timing is to far advanced.
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by A4SoftWalker View Post
    I ran it (unintentionally) to the 7,000 rpm rev limit. It got there a bit quicker than I had anticipated.
    May 13 2008
    NoCal - EBay
    I know it comes up quick right?
    I hit redline quicker than my rev counter can react. It says I hit it at 6800 but I'm tuned for 7500. I'm thinking of going up to 7800 with my elim once I upgrade my exhaust system yet again this time once and for all.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by BumblebVR6 View Post
    Yep. An app for your Android phone. All you need to run Torquepro is a ELM327 OBDII Bluetooth transmitter ($10) and the Torquepro app through Google play store ($4.95) and you can monitor all sorts of stuff with your cell phone. You can also read, research and reset DTC’s as they occur. Pretty versatile app for minimal investment.
    Fry Sauce, UT
    Getting to the rev limit so much faster has been the biggest adjustment for me since going with the F21. It's crazy how much faster it gets through the revs when boost doesn't taper off like with the K03!
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I have an iphone so may have to look for an alternative. Sounds like a safer alternative than staring at a laptop in the passenger seat :)
    2005 1.8T Quattro
    Jun 27 2011
    Items for Sale
    Just keep your eyes peeled for piston ring issues.
    But damn the B8 2.0t engines are SOOO sweet. My wife's stock q5 leaves my stock b7 in the dust. No contest...
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Mar 05 2013
    Earth
    Items for Sale
    Don't you already have all that now though? I suppose the package of an A5 comes with newer sleek lines.
    But, direct-injected and "no replacement for displacement"
    I heard Golf R is a letdown once you actually test drive it, at least in stock form. IDK though, I never drove it. Seen a few e-Golf's around though.
    the verdict is in
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Most 2.0 FSI/TSI motors I come across all have oil leak issues. Be it the upper cam/cradle assembly green sealant leaking, vacuum pump leaking, the common water pump leaking on the early plastic pumps (in addition to thermostat issues/codes). Our motors have their issues as well but are a lot simpler to repair once said issues arise.
    2005 1.8T Quattro
    Jun 27 2011
    Items for Sale
    The b7 FSI engines are remarkably similar to the 1.8t actually. Same water pump so the leaks there aren't any better or worse than the b6. Any leaks in the cam cradle are simple a result of the person half-assing a repair. I did mine when I replaced the cam and zero leaks from the valve cover or cam cradle.
    I'm not trying to insinuate they're bulletproof though. Mine currently has piston ring issues and burns 1qt/1200mi and has a relatively low compression for an engine with so few miles.
    That and the HPFP blew up and took out my cam and likely caused some bottom end wear.
    So basically my engine needed a rebuild at 54k miles. Yeesh.
    -CP
    Dec 28 2006
    Western Maryland
    Items for Sale
    OK.....I get it. You guys are just trying to make me keep by B6 a little longer, right ;-)
    Jun 27 2011
    Items for Sale
    Haha. Or just not be a dummy like me and get a damn inspection.
    I feel for the "low mileage" charm assuming there was no way catastrophic damage could be possible. Whoops?
    I love the 2.0t, I just bought a bit of a lemon. Though I'll admit it's gone nearly 30k miles since my cam replacement without any other serious issues. So it's not all bad.
    -CP
    Feb 12 2004
    DG 2004.5 A4 1.8T USP
    Austin, Texas
    Items for Sale
    Yo CW + Fletcher,
    I was always under the impression that the late model 2.0Ts (the one on the later B8s / A5s) had many of the earlier engine issues resolved? Is this not the case?
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Jun 27 2011
    Items for Sale
    They do. But the early (2009-2011) ones had major piston ring issues (recall campaign for that though). They have some PCV issues, and potentially some injector issues, but nothing particularly widespread.
    I would for sure say the b8 gen EA888 engines are a major step up from the b7's EA113. They're sort of the 1.0 version of the 2.0t. The b7 FSI one being the Public Beta...
    -CP
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
