Results 1 to 6 of 6
    Sep 21 2016
    1984 f-250 inline 6
    Washington
    Question Vibration on med-heavy exceleration
    I started to notice that when i accelerate anywhere from medium to full throttle i have a vibration feeling in the car and steering wheel. I also have started to get this code (p0087) Rail pressure low. often when i do excel rather spiritedly. It turns off after a day or so. Or i can reset it and it stays off, well until i repeat the prior. Also i noticed that after 5k RPM the boost drops to 5psi and then back up to 10-12 and back again while accelerating. Also when in D the car at stop has a Vibration but not when in P or N. NOTE. I have changed my hpfp about 20k ago due to the follower failing. Now i replace the follower every 25k with only the black center being shinny. Fuel filter about 40k ago. Really no problem when normal driving.
    Maybe the LPFP?
    Thanks guys.
    Senior Member Four Rings vce1232000's Avatar
    Jun 17 2013
    jersey city nj
    Items for Sale
    Sounds like motor mounts need to be for the engine vibration. Not related to the P0087
    APR KO4 ,S3 Inj, APR HPFP,RS4 LPFP Controller,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST Coil Overs, 034 RSB,034 St Density Mtr Mts, New South Vent Boost Gauge, Front B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. S6 19 inch rims. S4 mirror caps,RS4 Mesh Style Grill
    Sep 21 2016
    1984 f-250 inline 6
    Washington
    Could be, i did replace them about 2 months ago. I will give that a go.
    Established Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Sydney
    Nope, that sounds like fuel cutouts to me. Log the LPFP utlisation at idle.
    A4 B7 2.0L TSFI (Mauritius Blue) | KO4 + Autotech HPFP upgrade + BSR Stage II tune - 2.5" BSR CAT-back - CAI | GFB DV+ | 19" Audi 2015 RS4 rims | R8 Coils | 034 RSB, control arms, end links, street density engine & CVT mounts - snub nose - HFC | Cupra R lip | 7" Erisin 2028AM | Yellow Fogs, LEDs throughout | CXRacing FMIC - B12 Bilstein Suspension + H&R Springs | S4 brake upgrade and braided lines.
    Jun 17 2013
    jersey city nj
    Items for Sale
    the bolts to make sure there tight. also @ transmission mount
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Log lpfp, check your fuel filter, if you are tuned make sure you have proper gap on your plugs and that you are running colder ones.
    Sent from my Pixel XL using Audizine mobile app
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
