Results 1 to 27 of 27
    May 11 2014
    United States
    Best situation for bigger dual pulley sizes (drag vs highway)
    OK obviously I would love to get into 10s for the quarter mile but since the drag strip is more of an entertainment thing, I would rather have a car that's better in more real life situations like highway pulls and such.
    From what I have read iats seem to be a much bigger issue at the dragstrip vs highway pulls, so would a bigger pulley be better for highway while a little smaller would be better for the strip. It just seems like doing a pull from start all the way through 4th is obviously going to have heat issues but it might be more manageable during real life situations.
    Just wanted to get peoples thoughts.
    2014 Black S4 DSG - EPL DP 183mm with TCU tune - ECS Kohlefaser Luft-Technik Intake - Corsa Cat back Exhaust - Added Heat Exchanger in Series with OEM - OEM Coolant Pump w/Signal Wire Mod
    Dec 06 2015
    Santa Clara
    This is a good thread for those still on the fence on which DP setup to go with.
    I'm running a 194mm crank and 57mm sc, roughly 3.4 ratio. This setup as compared to my previous 180/57 combo is night and day. If I said it was like going from stage 1 to stage 2, that would be an understatement. The low end is massive compared to stage 2 or even stage 2+ with the 180mm. I still take my car to the track and set goals to go lower, but since my track time represents only less than 2% of the time I spend in my car, I am willing to give up a couple tenths on the quarter mile for the extra torque I get the other 98% of the time.
    With the Fluidampr option, anyone on the fence has the option to go big, then swap out rings if they choose to later at a very low cost as you could probably sell the ring close to the purchase price.
    Thats my 2 cents on this. Don't be afraid to go bigger if you know you're not trying to set records, or even hit the track at all. The extra torque down low vs peak HP gain is well worth the trade off in my opinion. How many people actually see 7200+ rpm on a daily basis?
    Established Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Around town DP is the cats pajamas. Makes the car way more enjoyable. For sustained highway pulls a bigger ratio offers diminished returns due to heat. For short bursts I'm sure a high ratio is fun, the 179mm is a great all around setup. This is the 3.10 ratio of 57mm upper 179mm lower. Haven't seen any high ratio 1/4 mile times that outperform the 3.10 ratio.
    Quote Originally Posted by KnewJack View Post
    This is where I am stuck. Something like a 3.4 ratio would most definitely create too much heat but even with a sufficient cooling system? I'm talking core, reservoir, and pump like an AMS kit. I am debating upgrading my 179 crank to a 189 with the cts pulley and I hear alot of mixed opinions
    Using Tapatalk
    Jul 21 2004
    E350 4Matic; Camaro SS; e30 BMW, Toyota FJ
    South Florida
    Agree very much. If you do back to back pulls or sustained higher rpm driving ala canyon runs or lap days you will get extremely high iats as well. When stationary they will onky get so high. There is no airflow bit no boost either. Lets say the csr will heat soak to 55c when stationary but hit peak iat of 64c under wot at redline with grat cooling and upwards of 85c with stock cooling. Without cooling you lose out on top end power
    2013 Audi S5 DSG
    Unitronic Stage 2++ ECU & TCU, KI 200mm Lower, Revo Charge Cooler, CTS Turbo Intake
    11.482 at 118.70mph - 97 octane - +465DA
    11.605 at 118.76mph - 93 octane - +544DA
    Gone:
    2016 A6 -- 2015 S4 -- 2009 A4 -- 2004 S4 -- 2006 A4 -- 2003 A4 -- 2000 A4
    Dec 06 2015
    Santa Clara
    Quote Originally Posted by bhvrdr View Post
    I've hot lapped my 194mm with APR hx only at the track. When I'm back at the staging lane IATS are back down to 41C every run. This was in 59C weather. Peak IAT on every run was 62C max. Daily driving in traffic, highest I've seen stationary is 51C, then it quickly drops to the 30s when I start moving again.
    Jul 21 2004
    South Florida
    Cooling upgrade is doing well for you then. Mine is similar. Before cooling it was 20c higher peaks. Most tuners pull timing in the 70c to 75c range so these hx are really helping a ton for more power. Technically you could even run slower with dual pulley if the iats get high to trigger lower timing maps and on only stage 2 it doesnt
    2013 Audi S5 DSG
    Gone:
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by ntsantos View Post
    For clarification, you were running the 194 with a supercharger pulley too or just the crank pulley? What supercharger pulley? At the track were you typically high up in the RPM bad near redline or more mid range? Just trying to get a sense of how hard you are pushing the supercharger and related cooling.
    I too would rather have the low end power as that's where I need it the most but I need to be mindful of the fact that I autocross and I don't want to hurt anything or heat soak so badly that I am actually slower.
    Shawn
    Dec 06 2015
    Santa Clara
    Quote Originally Posted by eurotic View Post
    Shawn
    194/57. However, I have an A7 with only 6400 rpm redline.
    Mar 13 2013
    Chicago Western burbs, Il
    59c track temp not air temp? air temp over 100F? just curious as the IAT's look really good.
    '13 Audi Q5 3.0 APR V4 Fluidampr 179/57.75 AWE touring W/DP P3 VIDI Bilstein B12 Pro (APR CF inlet pipe/AFe Pro-5R)
    '12 Golf R APR S2 LC/NLS HPFP IC, UM Haldex, Milltek TBE, Southbend SMF daily stg 2, VWR Intake, Fluidampr, Flip RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, APR catback, HPA intake, KW V3, RNS 315 Flip RVC, PolarFis
    '02 MDX - Need something to haul the junk
    Oct 06 2014
    Cleveland, OH
    Cool thread. I am looking at all of this through the eyes of a Road Course driver. I wonder what crank pulley I need for street/road course, to go with my 57mm snout pulley? I don't know, without logging, what my IAT's are for the 20 min of track time we get. I was thinking that I could get away with a 183 (GIAC's largest crank pulley for the S2+ file) because I will always have air flowing past the upgraded HX? I am not sure and right now, I don't see too many Road Course members posting their setups?
    2014 S5-DSG with Sport Differential|CTS Intake|034 Rear Sway Bar, End links and Insert Kit|CR-15|H&R Sport |Custom Exhaust|ST-60|PLM| Alu Kreuz |GIAC S2+/GIAC TCU
    Dec 06 2015
    Santa Clara
    Quote Originally Posted by tmoe View Post
    Sorry track temp at 59F not C, my bad.
    Mar 03 2010
    Pitsburgh, PA
    Quote Originally Posted by SR7D1 View Post
    Same. I'm more curious about the optimal setup for street/road course/canyons. It's amazing how many people are taking these cars to the drag strip! Cool stuff! Just not for me... in this car.
    Established Member Two Rings tars9's Avatar
    Jun 15 2015
    Schaumburg/IL
    I just installed the 187 pulley from APR to run with 57 CTS pulley. I use the car as a daily and so far, I've been loving it. Think I'm getting a bit of belt slip and the tune is still working itself out. But overall, it's been solid. Big increase down low. Haven't logged IATs yet, but haven't noticed major issues either. I have the PLM heat exchanger which is okay.
    2012 Audi B8 S4 | 6MT | Phantom Black | Alcantra l B&O | CF Inlays | Sport Diff | ADS | RS4 Grille l Injen Intake l AWE Track Exhaust & Resonated Downpipes l EPL Stage II+ l Pulley Ratio 3.28 l PLM HE & Reservoir l ECS Trans and Rear Diff Mounts l CR-15 l P3 VIDI
    Jan 10 2017
    Sweden
    Great thread, real life performance is as you say, more important for most of us.
    I have yet to find any 60-130 times with these dual pulley cars, that for me is a good real-performing measurement in my opinion.
    Mar 13 2013
    Quote Originally Posted by tars9 View Post
    where did you get it done: hoffman estates audi or GRD? I'm waiting for dual pulley file for Q5 but I'm seriously thinking about fluidampr 179 and cobra HE - the Q5 takes lots of trips to florida and the 187 and that heat has me a little worried. Offtopic have you ever complained to P3 about their useless air temp reading on the p3 gauge? I have for over a year and they say they'll have a new option to fix it but as the story goes with auto tuning, its coming....
    Dec 06 2015
    Santa Clara
    I flashed to my oem file a couple days ago in preparation for a trip to the dealership tomorrow. Out of curiosity, I hooked up my old Chipwerke to see what it would feel like with the oem file + 3.4 pulley ratio (194mm/57mm). What a torque monster! The CW is such a beautiful thing.
    This is definitely a good setup for anyone that wants a good all around setup without spending over $1K on a tune. Or if you're not sure which tune to go with. Just get whatever pulleys you want and slap a CW on. If you decide on a dedicated file later, you can either stack the CW (if needed) or sell it.
    Established Member Three Rings yjypm's Avatar
    Oct 08 2015
    You are running the new apr 187mm pulley with EPL tune?
    What was your previous setup?
    I'm running jhm 179mm crank pulley right now and debating if I should get apr's 187mm pulley since it's the cheapest dampened oversized crank pulley
    '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL DP+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | BBS CH-R | ECS RS5 380mm Front BBK | Macan Ducts | Brembo GT 380mm Rear BBK | AWE Touring | S-FLO Intake | Bilstein B12 Prokit | Led | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Coming: Custom Ebrake Brackets
    Veteran Member Three Rings deucescorner's Avatar
    Aug 26 2008
    2016 Audi Q3 S-Line Tecnik Black Optics
    Montreal
    I'm currently running on Stage 2 AWE/GIAC with the AWE heat exchanger and I'm on the fence on whether to go with the 179mm JHM pulley or the 187mm APR pulley. I'd like to pair either of these pullers with the GIAC DP file they just released, not sure about the compatibility with the APR pulley since it's 187 and GIAC recommends 179-184mm for their DP tune. No drag racing for me just normal cruising and occasional spirited driving.
    2013 Audi A7 S-line (current)
    2016 Audi Q3 S-Line (wife)
    2005 Audi A4 Avant 1.8T Stage II (SOLD)
    2001 BMW 325ci Convertible (SOLD)
    2000 Audi A6 2.7T (SOLD)
    Established Member Three Rings JD S4's Avatar
    May 07 2016
    Boulder, CO
    Quote Originally Posted by deucescorner View Post
    You'll be fine with either.. You'll get more torque from the 187 but more heat.. The 179 is the jack of all trades pulley but won't have as much down low grunt.. Your call. I think it comes down to how many back to backs you run. If you're usually a "1 and done" type - go 187 and you might bleed a little boost on the 187..
    2011 S4
    EPL Stage 2 l Roc Euro l Magnaflow l Racked l Tinted l CR-15 l RS Grill l P3
    Mar 20 2015
    McKinney,TX
    I just ordered a 184 pulley from Kustom Imports. I figured this was the safest bet and all around performance enhancement without having to spend a crap load for cooling.
    I was also wary of over spinning the SC if my Revs ever exceeded the 7,300 RPM Redline. Plus Stage 2 is almost unusable around town, at some point there's a limit to how much power you can use on the streets.... wait did I just say that?
    Stage 2 Banner Advertiser Four Rings Chris@EPL's Avatar
    Jun 23 2011
    Quote Originally Posted by yjypm View Post
    That pulley is not dampened at all. It just bolts to the OEM pulley, so you would have to install your old OEM pulley and then install it.
    European Performance Labs
    http://www.facebook.com/EPLabs
    https://www.instagram.com/eplabs/
    (203-345-6499)
    Chris@eplabs.net
    Please feel free to contact us with any questions!!
    Oct 08 2015
    Quote Originally Posted by Chris@EPL View Post
    I thought the oem pulley is dampened?
    Jun 23 2011
    The OEM pulley has an elastic rubber ring that the 2 pieces of metal attach to. The rubber is not really dampening and they are still failing. The Fluidampr are more money, but the Fluidampr OEM sized pulley has nothing that can fail and comes with a lifetime warranty. The Overdrive section of the pulley goes over this dampened OEM sized pulley to be the 179, 183, 187, 189mm, etc size.
    (203-345-6499)
    Chris@eplabs.net
    Feb 08 2016
    Mexico City, Mexico
    What about something like this, variable ratio SC: http://www.torotrak.com/products-par...ucts/v-charge/
    Senior Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x
    New York, NY
    I actually purchased a Fluidampr, but just to clarify, the rubber ring and metal mass is the OEM harmonic balancer. It is dampened. And the accessories remain dampened I believe even with the APR bolt-on. That being said, since it's clearly considered a common point of failure like you mentioned, the Fluidampr seems like a good insurance policy that may even have some fringe benefits.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Senior Member Three Rings ModItNow's Avatar
    Mar 05 2015
    Napa, Ca
    FYI for us 6MT guys. Ive heard of people having chatter with aftermarket flywheels and I can report zero chatter with mine which I believe is due to the fluidampr. Seems like a solid choice all around.
    © 2001-2017 Audizine, Audizine.com, and Driverzines.com
