Results 1 to 3 of 3
    Established Member Four Rings Spawne32's Avatar
    Nov 20 2016
    temperature flap motor upper limit exceeded
    Anyone encounter this issue before on their B8? Received this code after scanning the car tonight, noticed some unusual behavior from the temp control, was blowing cold when i had it set for 76 degrees, and since I had bought the car last year had always noticed an odd "snap" sound every so often with the auto climate control behind the dash. Wondering if the servo motors have a tendency to go bad or if im going down the road of needing to remove the entire dash. -_-
    Senior Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    I don't have personal experience with this code but this older article seems to be similar to what you are experiencing:
    This is a module failure but I can't seem to see a similar module in a B8(Most likely not your problem):
    http://www.ttforum.co.uk/forum/viewt...19879#p1919879
    This is a pump failure in an older A6(Most likely not your problem):
    http://www.audiworld.com/forums/a6-s...crazy-2893162/
    TSB Associated with above A6 failure(Most likely not your problem):
    http://uberlame.com/a6_tsb/HVAC/Temp...er%20sides.pdf
    You can also try running the adapations on the HVAC system to see if there is a fault with one of the vent motors/servos.
    Procedure from http://www.a2oc.net/forum/archive/in...p/t-26653.html
    1) Connect the VAG-COM, go to the control modules, and auto hvac-module.
    2) Advanced functions, basic settings.
    3) Group number 1. (Press "up" once)
    4) As the numbers change, the position of the flaps change.
    4) Wait till all those are 0.0.
    Other than that the only real other controller in the B8 that I am aware of is the actual HVAC controls.
    https://www.ecstuning.com/Audi-B8_A4...trol/Controls/
    Warning: HVAC controls are protected by Component Protection so there is an additional cost to have them mated to your car.
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | R8 Coils | CR-15 | ECS Inserts | Rear Muffler Delete
    Retrofits: MMI3G High | Color DIS Swap | MMI Stalks
    Safety : Timing Bomb Removed OUT: 06H109467 IN:06K109467
    Nov 20 2016
    Thanks for that, ill have to pull out my VAS tool and see what I can find, as I dont have a VAG-COM.
