Results 1 to 15 of 15
    Sep 05 2013
    Ottawa, Ontario
    Has anyone ever tried this 02 spacer?
    Has anyone on here ever tried a spacer like this one and have successfully set readiness for CAT?
    http://germanoem.ca/parts/exhaust/o2...11619-vib.html
    2002 1.8T Quattro
    Fully loaded APR ECU / K04-15 Turbo / 386cc injectors / Magnaflow dp-back exhaust / Forge 008 DV / 034 street density motor mounts / 034 street density tranny mount / 034 snub mount / Unitronics 3" HFC - DP combo ''last one ever made in production'' / Racetec front mount intercooler
    Active Member Three Rings
    Dec 27 2016
    Milwaukee Wisconsin / Detroit
    Yup those work magic.
    Established Member Two Rings EuroEnduro's Avatar
    Nov 01 2015
    Ottawa, ON, Canada
    If you want a cheaper option, you can buy spark plug anti foulers from Napa (I might be able to find the part number). The pack comes with 2, and you need both.
    What you do is drill the one out so the 02 sensor fits inside, then cut a 1" x 1" square of steel wool. Then, put the steel wool in, and screw the two anti foulers together, then put into your exhaust. Worked in my 2004 1.8t throwing a P0420 code
    2003 Audi A4 Avant 1.8t Quattro - 6 speed swapped - Unitronic 2+ w/ all required and supporting mods
    Check out my Build Thread! http://www.audizine.com/forum/showth...t-Build-Thread
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    Quote Originally Posted by EuroEnduro View Post
    this^, also you may have to play with the amount of spacers, angle, etc. Sometimes it just works others may have to make adjustments until it does, typically with no cats you have to pull it out more then if you have HFC and then it depends on how much those HFC's flow.
    Sep 05 2013
    Ottawa, Ontario
    Would you insert the wool in-between the two foulers so that the wool sits directly under the 02?
    2002 1.8T Quattro
    Jul 31 2014
    NH
    Quote Originally Posted by K04-B6 View Post
    basically yes, you may need to stretch out the wool with the 02 by pressing it in a little before you tighten the two spacers together, also sometimes you don't even need the steel wool, try it and drive for a week or so and see if your code comes back.
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by blitz2190 View Post
    That's the thing. I never got a code. I just can't set readiness for CAT.
    2002 1.8T Quattro
    Jul 31 2014
    NH
    you have a bad tune then, its just turning the check engine light off and associated code without setting readiness, If I remember right you were having issues with this in another thread right?
    Senior Member Four Rings Spike00513's Avatar
    Mar 05 2013
    AZ
    Quote Originally Posted by yxri View Post
    yes I heard they work
    Sep 05 2013
    Ottawa, Ontario
    Yes youíre right. My 02S is finally setting now but itís just the CAT readiness thatís not setting. It used to set with my stock cat with the tune, Ever since I installed the HFC it hasnít passed readiness.
    2002 1.8T Quattro
    Nov 01 2015
    Ottawa, ON, Canada
    Yes, insert the steel wool right beside the 02. I tried it without the steel wool and still had the code pop up.
    It's weird its not setting the readiness code. Sometimes it can take a lot of km to set it. However, I believe I was told you can have one readiness check that's not ready. But the catalyst is a pretty essential one, so not sure if it applies to that one.
    How many km have you driven with the HFC? Do you have any pending faults?
    Sep 05 2013
    Ottawa, Ontario
    I can have one readiness not pass and still pass emissions but I removed my Sai and I was hoping to have that readiness to be my "1" failed. I'd like to have my cat to pass as I feel it's essential like you stated. I have a pending code after I hit the highway for p0171 "lean" that I still haven't been able to rule out. I'm still trying to figure out if it's the tune or not. Since I've been having this issue for 4 years and it comes up more often in the winter time.. I'm going to be doing a smoke test hopefully this week and determine if I have any leaks. Everything is basically new as for vacuum lines and tip.
    2002 1.8T Quattro
    Jul 31 2014
    NH
    you have a small vacuum leak somewhere it comes up more in the winter as your car takes in more air when its cold and that probably pushes you just over the limit. Start with a boost leak test.
    Sep 05 2013
    Ottawa, Ontario
    I've done multiple boost leak test with no leaks detected. Hopefully this week I can build my EVAP smoke testing machine and smoke test the whole system to be 100% certain. I keep burning up my turbo to cat gasket so that's probably throwing my readings off a little as well. I have parts coming this week to fix that and then i'll know for sure.
    2002 1.8T Quattro
    Veteran Member Four Rings MikTip's Avatar
    Dec 25 2004
    Earth
    My N75 was leaking internally...and it was new from Audi...
    K04-15/APR/TT 225 Injectors/TFSI Coils/Custom Stainless Exhaust/710N/RaceTec FMIC/ 034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold/JHM B7RS4 SMFW clutch/Neuspeed TIP/Apikol Snub/Optima 75-35/AFE Pro-Dry/AMS Short-shift @ %40 redux
    Bilstein Sports with H&R/H-Sport Anti-Sway bars/E-codes/ 19x8.5 Skinny Fives 235-35 Falkens/B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors/Sirius Satellite Radio/Ross-Tech HEX-USB+CAN Equipped/Escort 9500ix
