Results 1 to 32 of 32
    Sep 29 2016
    Longwood, FL
    A4 Burning Oil LIKE CRAZY
    So the last couple months i've been monitoring the oil consumption on my wife's A4 because since it has hit the 100k mileage mark it has been losing oil like crazy... got an oil change from the dealership at 115,551.... oil min light came on today at 117,051.... that is almost 5 quarts of oil gone in 1,500 miles... with that said she is burning a qt of oil every 300 miles... THATS ABSURD! I read on a couple posts that it is normal with this year and with the turbo model because it's a pressurized crankcase and oil seeps past the piston rings but these people complaining are getting about 600-800 miles/qt. I have changed the PCV valve about 4,000 miles ago because it went out so that fix is already out the window. The other fix that people are saying that can be done is the piston rings... we all know how big of a PITA that is... might as well completely overhaul the motor. Anyway.... just looking for opinions and thoughts as to why and what else could be done? Is it just something that we are going to have to live with unfortunately? Please advise... thanks!
    Mar 24 2013
    A7
    Griswold, CT
    Ha! Dude, the low oil light comes on when you are down by 1 quart. My old motor was ACTUALLY burning a quart in under 300 miles. You're still in decent shape, but you may have a valve cover issue. Also check around the oil filter housing for a leak.
    -Adam
    Feb 15 2016
    Cambridge Ontario
    Yeah for the price of a gasket I'd thoroughly Check that vc
    2014 Nissan Murano
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Established Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Quote Originally Posted by presco135 View Post
    Ummmmmmm 5 quarts of oil? How much you think is in there?
    You'd had seized the engine long before you reached 5 quarts burned. Like aluthman said, the light comes on at 1 quart down. Even the oil pressure light comes on at like 1.5 quart or 2 down. The engine takes 5 quarts from dry
    1 quart in 1500 is fine
    Eric
    2005.5 6mt A4 2.0(red T ) Silver metallic outside, Platinum inside.
    May 20 2010
    Quote Originally Posted by pezgoon View Post
    I think you meant to say "1 quart in 1500 is livable".
    It's not fine--these cars should not be burning oil, at least not nearly like this. Adam had an extreme case that a few others did. Mine used to burn it in ~2000-2500 miles of normal driving. God forbid when I would get stuck in traffic jams. One winter, it was snowy and icy, and I was stuck for about 2 hours in traffic, all less than 1/2 mile from home. Wound up having to put 2 quarts of oil in the car because she burned through it.
    That's about the only thing I don't miss from my B7...
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    DE
    Aside from the oil consumption, the most immediate concern is whether OP dumped 5 qts of oil into the engine when it was only down 1 qt???
    '13 allroad Monsoon | APR Stg2/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Aug 19 2013
    Audi A4 B7
    Orlando, FLORIDA
    OP if you decide to do a cylinder head gasket or any other gaskets i have new ones from victor reinz that i'm selling.
    Ivan
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Dude just add half a quart and you should be good. Make sure to check if there's any leaks around the valve cover gasket.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jul 25 2016
    new hampshire
    Hmmm I coulda sworn I read a thread from someone whom was getting his consumption checked at a dealer and they didn't consider 1500 out of spec but I cannot remember where it was ( it was back when I first got the car last year I saw it) but I would love to know what Audi's spec for it is before it's an issue.
    On a side note why do these cars use so much? I have never seen anyone with solid suggestions as to why, it seems to generally be centered around the valve cover failing but I didn't know if it could be the piston rings/valves seats or what have you. I plan to have my car for a long while yet so I'm curious to know for the long run (right now I don't burn any between oil changes, many an imperceptible amount)
    Also the last car I had ( a civic) burned a quart in under 300, maybe 250? Maybe 150? I never really tracked it as I didn't care about the thing and it ended up losing a cylinder (I believed it was the valve seats) 1500 certainly could be worse lol
    Eric
    Feb 15 2016
    Cambridge Ontario
    i think that was Audibots point . Manufacturers might consider that "normal" so they dont get into costly warranty repairs, but it really isn't. I have had many high performance cars that will go oil change to oil change without topping off anything.
    In fact my 2009 290 HP maxima was a rocket for a 4 door sedan and went down practically zero and i had it for 150K.
    2014 Nissan Murano
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Established Member Four Rings yxri's Avatar
    Dec 27 2016
    formula SAE racecar
    Milwaukee Wisconsin / Detroit
    Turbos will eat oil. Its natural. Mine looses a quart every 2500 miles.
    Jul 25 2016
    new hampshire
    Ah that makes sense. They use it as a scapegoat
    That is especially why I'm curious as to what causes the oil burning for our cars in the first place, and how much is that the fault of audi that they won't admit
    Eric
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    12' Mercedes GLK350 4Matic, 04' GLI
    Pennsylvania
    Get use to it. My former B7 used more oil than fuel
    B8 S4 6-speed
    GIAC Stage II
    Oct 09 2007
    Miele S7
    With that said, I've never had a car that burns oil like my B7, then again this is my first turbocharger. I lose about a quart every 1K-1.5K miles depending on the severity of my driving. I'm currently at 63,000 miles and recently had the Valve Cover Gasket replaced along with a new Oil Dipstick and it is holding up well, not losing as much as before.
    Senior Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I'm at 217k on my B7. I bought it at 175k and gaskets may have been replaced then and I know my oil filter housing and turbo are leaking slightly. I lose about 1/2-3/4 quart every 5k oil change. Not enough to turn on the low oil light. I use to lose a quart between oil changes and I changed my PCV breather hose (was really fucked).
    2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Upper/Lower Control Arms | Pipercross Filter
    Dec 27 2016
    formula SAE racecar
    Just check your oil every month. Or sooner if you notice a huge drop in the dip stick.
    Senior Member Three Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Good ol VQ. I used to own a 350z with the DE engine. I beat the piss outta that thing and never lost a drop of oil. That engine was so solid, the transmission was a different story though. I had that replaced twice, the early 350z's (pre 2006) were known for syncro issues and that is what I had to deal with. Really do miss that car
    Senior Member Two Rings flavormonkey's Avatar
    May 14 2015
    RS4 Avus Silver Pearl
    United States
    Audizine
    WHAT!!! That's crazy...and seriously news to me.
    @OP - You probably have a valve cover gasket leak. Also, there's another gasket in the back of the engine below the fuel pump that can leak. I have a small one of those ATM, but i still won't burn >1Quart per 5k miles
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    Quote Originally Posted by yxri View Post
    Thats not terrible, but damn funny people saying that a quart every 300 is normal, may as well not even do an oil change at that point you've already replaced the oil 3 times in 5k haha. That said no engine should burn more than a quart every oil change if its running correctly and everything is functioning correctly. But I replied to this comment as just becuase a car has a turbo does not mean it will eat oil, my 1.8t drops maybe an 1/8-1/4 quart between changes (every 5k) this last one was up to a 1/2 quart because I think my PCV is on its way out. If someone came to our shop and said they burned that much we would be like , damn somethings wrong.
    Jul 25 2016
    new hampshire
    Maybe it's our terrible pcv systems? They are a known issue
    Maybe it's everyone saying that the car needs to be beaten to run well too lol
    Although I'm sure there are those who beat the shit out of there's and barely use any oil
    @ 80'sGuy that really blows, mines at 45k and uses none at all, atleast since I tightened the vc bolts, it was owned by an actual old lady though so maybe that has something to do with it
    I also idle it for atleast 1 minute but no more than 3 for the first start in the morning and idle it for atleast 1 min, longer if I've driven it hard, every time I stop it. Whether it's summer or winter. We'll see in 100k if it's worth the effort lol
    Eric
    Oct 30 2006
    05 Mini Cooper S
    I would check if you actually have an oil leak(and I mean a leak, straight drip at that consumption), if you don't the second thing I'd check is one of the turbo hoses, if something like a quart of oil comes out of the turbocharger pipe, your issue lies there. The last thing, and this sucks, you'll need pistons / piston rings. Just like the TSI EA888 engines, the FSI motor does experience this failure, and sadly the only way to fix is to replace and redo.
    -MilitantGrunt- Certified Audi Dealership Technician
    -F30 Estroil Blau 335 Xdrive M Sport 6spd.
    -Brilliant Red B6 A4 Ultrasport 1.8t Avant 621whp - RIP
    -Silver B6 A4 Ultrasport Sedan - SOLD
    https://www.facebook.com/auditech/
    Oct 09 2007
    Miele S7
    After replacing the valve cover gasket, I realized there were some misting residue next to the cover by coil #1, very little and would require days to actually see some faint oily stains around the area. I thought the gasket was somehow loose and oil was seeping through and out from the spark plug chamber. Removed coils to inspect and realize it wasn't the case. I then traced the culprit back to the lower rubber pcv (Turbo) inlet and thought it wasn't secured tight enough, evidenced by some shiny oil on the end. Refastened the Home Depot replacement screw-type clamp and it is all good now. But yeah before that I was adding 1/4 to 1/2 quart after long road trips. Since then, along with the new vc gasket and dipstick I have not seen any residues, and the car definitely ran tighter. Check oil level every now and then and it is holding up to level according to the dipstick.
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    Valve cover failure is really common too. Fixed my oil consumption issues
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Mar 24 2013
    A7
    Griswold, CT
    Based on OP not responding I'm guessing troll?
    -Adam
    Sep 30 2009
    08 A4, 87 Jag XJ6, Lex RX300, HD Street Rod, Grumman Yankee AA1A
    Indiana
    ^^ I agree. Who posts a thread like this and then disappears? Kill the thread.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by Avant4me View Post
    I had my valve cover replace because it was warped and leaking at the front drivers corner. I has also seems to cure my oil consumption. It's only been about 1 month and ~550 miles, but the level hasn't gone down at all. I was burning thru about 1qt every 1200 miles.
    I should add that I replaced the PCV https://www.europaparts.com/breather...-late-vin.html system about a year ago.
    Doing it for the wolfpack! Kiddchris.com
    Feb 15 2016
    Cambridge Ontario
    These threads are always good for others looking.
    I think many people don't understand the vc can be broken internally. Just because it isn't leaking at the gaskets doesn't mean it's good
    2014 Nissan Murano
    2006 A4 2.0TQ 6spd
    1976 Yamaha XS 360
    Aug 20 2014
    Doylestown PA
    I'm thinking this might be what is going on in my case. Previous oil change I didn't have to add any oil. Now I'm adding a quart about every 1500 miles since I did my valve cover gasket. I'm thinking the actually cover may now be damaged.
    Oct 09 2007
    Miele S7
    Quote Originally Posted by klrider44 View Post
    Do you see any leaks around the vc/gasket area? Maybe the gasket needs to be re-seat or re-torqued correctly. Did you replace the gasket yourself?
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by 80sGuy View Post
    I didn't do it my self, my buddy was putting some new axles on the car cause he has a lift and he did it then. It doesn't show any signs of leaking.
    Aug 16 2004
    SE PA
    Quote Originally Posted by heateris View Post
    I should probably update this comment.
    It seems that the new valve cover DIDN'T solve my oil consumption.
    Senior Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Is the oil collecting in your intercoolers?
    If not it could be turbo seals or rings . I'd say check your compression first
    Casey | @cshore
