Results 1 to 16 of 16
    Senior Member Four Rings Grouse's Avatar
    Sep 06 2005
    05 a4 3.0 Ultrasport
    3.0/2.8 FAQ sheet.
    It was mentioned that this was helpful. I added some links.
    Stuff for 3.0
    Exhaust:
    Neuspeed
    http://www.greedspeed.com/applicatio...ST_V6_QUATTRO_
    Decorsa:
    http://www.ecodetuning.com/shop/cart...ail&p=446&c=18
    Thermal:
    http://www.ecodetuning.com/shop/cart...ail&p=359&c=18
    Milltek (all the way down 2nd from the bottom)
    http://www.stratmosphere.com/milltek_a4_catback.htm
    Supersprint:
    http://www.supersprintna.com/categor..._model%5D/171/
    Chip:
    Neuspeed
    http://www.greedspeed.com/applicatio...0v.aspx?cat=46
    Giac:
    Does not show it but my local dealer Evolution Assures me that they have a chip flash for the 3.0.
    www.evolutionsports.com
    Wetterauer
    http://www.autobraun.com/abd/chiptun...l.asp?ct_id=12
    Cold Air Intake:
    Stratmosphere:
    http://www.stratmosphere.com/hyperflow.htm
    Intake shoot out article
    http://eurotuner.com/techarticles/0411et_intake/
    SuperCharger:
    Pes G3:
    http://www.pes-tuning.com/
    MTM Twin Screw Supercharger
    http://www.mtm-online.de/en/index.ph...m=MCA4220315FX
    Water Methanol Injection
    http://www.snowperformance.net/ article
    product
    http://www.snowperformance.net/products.asp?id=1
    Threads
    http://superchargedaudi.com/sc/index...topic=2209&hl=
    http://superchargedaudi.com/sc/index...topic=2220&hl=
    http://forums.audiworld.com/a4/msgs/2146261.phtml
    Suspension
    Stasis Koni/ohlins kit
    http://www.stasisengineering.com/aud...uspension.html
    Tien S.Tech
    http://www.tein.com/ti/j00.html
    Bilstein Coilover set
    http://www.neuspeed.com/products/pro...ils.asp?app=20|AQ&type=2&ltype=ns_euro&p_id=1832
    Koni Yellows
    http://www.neuspeed.com/products/pro...ils.asp?app=20|AQ&type=2&ltype=ns_euro&p_id=1810
    Vogtland Coilovers
    http://www.greedspeed.com/applicatio...land_Coilovers
    H&R coilovers
    http://www.awe-tuning.com/pages/shar...IL=HRCoilovers
    H&R Sways
    http://www.hrsprings.com/site/index.html
    Neuspeed 21mm rear sway
    http://www.greedspeed.com/applicatio..._Sway_Bar_21mm
    Brakes
    Stasis Alcon
    http://www.stasisengineering.com/audi_a4_b6_brakes.html
    RPI 13” WilWood
    http://www.rpiequipped.com/store/c192476.2.html
    Brembro BBK 355mm
    http://www.prostreetonline.com/buy/b...its/1b2.8002a/
    StopTech BBK
    http://www.stoptech.com/products/BBK/summary.shtml
    http://www.greedspeed.com/applicatio...t_02_06_A4_S4_
    ECS 2 Piece IE replica rotors
    http://www.ecstuning.com/stage/edpd/...OE%202%20Piece
    ECS Porsche Big 993 calipers
    http://www.ecstuning.com/stage/edpd/...CS%20Stage%203
    ECS OE replacement rotors
    http://www.ecstuning.com/stage/edpd/...ubcategory=OEM
    Differential
    Stasis differentials
    http://www.stasisengineering.com/audi_a4_b6_diff.html
    Snubmount
    APR snub
    http://www.ecstuning.com/stage/edpd/...ry=Performance
    Twin Turbo One Off 2.8's and 3.0's
    2.8 passat twin turbo thread
    http://www.passatworld.com/forums/sh...2&page=1&pp=30
    TVA motorsport one off 3.0 twin turbo at .7 bar.
    http://www.audi-sport.dk/audi_a4_3.0_turbo.htm
    These are the only two twin turbo's i know about and Niether has responded to my pm's emails.
    Intake, exhaust, and chip will net you 12-18 hp. Not a whole lot, your running a n/a motor.
    You can do a 50 wet shot of nitrous. There are a few around who do, they tend to stay quite as some of the members here are asshats about nitrous only being for ricers.
    The pes system puts down 320 chp, and 268 ctorque. that translates to about 256whp and 213 wtorque. Winslow at PES thinks with intake and The new thermal exhaust that thermal made specifically for the g3 they can hit 350 chp witch would put you at 270-275 whp.
    The g3 is the eaton roots e-62 supercharger, it hits 10 psi at full boost, This is the safe long term functioning limit PES has found on the 2.8/3.0 30v engines. Winslow says if you want to go higher with the G3 you'll need to beef up the bottom end. As for the top end their testing shows the g2/g3 actually benefits from all of the turbulence increasing the mixture of the compressed air and fuel. This gives better fuel air mix for ignitions. The g3 is their third supercharger for the 2.8/3.0 30v, it started with the g1, then the g2, and the final version of the g3 for the 3.0 30v.
    3.0 king has a g3 with intake and supersprint exhaust and shows 335 chp. That puts him at s4 power with 3.0 gas mileage and about 5k less new. Out of the g2's and g1's there are some that are in the 60k to 90k in mileage, is this the standard yeah I believe so. the e-62 is a near bullet proof s/c not nearly as high strung as a big turbo kit for the 1.8t's. If
    If your looking for near instant boost, with s4 power, but the gas savings of a 3.0. This will fit the bill.
    When i asked winslow about speed comparisons he said the g3 will beat a chipped and exhaust 4.2 s4, and a chipped 996 will need a long long road to actually take the g3, and it finally does at 6th gear and about 6k in rpm.
    Obligatory info to support what i said
    These two dyno's are from a 3.0a4 quattro. so the numbers are quattro WHP numbers. multiply them by 1.21/1.22 some where in there to get your numbers at the crank.
    Several guys with the g3 make more than the advertised 320. 3.0king makes 335 with stratosphere cai and supersprint exhaust.
    Last I talked with Winslow he was thinking that the new thermal exhaust specifically made for the g3 could possibly bring it up to about 350 chp. which would translate into 273 whp on a quattro a4.
    I asked about
    Port and polish of the top end, headers, manifold extrude and hone, 50 hp shot of nitros... your best of hearing his answers directly from him.
    For those two lazy to call.
    *Port and polish. Will run you about 12-1500 for� almost no gain times that people have done it on the g2 they range with in 5-8 hp on their dyno�s that is well with in the margin of error for environmental conditions.
    * Headers run around 1100 for the 2.8/3.0 if you can find them. I did once but lost the link. Pes tested the headers on the G2 and saw a gain of 8-10 hp. for 1100 plus one hellatious install it was a bit of a stretch.
    *Extruding and honing of the Manifold. PES�s is a custom manifold. What little rough ness it has is likely to give the air a bit of turbulence. This tumble seems in Winslow�s opinion to be more beneficial to the operation than a clean charge. It forces the air and fuel to mix at a much more efficient level.
    *Nitrous in addition to the G3 has not really been tried. Give it a shot :P and let Winslow know.
    *Intercoolers. Currently the G1 is the only supercharger that can accept the FMIC. Right now both the G2 and G3 simply do not have enough room to mount one. Both in the front and in the space between the hood and S/C.
    Even with a FMIC on the g2 PES only saw a minimal amount of temperature drop. With intake charges around 250 degrees F. This little change was next to worthless. Winslow stated that to see any gains they needed a minimum of 35 degree lower intake temps. With the room, cooling and psi loss it simply did not make economical sense.
    Water/methanol injection is more feasible.
    anywho, I hope that helps.
    this is a dyno on the g2 done on a fwd passat 2.8 this will give you a comparison of the hp loss due to Quattro 21/22% versus around 9% drive train loss for FWD.
    ***** 3.0 kings eurotuner article
    Stuff for 2.8 30v
    EXHAUST
    COLD AIR INTAKE
    CHIP
    CLUTCH
    TIP TRANSMISSION CHIP
    SUSPENSION
    BRAKES
    SUPERCHARGER
    USPClub Member # 32
    Nominated best detailer in western washington
    Chosen as one of the top 9 detailers in the US by autoweek.
    Apr 28 2005
    MD
    Hey Grouse, what would you say if I told you I have a contact that is willing to make a one- off headers and L/W flywheel?I also found a Stage three clutch from Spec and South Bend.
    Sep 06 2005
    send me the links, dyno's and pricing if you can I'll put them into the FAQ.
    USPClub Member # 32
    New Member Three Rings Speedyejl's Avatar
    Mar 23 2005
    Long Island, New York
    First motion to sticky this thread
    As mentioned prior, upgrade information regarding Audi N/A V6 engines is extremely hard to find and never detailed. This thread will be a godsend for many.
    <img src="http://nychitmen.com/car/web1.jpg">
    Sep 06 2005
    With respect to Supercharged audi, sometimes they can be a bit abrasive when asking for help and advice. Getting this all together was to allow people to see the info first hand and understand the limits of it.
    Most people see it here, audiforums, aw ect. then head there.
    If i can give them this info here then they avoid the newbish questions there.
    USPClub Member # 32
    Sep 06 2005
    Added the convo about FMIC and Water/methonal injection threads.
    USPClub Member # 32
    Sep 06 2005
    Updated info to include Suspension, brakes, snubmounts, differential.
    Still to include clutch.
    I have also to put together all the aggregate g2 dyno's and 2.8 30v information and links.
    USPClub Member # 32
    Veteran Member Four Rings Feeesh's Avatar
    May 31 2005
    San Diego
    anybody know how high you can rev the car once it's chipped?
    Sep 06 2005
    with giac I believe it is 6500 or 6700.
    once the G3 is installed Pes brought it back down to 6400 if i remember correctly.
    USPClub Member # 32
    May 31 2005
    San Diego
    short shifters too. Not that those increase power, but they make shifting so much quicker. I wonder how much time a short shifter will shave off a quarter mile. Think a .5 second?
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    not even close feeeeesh!
    is that chronic smoke from your avatar?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 06 2005
    Bump for Sticky purposes
    USPClub Member # 32
    Feb 13 2006
    B6 3.0 Quattro (RIP), E55 AMG
    Sticky!!!!
    Black B6 A4 3.0 QMT6 (RIP)
    Black C5 S6 Avant
    Black W211 E55 AMG
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, Puerto Rico
    Apr 16 2007
    B6 A4 AVANT 3.0 USP 6MT, 04 CBR 600RR
    San Mateo, CA
    Re: 3.0/2.8 FAQ sheet.
    i think the links need to be updated. alot of them do not work.
    Sep 06 2005
    Feel free, i spent two weeks hunting everything down two years ago.
    USPClub Member # 32
