Results 1 to 7 of 7
    Established Member Two Rings JuggernautB5's Avatar
    Nov 28 2014
    Upstate NY
    01 AWM block with AEB head problem
    Okay I've searched but can't find much anyways like it say 01 1.8t AWM block with AEB head the car runs great just keep getting a CEL code P0340 says it's the Cam Positioning sensor , I've changed the CPS and I am still getting the CEL and from what I have read if the timing was off it wouldn't run right at all so I am kind of puzzled at this point any help would be good
    Dec 05 2007
    Cam windows are different. If you did not swap the one out from your old AWM head, you need that one.
    https://www.ecstuning.com/b-genuine-...or/06b905234a/
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Mitch is probably right! Did you swap the cct out for the vvt version?
    "The American people already know that Bill Clinton is a bad boy, a naughty boy. I'm going to speak out for the citizens of my state who in the majority think that Bill Clinton is probably even a nasty, bad, naughty boy." Former Senator Idaho Senator Larry Craig, the man with a wide stance.
    2001 A4 1.8TQMS Mods- GT2871R, Maestro, All things that are good.
    2000 A4 Avant 1.8TQMS- Daily Driver
    2000 S4- Working?
    Nov 28 2014
    Upstate NY
    Thanks guys I'll give it a try I bought the car this way so not too sure what else could be wrong lol but I'll keep y'all updated
    Dec 05 2007
    Use this website when it comes to DTCs for the VAG platform. Also take the hall sender off and see if there is a bunch of oil inside. Could possibly be playing with the signal and a new cam seal will be necessary at that point. My advice is to check wiring, then replace both hall sender and hall window (link above). If that does not fix it, then I am stumped.
    http://wiki.ross-tech.com/wiki/index.php/16724/P0340
    Nov 28 2014
    Upstate NY
    Okay just took the hall sender off and it's not an AWM cam rotor its the one for AEB so now I have to wait for the new one to come in so time to play the waiting game
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Quote Originally Posted by JuggernautB5 View Post
    You can use one off any vvt 1.8t.
    2000 S4- Working?
