Results 1 to 19 of 19
    Jan 02 2017
    Geleen
    N75 vacuum lines
    Hi guys,
    Today I found the cause of my power issues. Both n75 vacuum lines are busted on my 1.8T. I want to replace them with silicone. Does anybody know the inner size of the 2 lines in MM? Mine are all worn out so I cannot meassure that.
    Thanks for the info guys!!
    Sent from my SM-G930F using Audizine mobile app
    Nov 10 2015
    Sudbury, ON
    post a photo of the lines you want measured, I can get some measurements for you
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Jan 02 2017
    Geleen
    https://www.dropbox.com/s/sltnia7lss...0008.jpeg?dl=0
    The one that is disconnected. That's the inner size I need. One goes to the turbo and one to the waste gate.
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Mitcheman View Post
    3/8" hose will do the trick
    Jan 02 2017
    Geleen
    Whats that in mm? 8'5/9? I'm from the netherlands. Metric system.
    Aug 19 2013
    minnesota
    I used 4mm on all of those. It's snug and sturdy, I ordered from a good website with quality stuff, can't recall the name, oem hoses can be had in ebay cheap if you have the part numbers and it's sturdier and will last a long time.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Jan 02 2017
    Geleen
    I have got the oem number. Found it on etka. Oem retail price 29 dollars. So i'm looking for heat resistent silicone for example.
    Nov 10 2015
    Sudbury, ON
    Sorry, I had N80 in my head for some reason. Measurement from N75 valve.
    Jan 02 2017
    Geleen
    Quote Originally Posted by jesse500 View Post
    Thank mate! Will replace mine this friday. Hopefully my boost will come back. Got zero power in the high revs. And an overboost error.
    Nov 10 2015
    Sudbury, ON
    No problem man, Like Jacobsen said, 4mm would be perfect.
    Aug 06 2014
    Melbourne/Australia
    Just so you're aware, both of the hoses that go from the N75 to the turbo/wastegate are larger at at the N75 end. (They are ~5mm at the N75 end and ~3mm at the Turbo end)
    4mm hose will fit, but it'll be really tight on the N75 connections.
    You can see the flare in the hose in this pic.
    Nov 10 2015
    Sudbury, ON
    A little heat, and the 4mm will slip over the N75 no problem. the hose I had was 5mm, but also a little old/stretched abit
    Jan 08 2010
    '02 S6 avant 01E, '04 A4 1.8tq USP, '06 Scion xA
    DFW Metroplex...wait, what?
    034 sells a replacement hose kit for the N75 valve. Silicone, with clamps, and much more affordable than dealer part.
    Established Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    The stock N75 hoses are silicone for what it's worth. Reinforced, no less.
    Jan 02 2017
    Geleen
    Fixed my boost issue. Here is the cause of everything :
    https://www.dropbox.com/s/476reawtlk...0010.jpeg?dl=0
    Established Member Two Rings benjad's Avatar
    Sep 12 2014
    Mechanicsburg, PA 17050
    Should these hoses be replaced regularly
    Sent from my SM-G930P using Audizine mobile app
    Jan 02 2017
    Geleen
    I think you should check em fro time to time. With a diy boost leak tester.
    Sep 12 2014
    Don't have any of that stuff. I'm not even sure where those hoses are locatated
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Just get 6mm ID hose and call it a day. Otherwise you'll be squirting KY in the hope of gettin' it in a smaller hole.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
